Shutdown This unit plays for about 30 minutes and then shuts down and the power and the temperature red LED's stay on solid. I have no info on this. Please help. Magnavox - 50ML8105D/17 DLP TV chassis - DLP001 -carl hello, I have 50" magnavox 50ml8105d/17 TV, when I turn it on it stays on for about minute and goes out. the indecator light shows that the lamp is over heating, so I check the bulb and the fans, but they are fine. what could my problem be.
  • 4 more comments
  • gtcl May 27, 2008
    Guru
    the filter that you are referring to is on the sides of the TV
  • gtcl May 27, 2008
    Thanx, but have taken them off awhile ago. and thank you answering my post.
  • gtcl May 27, 2008
    Thank you. but where and how do I identify the thermal sensor in the TV.
  • gtcl May 27, 2008
    Thanx again, now can it be purchased and were?
  • gtcl May 27, 2008
    Thank you for the last time , and will these changes, if it work, what can I do to help for the help you have given me.
  • gtcl May 27, 2008
    your time and help alone were worth 100% rating.
  • 8,617 Answers
Try cleaning the air filter and see if that solves the problem.
Posted on May 26, 2008
  • 4 more comments
  • Sonny Berry
    Sonny Berry May 27, 2008
    On some models its on the side and on other models its on the rear. You should notice a small access panel with vents which is secured by a screw. The filter will be behind that cover.
  • Sonny Berry
    you may have a defective thermal sensor.
  • Sonny Berry
    They are usually located on or near the lamp compartment. some are a small cylinder and other types are a triangle.
  • Sonny Berry
    it should be available at www.partstore.com you enter your model number and it will list all the parts that are available for your model.
  • Sonny Berry
    thats quite allright. Hope everything works out and you get the set functioning properly again.
  • Sonny Berry
    Thanks let me know if you need further assistance
Error light in my apc smart ups sc 1500va ups
1. Four beeps every 30seconds (On Battery LED will be illuminated)
This alarm indicates that the Battery PowerSupplied outlets are now supplying battery power as opposed to power from theutility. If the UPS determines that the input utility power is unsafe for yourcomputer equipment, the UPS will switch to battery power.
Note: Ifthe power disturbance is brief, you may only hear one or two beeps.
2. Continuous Beeping (On Battery LED will beilluminated)
This alarm indicates that a Low Batterycondition has been reached and that the UPS will soon shutdown. Once the UPStransfers to On Battery operation, it can only stay on battery for a limitedamount of time. The UPS will sound this alarm about two minutes before thebatteries are totally exhausted. Once exhausted, the UPS will shutdown and turnoff its output power to your equipment. If you hear this tone you shouldimmediately shutdown your computer to prevent data loss or corruption.
3. Continuous Beeps for 30 seconds (BackUPS OFFICE 250 and 280 ONLY)
This alarm indicates the unit has detected anOverload condition after it has performed a self-test during start-up.
4. Continuous Two-Tone Beep
This alarm indicates a severe Overload wasdetected while the unit was on-battery operation. This tone will continue tosound until the unit shuts down.
5. Continuous Tone (On Battery LED will beflashing)
This alarm indicates that the battery-poweredoutlets are overloaded.
6. Continuous Tone (On Line and On BatteryLEDs flashing) Back UPS OFFICE 350,400, and 500 ONLY
This alarm indicates that an internal UPS faulthas occurred.
Dec 08, 2011 | APC Smart-UPS SC 1500VA UPS System
I ahve a beeping sound that is coming from my garage door opener.
If you have an opener with battery backup this may help. BBU stands for 'battery back up.'
This is battery related. On top of your unit is a battery pack with three colored led lights. You can tell what is going on by looking at these. This information is in your manual or here it is.
GREEN LED: All systems are normal. A solid LED light indicates the batteries are fully charged. A flashing LED indicates the batteries are being charged. NOTE: Batteries do not have to be fully charged to operate the motor unit. YELLOW LED: The motor unit has lost power and is operating off of the BBU. A solid LED with beep, sounding approximately every 2 seconds, indicates the motor unit is activating the door and is operating off of the BBU. A flashing LED with beep, sounding every 30 seconds, indicates batteries are low. Once the power is restored the BBU will recharge. This is indicated by a flashing GREEN LED. RED LED: An error has been detected and the BBU will automatically shut off. The BBU will attempt to restart by reconnecting to the batteries. If the error is still present it will shut itself off again. This process will repeat every 5 minutes or until the error has been resolved. This is used to prevent further draining of the batteries. If a red LED remains on when the power is restored, and is accompanied by a beep sounding every 30 seconds, please call for service.
Jul 09, 2011 | Sears Craftsman LiftMaster Chamberlain...
Have had to replace the backup battery in the opener 3 times in the last year. What could be draining the battery?
Here is some general information that you probably already have. The opener should keep that battery charged. I would recommend getting a service technician out. Just when you really need that battery backup it will be out.
On top of your unit is a battery pack with three colored led lights. You can tell what is going on by looking at these. This information is in your manual or here it is. GREEN LED: All systems are normal. A solid LED light indicates the batteries are fully charged. A flashing LED indicates the batteries are being charged. NOTE: Batteries do not have to be fully charged to operate the motor unit. YELLOW LED: The motor unit has lost power and is operating off of the BBU. A solid LED with beep, sounding approximately every 2 seconds, indicates the motor unit is activating the door and is operating off of the BBU. A flashing LED with beep, sounding every 30 seconds, indicates batteries are low. Once the power is restored the BBU will recharge. This is indicated by a flashing GREEN LED. RED LED: An error has been detected and the BBU will automatically shut off. The BBU will attempt to restart by reconnecting to the batteries. If the error is still present it will shut itself off again. This process will repeat every 5 minutes or until the error has been resolved. This is used to prevent further draining of the batteries. If a red LED remains on when the power is restored, and is accompanied by a beep sounding every 30 seconds, please call for service.
Jun 28, 2011 | Sears Craftsman LiftMaster Chamberlain...
I have a Chamberlain Whisper Drive and it started beeping. Reading the manual, it seemed that I needed to replace the battery. It is about 5 years old. Replaced the battery and the LED is no longer red but...
On the back of the garage door opener there is a red button. Depress this button and sync your keypad to the opener. This will re-establish the code and reset the remote.
May 27, 2011 | Sears Craftsman LiftMaster Chamberlain...
The main unit beeps every 30 seconds
GREEN LED: All systems are normal. A solid LED light indicates the batteries are fully charged. A flashing LED indicates the batteries are being charged. NOTE: Batteries do not have to be fully charged to operate the motor unit. YELLOW LED: The motor unit has lost power and is operating off of the BBU. A solid LED with beep, sounding approximately every 2 seconds, indicates the motor unit is activating the door and is operating off of the BBU. A flashing LED with beep, sounding every 30 seconds, indicates batteries are low. Once the power is restored the BBU will recharge. This is indicated by a flashing green LED. RED LED: An error has been detected and the BBU will automatically shut off. The BBU will attempt to restart by reconnecting to the batteries. If the error is still present it will shut itself off again. This process will repeat every 5 minutes or until the error has been resolved. This is used to prevent further draining of the batteries. If a red LED remains on when the power is restored, and is accompanied by a beep sounding every 30 seconds, please call for service.
Jan 25, 2011 | Sears Craftsman LiftMaster Chamberlain...
Lift masters battery keeps bleeping every 5 seconds,does this means my battery needs replacing.
Jan 15, 2011 | Sears Craftsman LiftMaster Chamberlain...
The battery backup beeps and the service light is on. The battery tests good with a volt meter
Dec 30, 2010 | Sears Craftsman LiftMaster Chamberlain...
Opener beeps
Nov 06, 2010 | Sears Craftsman LiftMaster Chamberlain...
Dell 1110 Laser Printer Solid red warning light
Hi in this case the paper jam made some sensor through the paper road they are not in normal position or still tigger on by piece of something or error stander. you may try:
1) check paper input sensor near paper tray roller\
2) check margin sensor inside paper way before drum unit
3) check fuser sensor near fuser unit
4) check paper output sensor near output tray roller
sometime need sensor adjustment back to normal position
Dec 22, 2008 | Dell 1110 Laser Printer
Automatically powers off, flashing red LED
try removing one neck board at a time and see if it stays on and longer,don;t let the board touch any metal or a short wil follow and you got problems.try the red first,
Sep 03, 2007 | Toshiba 43H70 43" Rear Projection...
Televison & Video Logo
456 people viewed this question
Top Televison & Video Experts
Electro Med Services...
