Maytag washer leaks from bottom when rinsing and spinning. What is wrong?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 113 Answers
Remove front panel and watch where water is coming from during the spin. When the main seal goes bad it will slign or spray water from the center area.
Posted on Oct 02, 2010
Maytag Bravos XL HE Leaks Adjacent to Bleach Dispenser, how do I fix this?
Fill it with water by hand and see what happens. Tape paper towels in the suspected area. Makes it easier to see. Part 2 ans: so the water is over powering the drain...that sucks. You are right, the valve is probably letting too much water out. I don't know if it is adjustable but I do know it'll probably cost a lot for an itty-bitty brass valve. If money is not a problem replace the valve. If you are a DIY'er, I'd try to use some sort of clamp on the hose leading into the dispenser and close it just enough to slow the flow down. Another idea is to open the drain up by cutting away some of the screen if it has one. A better source than me is to go to repairclinic.com and email them. They have a lot more experience than me. I did appliance repair as a side to handyman for 20 years & fixed just about everything for 50. I never had any formal training.
Jun 19, 2015 | Maytag Washing Machines
Maytag washer lat8600
That model doesnt come up on Matags web site?
Nov 25, 2013 | Whirlpool Washing Machines
My washer is leaking bad and does not spin all the water out
there may be a blockage in the waste water pump had a similar problem with a beko there was a rubber band wraped around the outlet fan
Jan 23, 2013 | Maytag Atlantis MAV6000 Top Load Washer
Wont spin
Sounds like the transmission seal had failed sometime back and has leaked the lubricant causing the transmission to overheat and now possibly seizing the gears, if this is the case the transmission will have to be replaced. Depending on the age of the washer, (5 years or less) you should contact Maytag to see if they will compensate you by way of furnishing the new transmission for free, but you will be responseable for the labor charge from a tech to do the replacement.
If they will not cover the part, you will probably be better off to replace the washer than to invest in the cost of a new trans and labor.
Good Luck !
Mar 21, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Washer leaking from the bottom
It will be the normal trial and error. Remove the top lld and the back panel.statt the wash again and start looking for anything obvious. Start from the soap box, then carefully look down the sides and then if nothing seen, switch machine off and tilt machine untill you can see the underneath. Look for any areas where there is water .(when visible start looking a little higher untill you find the spot.) Most of the underneath areas are likely rust spots that have broken through.. On occation the pipes are perferrated and have a small leak. All observation.
Sep 23, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Maytag performa mod#pav2200aww leaking between rinse and spin cyc
My Performa started leaking from the Drain Pump rubber gasket. It had dryrotted. However, Maytag doesn't make a replacement O-ring gasket. You have to buy the whole new pump! Thanks Maytag.
Jul 05, 2009 | Maytag PAV2300 Top Load Washer
Washer leaks from bottom during rinse cycle
Take the cover off the back, and look up, next to where you put the soap in, when it's filling/rinsing. There is (like) a (white) plastic valve body, and look to see if water is dripping out of it. I haven't figured out a solution to that yet, other than to replace it.
Also check the boot, coming off the pump. You could have a bad/dry boot, or a loose hose clamp.
Mar 21, 2009 | Maytag Neptune MAH5500B Front Load Washer
Whirlpool calypso model GVW9959K-0 leaking during rinse cycle
hi my name is joyce
Sounds like your pump is leaking. if it is leaking when you are on a spin cycle.
now if it is stuck on f1 cycle and wont drain unplug and let stay unpluged for 60 seconds and replug and see if you can restart on drain and spin cycle. let me know if I can help with any other problems.
thanks
joyce
Feb 06, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Washer does nothing during rinse then leaks during spin cycle
hi thanks for the question i would check the drain hose your problem is the washer is not draining check the drain hose thanks the appliance doc
Sep 27, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
