Question about Kenmore 24032\24036 Top Load Washer
Warm water only on kenmore washer
My mom has a washer from 2000, I have the small parts book I would like to change the temperature switch for them but I am not sure it will solve the problem. They get only warm water. please help.
  • 2 more comments
  • mom80 May 27, 2008
    This is my fathers washer, so i am going by what he has stated. I went to talk to him to clarify everything. The machine gets cold and warm water. He states that he has removed the hoses and there is no problem with the flow to the water mixing valve. He gets no hot water.
  • mom80 May 30, 2008
    I am going to check the filter on the hot inlet or ask my dad if he did so. I appreciate all the help. The last bit of info that suggested I look at the filter also stated that I may be able to find the part I need locally. I am going to try both.
  • mom80 May 31, 2008
    I have not had a chance to try to find a part locally before I get one online. Thanks
  • Buck Whyte
    Buck Whyte May 11, 2010
    How is the flow on the hot water? check the pressure and see how it flows..  Simple things first.
I changed the water mixer valve, they had one at a local sears repair outlet. it was 23.00
thanks for all the advise.
Posted on Jun 20, 2008
  • Kenmore Master
  • 5,568 Answers
There may be a downstream screen at the back of the washer in each line.
I would check both ends of the hose to ensure they are clear.
Also, the mixing valve on most machines is a piece of **** and are prone to failure.
They are mostly not not hard to replace and you can save some bucks normally by buying it at Johnstone Supply if you have one nearby.
Posted on May 28, 2008
I have a Kenmore washer model 110.98762792 and im having a problem with the cold water. When the water temperature switch is set to the cold/cold position the washer does not fill with cold water. W
Since U get warm water that tells you that the cold and hot water solenoids are both operating. Ergo the anomaly has to be with the device that controls temperature.
Apr 10, 2017 | Kenmore Washing Machines
Mom has a Kenmore stackable washer. She ran water into the washer and all the water came out on the floor.
This seems like a difficult problem but is an easy fix. Remove the hose from the water level switch and blow out the sediment like this:
Service manual and more photos HERE
Oct 22, 2011 | Kenmore 98702 Stacked Washer/Dryer
Water mixing improperly set on cold and warm or hot water is being dispenced
Did you check to make sure the hoses are connected to the correct temperature spigot? They may have been swapped when the washer was hooked up. Really easy to fix, just unscrew the hoses that go from the faucets and switch!
Aug 19, 2010 | Kenmore 24032\24036 Top Load Washer
I dont know what the piece is called but it goes on the back of my front load washer and it seperates the hot water from the cold water and its cracked
Are you referring to the water valve assembly? If so, you can purchase a new assembly. Check with a parts distributor. You will need the brand and model number.
Unplug the washer. Turn off the water supply (hot and cold) to the washer and disconnect the hoses at the washer (there is no need to disconnect the hoses at the wall). Make certain that you replace the hoses correctly on the new water valve with corresponding hot and cold hoses coming from the wall. Disconnect the wire harnesses to each temperature (hot and cold) on the water valve. The harnesses should be color-coded. Replace them correctly on the new valve. Turn the water supply back on and plug in the washer. Run a small water level while testing different temperatures (hot, cold and warm). Check for water leaks and proper temperature.
Feb 20, 2010 | Kenmore Washing Machines
Automatic warm/cold water temperature setting does
The temperature control board is bad . Pt # 388246
Aug 17, 2009 | Kenmore 22422 Top Load Washer
Water changes temperature
just a suggestion kathy;
the hoses that connect the washer to the hose bibs at the wall usually have screens in them at either end. they connect on both ends the same as a garden hose. if the screen on the cold supply is somewhat clogged, this could be your problem.
Oct 07, 2008 | Whirlpool LSR5132PQ Top Load Washer
Kenmore heavy duty washing machine 70 series
The most likely cause for water fill temperature problems is the solenoid has burned out, usually cold first, it gets used more. Not a repairable item , easy to replace
Dec 30, 2007 | Kenmore 24032\24036 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
Sal De
fordexpert
Robert Rankin
