Question about Hoover SteamVac Carpet/Upholstery Deep Cleaner Vacuum
Solution tank does not dispense--recovery tank still sucks up dirty water from tile floor on screen porch. I applied cleaner manually with a scrub brush and sucked it up with the hoover steam vac deluxe.
    President:
  • 1,673 Answers
Check to see if the when you squeeze the trigger, the rod is hitting the reservior asm(tank sits on). If not then there is a problem inside the handle and the rod. If it is hitting, then the reservior asm. is bad. Also make sure fluid is coming out of the tank when you push the vavle in at the bottom of the tank.
Posted on May 26, 2008
How to I clean the grout on my kitchen floor?
There are many ways to clean stained grout. You could try one of the commercial cleaners sold on the market and scrub it with a brush. You can also try creating your own cleaning solution. This way you will avoid using harsh chemicals in your home, which is always a good thing. You could try making a paste of baking soda and some water and use it to scrub the grout with, or you could spread some baking soda on the grout and then pour some vinegar on it. After about half an hour you should be able to scrub off the dirt easily. In some cases the grout is so dirty, that the only option is to remove it and apply new one. You can check the website attached, the professionals there know a lot about tile cleaning and maintenance.
High Quality Tile and Grout Cleaning in Melbourne
Oct 06, 2015 | Vacuums
How do i get ceramic tiles to have a shine again. they are not high gloss but they used to have a shine to them
You might try a steam cleaner like the Shark Steam Cleaner. If you use a polish, sometimes that makes it worse and makes your tile dull. Just use plain old soap and water. The Shark also scrubs your floors as it cleans.
Feb 13, 2015 | Vacuums
Will not dry or suck up water at all...BRAND NEW
If it's brand new your best bet might be taking it to a Hoover service center. That'll have a year warranty on it so the fix would be free.
Apr 06, 2013 | Hoover H3044 FloorMate SpinScrub Wide-Path...
Not sucking up the dirty water or it's sucking up water but it's not filling the recovery tank. I've tried reattaching the lid of the recovery tank and it doesn't look like it is sitting quite right.
This is one possibility. other things to look are the screen filter on the machine. intake hose behind the motor. ensure that accessory hose cover is closed when extracting water from the floor.
Oct 06, 2009 | Hoover F6212-900 / F6215-900 SteamVac...
Steamvac won't **** the water into the recovery tank.
This usually means one of a few things:
1. The lower tank is full
2. You did not dispense water (sloution tank empty), when applying solution to the floor.
Jan 19, 2009 | Hoover SteamVac F5914-900 SpinScrub...
No suction
I used a new Hoover Spin ScrubSteam Vac the first time and it worked great. The next day it would not such up the water and sounded like it was sucking air. I took off the lid on the recovery tank and when carefully inspecting the gaskets saw a every so small slilt in the small gasket that surrounds the intake duct. I put some silicone glue on it to close and seal it. This morning I tried sucking up water on a tile floor and it worked OK! I have not tried it again on carpets but am keeping my fingers crossed.
Jan 06, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover SteamVac Deluxe
http://geeksquad.fixya.com/ThreadView.aspx?prdid=618767&thid=624426
Posted by providence51 on May 26, 2008
My cleaner is not dispensing the shampoo solution. Still sucks up the dirty water that I manually applied with a scrub brush. I use this on my tiled screen porch floor and it has worked great many times.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Hoover SteamVac Carpet / Upholstery Deep Carpet Cleaner.
There is a release value in the bottom the holding tank that may be bad and not opening or the trigger assm in the handle may be broken and not connecting to release the water to scrub and clean the carpets. You should really check with your local factory authorized Hoover vac dealer in your area or , please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
May 26, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Kenwood Steam mop
The Manufacturer suggests you clean the hose by removing the water tank dammed if u can get it off though.
Nov 26, 2007 | Eureka Enviro Steamer 310 Stick Vacuum
Suction button
This happens when the filter on the inside of the lid for the dirty water tank is pushed all of the way up. You need to leave a 1/4 in. gap from the top to the top of the filter
Sep 28, 2007 | Hoover SteamVac F5914-900 SpinScrub...
Hose Attachment
On the clean / dirty water tank there is a red lint lint filter, this is on the upper part of the tank,
If this is blocked it reduces the suction ,this must be free from debris,
If you are using the turbo brush ,
there is a sliding switch on the brush, This diverts the suction from the brush to the nozzle of the attachment ,
You should see the dirty water traveling up the hose ,
You should only use bissells own cleaning solution as using another product would null your guarantee
Jun 11, 2007 | Bissell 9400 ProHeat Upright Wet/Dry...
Hoover SteamVac Carpet/Upholstery Deep Cleaner Vacuum Logo
342 people viewed this question
Top Hoover Vacuums Experts
Roger Potts
Mike Cairns
Mike Cairns
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
