Question about Nikon D300s Body only Digital Camera
My new 2month old..d300s..my if Switch Off it shows On..LCD goes Blank..no live view..on top LCD..doesnt show the details of memory card..like how many photos to be clicked..CF...PC doesnt ditect..etc.. rest like shutter is working...
  • 10,865 Answers
Hello. Turn it on and then go into the menu and find the reset function. Reset it. What this means is a reset to factory settings.
If that does not solve the problem return the camera while it is still under warranty. Joe
kindly rate my answer as 4 thumbs up. Thank you.
Posted on Oct 02, 2010
  • kishanm2000 Oct 04, 2010
    i did the reset..option..but the problem remains..now i have dispatched..it authorised nikon service centre...thank you very much..!!!..for th quick reply...!!!
    but very much upset with nikons d300s.. perfomance..i have hardly cliked..2500photos..:(...
    thanks again..
Hp r507
I don't think anything is wrong with your camera. Just check the Manual.
Your camera has a view finder, to make pictures. Yes the little screen on the top left (Backside) As an extra the camera has live view, that can be switched on and off. because the live view consumes lots of power, it is advised to use the view finder. If you want to switch it on, you can do so in the settings menu. There go to the live view en switch it on.
Feb 13, 2014 | Cameras
Tip
My new 2month old..d300s..my if Switch Off it shows On..LCD goes Blank..no live...
DSLR Camera or All kinds of Expensive camera needed a good care.Otherwise it will effect by Fungus or Moisture cause the damage to your Camera.I Have a Tip to give you to Protect your Camera in inexpensive way.
Tip:Take a Cardboard Box ,cover your camera and lens with dry cotton cloth and put it inside the Box.Make a Coin size hole in any side of the box and connect a zero watts Bulb or Frigde lamp fix to the hole.(You should need only a Zero watts Bulb or Fridge Lamp)You can switch on the Lamp now.Another way is to buy silica and put it in your bag even if you travelling.Silica will obserb moisture and kep your camera dry.
on Oct 02, 2010 | Nikon D300s Body only Digital Camera
Is it possible to be locked out of my hard drive
yes
if its a usb external drive you might need a usb 3 card installed on your computer your computer might not have enough usb output power
USB 3 card will provide more power when needed to the device to gain maximum throughput and conserve power when the device is connected but is idling
http://blog.premiumusb.com/2010/09/usb-2-0-vs-usb-3-0/
these can be purchased on Ebay cheap and easy to install
http://www.ebay.com.au/itm/PCI-e-PCI-Express-USB3-0-Card-new-NEC-720200AF1-chipset-/330608109325?pt=LH_DefaultDomain_0&hash=item4cf9c7670d
for roughly $9 or $10free postage
or
Click start control panel scroll to folder options view place a tick in show hidden files folders and drives
this may vary depending on your operating system
http://majorgeeks.com/Dr._Freeware_System_Utilities_d6416.html
Support IDE/SATA/USB Hard Drives memory cards USB Memory Drives
Windows Password Cleaner
Available in Live CD to run offline
This is a utility to blank the password of any user that has a valid local account on your Windows system.
You do not need to know the old password to blank the password.
hope this helps
Oct 30, 2012 | Iomega Prestige 500 GB USB 20 Hard Drive
No picture display on the LCD screen
If camera shows previously stored images in memory card in playback mode correctly but does not show live view in camera mode to take fresh pictures then its problem of ccd imager chip failure that will be replaced to solve the issue.
Canon offers free of cost ccd imager chip replacement for Canon A95 and few other models.
Click Canon CCD Imager Advisory for details.
Thanks.
May 21, 2010 | Canon PowerShot A95 Digital Camera
I have a Canon A95. The view finder is blank, and when you try to take a picture, it doesn't show in the view pane after you take it either, what is wrong?
If camera shows old taken pictures properly in playback mode but does not show live view to take fresh picture then it got known problem of ccd imager chip failure that will be replaced to get it fixed.
Canon offer free of cost ccd imager chip replacement for A95 model.
Thanks.
Feb 27, 2010 | Canon PowerShot A95 Digital Camera
Viewfinder and LCD screen only show black and record black
If camcorder shows old recorded tapes picture with correct colors in LCD but does not show live view in camera mode to record new movie then its ccd imager chip failure.
And if camcoder shows live view and old recorded tapes in its eye piece view finder but does not show any thing in LCD the its problem of broekn/ cracked flexible wire between lcd board and main board of camcorder.
Let me know your finding with bit detail to provide you solution/ helpful info.
Nov 18, 2009 | Sony Handycam DCR-HC30 Mini DV Digital...
Hi I have a fujifilm f470 finepix camera. One
Is it just the live view from the lens that you can't see ( totally blank screen), or are the icons visible?
If it still shows the icons but no live view then I suspect the shutter mechanism is stuck over the lens inside the camera.
Have a look at the lens and see if you can see the inner lens? You may have to adjust the zoom to bring the inner lens up to the end of the lens barrel.
If it is stuck then it will require removing and inspecting / cleaning.
Aug 26, 2009 | Fuji Rod Repair Kit
My sony cyber shot dcs-t1 . The LCD goes all white when i take a picture. I rarely use the camera.
Couple of questions..
Does camera show live view correctly on LCD to take picture?
Does camera playback old stored pictures in memory card properly in LCD?
Let me know to find out problem in DSC-T1
Jul 23, 2009 | Sony Cyber-Shot DSC-T1 Digital Camera
LCD screen doen't display the view
So camera doesn't give live view to take picture? and you can view old / stored  pictures OK, is it?
If yes, then it is problem of CCD imager in Canon A80 and this part needs to be replaced.
Canon will repair your A80 free of cost as per announced scheme of CCD imager support.
Click Canon CCD Advisory to know how to get free repair facility.
Jan 07, 2009 | Canon PowerShot A80 Digital Camera
No picture displayed on lcd (blank)
Does your camera playback old recordings fine? and just can't show live view to record?
If yes, then camera has problem of bad ccd imager and this part will be replaced.
Sony announced free of cost repair scheme for subject problem. DCR-HC20E is PAL system camera so Sony Support UK can be visited for free of cost repair details as your camera model is listed there.
If you live in different country, let me know to guide you further.
Thank you.
Oct 26, 2008 | Sony DCR-HC20E Mini DV Digital Camcorder
Nikon D300s Body only Digital Camera Logo
129 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
