Question about Maytag SAV2555A Top Load Washer
Washer will not agitate ,but will spin?How do i fix this?How much?
I had the same problem and had a repair guy come out who told me it was the powertrain aka transmission. The estimate was $350 to repair. Thankfully my home warranty covered it and decided it would be cheaper to replace than to fix. I had a Maytag Performa is the only difference. I actually called several other appliance shops in the area who all basically said it was the transmission and very expensive to replace. When it is agitating it goes one way and for it to spin it "spins" the opposite way. Good luck with your washer issue!
Posted on May 23, 2011
Washer not agitating properly.
Try looking under it as I've had that problem and found it was build up of dust
Jul 11, 2015 | Kenmore Washing Machines
My roper top load washer model rtw4440vq fills with water but wont wash, spin or drain
see this causes and fix it. God bless you
Motor Coupling If the washer won't spin or agitate the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and
Drive Belt If the washer won't spin or agitate, check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't spin or agitate properly.
Drive Motor If the washer won't spin or agitate the drive motor might be defective. This is not common. Check all of the other related parts to this symptom before replacing the motor. If the motor is visibly burned out or physically damaged, replace it.
Stator Assembly If the washer won't spin or agitate the stator assembly might be burned out. The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed.
Door or Lid Latch Assembly If the washer won't spin or agitate the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't spin or agitate the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Motor Control Board If the washer won't spin or agitate the motor control board might be defective. The motor control board provides power to the motor as well as direction and force. If the motor control board is defective the washer may not work at all or function properly.
Sep 30, 2012 | Roper Washing Machines
Kenmore washer agitates on spin cycle
Obviously the washer should be either just spinning or agitating. The transmission ,or in this style washer it is called the gearcase, is bad and would need to be replaced. The gearcase controls the spin and the agitate in this washer. The part number is 3360629 and retails for $172.77. To replace; Unplug washer, remove the 2 trim pieces on either side of the console, remove the 2 screws under the trim, lift the console and rotate to the back, remove the 2 retainers going from the back into the cabinet, remove the cabinet, remove the drain pump, remove the motor, remove the agitator, remove the gearcase with 3 bolts holding it on. The gearcase will now slide out of the washer. Transfer the clutch and motor mounting plate to the new gearcase and reassemble in the reverse order.
Thank you
Jan 23, 2010 | Washing Machines
Agitator just stop working. Spin cycle will run. Rinse will drain the water, add new water, but the Agitator will not work. Do you have any ideas? Do you know how old the machine is?
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump
removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
This problem points to a couple of places:
The first unfortunately is the motor. Kenmore / Whirlpool top load direct drive washers use a reversing motor.
When in agitate mode, the motor turn one way, When in spin mode it turns the other way for draining and spinning.
I'd check the following first before assuming that it's the motor though.
First, I'd pull the agitators and check for worn or damaged splines inside the agitator or on the agitator shaft.
Following is a description of how to take them out.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
If the agitator and shaft are OK, the problem may be in the transmission.
See the following Whirlpool / Kenmore installation and service manual for top load, direct drive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/
$FILE/L-55.pdf
I'd also look at the troubleshooting section of the manual.
Starting at page 10, you'll see a description of how the transmission changes from agitate to spin mode.
The key (and likely problem) is the "agitator spring".
The spring holds the agitate gear down so that the two sets of splines on the agitate gear are connected and the agitate rack
can turn the agitators.
See the following Whirlpool parts list for a blow-up of the transmission and how the various gears and springs connect.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
See the following for how to remove the transmission and clutch.
Tearing apart the transmission is a bit messy but if the problem is the spring or agitate cams, it's a lot less expensive to
fix than a $170 transmission.
Remove the clutch (the spring holding the clutch to the spin pinion is a bear to replace.
Remove the 8 transmission screws carefully, the transmission is full (15 oz.) of 80-90 weight oil.
Remove the transmission cover and drain the oil.
Pull off the spin pinion.
Carefully remove the clip that holds the main Spin Gear on and remove it.
Push down on the agitate spring and remove the spring clip. Note where is attaches to the main shaft.
Check the spring, Agitate Cams and the cams in the Neutral Drain Assembly.
Re-assembly is obviously the reverse of taking it apart.
If you're reasonably comfortable with tools you can fix it yourself.
When we had a problem with ours, we ended up spending less than $30 replacing the agitate cams, neutral drain assembly and oil instead of $170 for a transmission. It was worth fixing.
As an aside, tearing the washer apart will give you the opportunity to completely clean it..
As to the age of the washer. Whirlpool / Kenmore washers use a part of the serial number to determine the year the washer was made..
Jan 11, 2010 | Kenmore 23822 Top Load Washer
Kitchenaid top load washer wont agitate or spin
you have a direct drive washer with a coupling broke.Here is a good article on it http://repair2000.com/coupling.html
Dec 11, 2008 | KitchenAid KAWS700L Top Load Washer
Old model rca washer machine...will not agitate/wash the clothes,does spin.
If the washer fills up with water and you hear the motor running but the agitator doesn’t move, the agitator coupling is the most likely problem. First pump the water out by turning the timer to spin. Once the water is out, turn the washer off. Now pull up on the agitator until it comes off (it may be hard to pull off). Now that the agitator is off, you can see the agitator coupling, reach down and try to turn the coupling. If the coupling turns freely, it is striped out and needs to be replaced.
Sep 29, 2008 | Washing Machines
Washer won't agitate or spin
The transmission is dead!
It's not worth fixing!
If it's 10 years old or more, better off replacing it with a newer machine which will be much more efficient!
1998????????????
Not worth the money to fix!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Try You should call service.:
A&E Factory Service
1-800-905-9505
Nation wide / 7days/24 hours
Good work
Please give me a "Solution Solved Rating", in this site!
Thank You
Neil
Aug 01, 2008 | Frigidaire FEX831CS Top Load Stacked...
Washer fills and spins but does not agitate
Im sorry to say, it sounds like the transmission in the washer may have gone out, the unit it self sits at the bottem of the main agitator shaft under the the tub, you may be able to have this replaced, but shop around for the right price.
Jan 26, 2008 | Washing Machines
No agitator action
I need to get the model of the washer. (e.g. 123.123456789). This will greatly help to identify the problem and a fix for the washer. Thanks
Jul 07, 2007 | Kenmore 24032\24036 Top Load Washer
Maytag SAV2555A Top Load Washer Logo
47 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
