Question about Dell E172FP 17" LCD Flat Panel Monitor
Monitor stays dark
The power button is green, and I can very faintly see the menu, but it is not clear enough to make out the text.
Have the settings been changed? (other people use this PC too) How do I reset? Or is there another problem?
    Problem Solver:
  • 19 Answers
Check that VGa cable is firmly connected at both ends. If you have a DVI connection try switching it to DVI.
Posted on May 26, 2008
I have a sony KDL 46xBR2 when I turn on powers up green light stays on but a dark gray screen no picture or sound
The green light merely indicates that power is getting to your TV. The symptoms you describe point to internal power supply failure
Mar 17, 2013 | Sony BRAVIA KDL-52W3000 52 in. LCD...
I have a problem with my l2046nv monitor. It turns on, flashes and stay dark, you can however see the picture but it's VERY faint (flash light helps). I turned it off and on.. it would turn on and show a...
Look for bad caps with leaking/bulging tops or seals first.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Oct 14, 2010 | Westinghouse L2046NV Monitor
It has a very dark screen, I can barely see my
Check the pins on both end of the connector, make sure they're straight other wise, reposition it with fine long nose pliers. Make sure the connectors are push and screwed tight also. Let us know!
Oct 10, 2009 | Samsung SyncMaster 205BW LCD Monitor
I have a FPD 1830 flat screen monitor not displaying picture
Send the monitor. It's a power supply problem. My 15.4" LCD has the problem, too, whenever I move the monitor down, it powers off, and the menu disappears as well, but I'm going to fix the screen.
Jul 08, 2009 | Gateway Computers & Internet
I am charging my Gamin Edge 305 and can barely see the LCD screen
  1. Power the unit on.
  2. Press the mode button to access the Main Menu.
  3. Select Setting > System > Display > Contrast.
  4. Now press the enter button and continue pressing the arrows up or down to change the contrast.
Jul 04, 2009 | Garmin Edge 305 GPS Receiver
Dark screen
reset your monitor settings with deafaults with menu.u see some buton on lcd or monitor.
Dec 29, 2008 | ViewSonic VG900 19" Flat Panel LCD Monitor
Extension cable
Have you connected an extra cable as extension or Replaced the original cable with a Longer one?
In Either case the cable is to blame,Normally you should be using one single high quality cable from computer to Input of monitor.There is signal loss due to longer lengh or joint.
Hope this answers your question?
Please rate the solution and provide feedback.
Thanks.
Samir
Jun 04, 2008 | BenQ FP731 17" LCD Monitor
Powering on
OK ... after a lot of trial and error, I got mine to work. I think it may be a really low charge or something. I had to press the power button until it was completely dark ... no flashing faint green or any colors. Then when I plugged it in, I got a solid red and left it for awhile. Then when I pressed the power button I got yellow, red and green ... the computer recognized it and then got a solid yellow.
Before when I had it plugged in, I'd get a lot of red random flashing ... and it just didn't seem to charge at all ... even after a full day.
I think the issue was that it was in this "flashing state (red when connected, very faint green when disconnected)" It wasn't easy to get it to turn off completely. Most of the presses of the power button didn't change the state at all. But if I got it just right, I could see the faint green light go off. That's when I plugged it in and got a solid red light, and eventually a good charge.
Hope this works for some others.
May 23, 2008 | LeapFrog FLY Fusion Pentop Computer
Monitor blinks on then turns off after computer boots up
It could be your LCD backlight giving you problems. When the image "goes off" shine a flashlight in the lower left hand corner of your screen. Look for the ?Start? button, if your backlight is not working you?ll see a faint ?start? button if you look closely. Depending on the monitor this is usually and economically repairable problem. Let us know if you have any other questions and please don?t forget to rate this posting.
Jul 20, 2007 | Hyundai L72S-8 17" LCD Monitor
Picture not clear and shuts off after about 2 seconds after being turned on
It could be your LCD backlight giving you problems. With the computer on and the monitor power LED green shine a flashlight in the lower left hand corner of your screen. Look for the Windows ?Start? button, if your backlight is not working you?ll see a faint ?start? button if you look closely. It could be your LCD backlight giving you problems. With the computer on and the monitor power LED green shine a flashlight in the lower left hand corner of your screen. Look for the ?Start? button, if your backlight is not working you?ll see a faint ?start? button if you look closely. If you can see the start button then it?s either the backlight tube or the electronics that controls it. This is repairable but I would not recommend the typical user try it unless they have tools and some experience with disassembly and handling of electronic components. It goes without saying that if you are unwilling to risk damaging the monitor you should take it to your local repair shop. You will spend about $50 more in labor but you save yourself guessing which parts are bad (a potential savings) and you will typically get a warranty of sorts. If you don?t see the start button I would next suggest you connect this monitor to another computer to see if the problem goes with the monitor or stays with the computer. Let us know what happens and if you need some more assistance.
Jul 11, 2007 | Envision G175 Monitor
Dell E172FP 17" LCD Flat Panel Monitor Logo
56 people viewed this question
Alun Cox
