When my computer starts it goes to a black screen and says "no bootable device jnsert boot disk and press any key" what can i do
  • 32,281 Answers
Normal 0
This error message - "No bootable device. Insert boot disk and press any key" means -
The PC cannot see a boot file/disk on either the hard disk or floppy drive.
Check the floppy drive and remove and floppy disk.
If there was no disk in the floppy drive then it is a hard disk problem.
Check the BIOS to see if the hard disk is detected, if not open the case and re-seat the data cable on the hard drive and also where it connects to the motherboard disk controller.
If it still gives this error message and the BIOS does not detect the hard drive, then the hard drive is probably faulty.
A further check on the hard drive, remove the hard drive and connect it to an USB hard drive adapter and connect it to a working computer's USB port, if this computer does not detect it as an external storage device then the hard drive is faulty.
To get the computer working again, install a new hard drive in your computer and then install Windows on the new hard drive plus the computer's device drivers and your programs.
Posted on Oct 02, 2010
What do you do if no bootable device is found
When your pc starts as no bootable device that means it either can't see the hard drive or it's trying to start from the dvd or floppy? Do you know how to get into the bios menu?
Aug 23, 2014 | Compaq Computers & Internet
Maxdata pro 5000 ir
There are many good reasons for booting your computer from a USB drive.
For instance, if you want to try out another operating system without disturbing the main hard drive on your computer, then installing the new OS on an external drive is a great way to run the system through its paces and decide whether you like it.
This approach will offer you the flexibility of being able to run both operating systems on your computer.
However, before you can boot the new operating system from the USB drive, you will need to change the boot order for your computer in the system BIOS.
Connect the external USB drive or pen drive to the computer before you power it on.
Press the "Delete" key as the computer performs the "Power On Self Test" (POST) to enter the BIOS area of the computer firmware.
The POST performs a diagnostic of components on the motherboard and does a cursory check of the hard drive, memory and processor.
The POST only lasts a few seconds; therefore, press the "Delete" key quickly.
Enter the administrative BIOS password if prompted to do so.
Once you enter the correct password, you will see the main BIOS screen.
Use the right-arrow key to navigate to the "BOOT" menu option at the top of the screen, and press the "Enter" key.
Press the down-arrow key until the cursor is on the "Boot Device Priority" label. Hit "Enter," and press the down-arrow key again to highlight the "1st Boot Device" option.
Press the "+" or "-" keys to scroll through the available boot options until the "USB Drive" or "USB-HDD0" label is the highlighted option.
Press the "F10" key to save changes and exit the BIOS setup program.
When the computer restarts, wait for the "press any key to boot from external drive" prompt to display, and then press any key on the keyboard to boot from the USB drive.
Award or Phoenix BIOS
Connect the USB drive to the computer.
Wait for the POST to display on the screen, and press the "Delete" key to enter the BIOS.
Enter the BIOS password if prompted to do so.
Tap the right-arrow key until the cursor is over the "BOOT" menu option.
Press the "Enter" key.
Press the down-arrow key until the highlighted cursor is on the "Removable Devices" option. Press the "+" key until the "Removable Devices" label is on the top of the boot device list.
Press the "F10" key to save the changes for the boot order in the BIOS and to exit the utility.
After the computer restarts, press any key on the keyboard to boot from the USB drive when prompted to do so.
bootable USB guide, here we assume that you are using either Vista or Windows 7 to create a bootable USB.
1. Insert your USB (4GB+ preferable) stick to the system and backup all the data from the USB as we are going to format the USB to make it as bootable.
2. Open elevated Command Prompt. To do this, type in CMD in Start menu search field and hit Ctrl + Shift + Enter. Alternatively, navigate to Start > All programs >Accessories > right click on Command Prompt and select run as administrator.
3. When the Command Prompt opens, enter the following command:
DISKPART and hit enter.
LIST DISK and hit enter.
Once you enter the LIST DISK command, it will show the disk number of your USB drive. In the below image my USB drive disk no is Disk 1.
4. In this step you need to enter all the below commands one by one and hit enter. As these commands are self explanatory, you can easily guess what these commands do.
SELECT DISK 1 (Replace DISK 1 with your disk number)
CLEAN
CREATE PARTITION PRIMARY
SELECT PARTITION 1
ACTIVE
FORMAT FS=NTFS
(Format process may take few seconds)
ASSIGN
EXIT
Don't close the command prompt as we need to execute one more command at the next step. Just minimize it.
5. Insert your Windows DVD in the optical drive and note down the drive letter of the optical drive and USB media. Here I use "D" as my optical (DVD) drive letter and "H" as my USB drive letter.
6. Go back to command prompt and execute the following commands:
D:CD BOOT and hit enter. Where "D" is your DVD drive letter.
CD BOOT and hit enter to see the below message.
BOOTSECT.EXE/NT60 H:
(Where "H" is your USB drive letter)
7. Copy Windows DVD contents to USB.
You are done with your bootable USB. You can now use this bootable USB as bootable DVD on any computer that comes with USB boot feature (most of the current motherboards support this feature).
Note that this bootable USB guide will not work if you are trying to make a bootable USB on XP computer.
http://www.howtogeek.com/howto/16822/boot-from-a-usb-drive-even-if-your-bios-wont-let-you/
boot from a usb drive
Jun 22, 2013 | Computers & Internet
No bootable device
when ur computer starts,start press the f8 key again again after that there will come so many option chose repair or restore option.
NOTE: it may delete your newly installet software. choice is urs then don't blame me
Jun 07, 2013 | Toshiba Satellite Computers & Internet
How to boot from usb flash drive
There are many good reasons for booting your computer from a USB drive. For instance, if you want to try out another operating system without disturbing the main hard drive on your computer, then installing the new OS on an external drive is a great way to run the system through its paces and decide whether you like it.
This approach will offer you the flexibility of being able to run both operating systems on your computer. However, before you can boot the new operating system from the USB drive, you will need to change the boot order for your computer in the system BIOS.
Connect the external USB drive or pen drive to the computer before you power it on. Press the "Delete" key as the computer performs the "Power On Self Test" (POST) to enter the BIOS area of the computer firmware. The POST performs a diagnostic of components on the motherboard and does a cursory check of the hard drive, memory and processor. The POST only lasts a few seconds; therefore, press the "Delete" key quickly. Enter the administrative BIOS password if prompted to do so. Once you enter the correct password, you will see the main BIOS screen. Use the right-arrow key to navigate to the "BOOT" menu option at the top of the screen, and press the "Enter" key. Press the down-arrow key until the cursor is on the "Boot Device Priority" label. Hit "Enter," and press the down-arrow key again to highlight the "1st Boot Device" option. Press the "+" or "-" keys to scroll through the available boot options until the "USB Drive" or "USB-HDD0" label is the highlighted option. Press the "F10" key to save changes and exit the BIOS setup program. When the computer restarts, wait for the "press any key to boot from external drive" prompt to display, and then press any key on the keyboard to boot from the USB drive. Award or Phoenix BIOS Connect the USB drive to the computer. Wait for the POST to display on the screen, and press the "Delete" key to enter the BIOS. Enter the BIOS password if prompted to do so. Tap the right-arrow key until the cursor is over the "BOOT" menu option. Press the "Enter" key. Press the down-arrow key until the highlighted cursor is on the "Removable Devices" option. Press the "+" key until the "Removable Devices" label is on the top of the boot device list. Press the "F10" key to save the changes for the boot order in the BIOS and to exit the utility. After the computer restarts, press any key on the keyboard to boot from the USB drive when prompted to do so.
also
Bootable USB guide, here we assume that you are using either Vista or Windows 7 to create a bootable USB.
CLEAN
SELECT PARTITION 1
ACTIVE
FORMAT FS=NTFS
ASSIGN
EXIT
http://www.howtogeek.com/howto/16822/boot-from-a-usb-drive-even-if-your-bios-wont-let-you/ boot from a usb drive
Apr 16, 2013 | HP s3700y PC Desktop
Emachine350 has no bootable devce
Try pushing f2, and going into boot options, and make sure the hdd appears in the list, if not, it's possible the hdd has coincidentally failed. If it does appear what order are the boot options in?
Mar 15, 2012 | Computers & Internet
Hi! I need help with my computer. I use a seagate ST380811AS hard disk in my desktop computer. The problem now, is that everytime I start my computer "A non system disk" appears on the monitor or...
1 Remove any floppy disks or bootable CDs, DVDs, USB flash drives or other bootable media from the computer. Attempt to restart the computer again. Proceed if you continue to receive the error.
2 Restart the computer again. Press the key required to enter your BIOS setup. (The monitor usually displays a "Press [key] to access BIOS" right after restarting your computer. Press the key shown on your screen.)
3 Navigate to the "Boot Options" or "Advanced" menu by using the arrow keys. (The precise menu terms will vary according to your computer and BIOS type.)
4 Select the hard disk that contains your operating system (usually C:) as your primary boot device. Select your CD/DVD drive, your floppy drive or another hard disk as your secondary boot device.
5 Save and exit the BIOS. Proceed with the next step if you see the "Non-system disk error" message again.
6 Restart the computer. Return to the BIOS' "Boot Options" screen by following the steps above, then set the "CD/DVD drive" as the primary boot device and the hard disk as the secondary boot device. Save and exit the BIOS.
7 Insert your Windows installation disc. Restart the computer. Press any key to boot from disc. Follow the on-screen prompts to reinstall Windows.
8 Replace your hard disk drive if you cannot install Windows.
Thanks for choosing Fixya
Sandeep
Mar 19, 2011 | Computers & Internet
How to fix no bootable device - insert boot disk and press any key
the harddrive might be loose. check that the IDE/Ribbon Cable, or SATA wires are secure into the back of the hard disk , and where the other end of the cable meets the motherboard.
next , make sure the bootable device order is correct. that it is indeed trying to boot of the hard drive. that is done in the BIOS. Press DEL, or F12 or whatever option (sometimes F2) is displayed on the screen at the very start of the powering on state. (this is called the POST screen).
If you access the BIOS screen from the POST (the black DOS screen before windows starts) look in the listing for Logical Boot Order, and ensure that the Hard Disk Drive is listed as one of the first in the order.
try that and see what happens.
because beyond that, you might have a dead hard drive, or the master boot record on your disk is corrupt, and either of those are bad results.
Jul 10, 2010 | Computers & Internet
When I start the netbook it goes to black screen telling me ex rom no bootable device-insert boot disk and press any key
The netbook can not detect the hard drive or SSD you may have to remove the drive then reseat it if the problem persist then replace the drive.
Jan 29, 2010 | Acer Aspire One Netbook 8.9" Notebook
Boot problem
use the orginal windows cd and inset the disk and
show the press any key that time press ENTER ok ...........after booting is start .................send me feedback.......ok
Apr 01, 2009 | Computers & Internet
Computers & Internet Logo
294 people viewed this question
David Payne
David Payne
