Question about Kenmore Elite Oasis 27052 Top Load Washer
I can't get the water to drain out of my washer. It had a code that read LD when it broke any ideas
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 113 Answers
Most of the time I find coins or socks jammed in the drain pump. Turn machine 180 degrees, tilt up against wall, and pull pump. Dislodge whatever's lodged in it.
Posted on Oct 02, 2010
Washer won't drain. Code is Ld
Ld usually means door not closed. So probably trouble with lid switch. Or actuator that hits switch broke or loose.
Mar 05, 2016 | Haier 1.5-cu ft Portable Washer 20"...
Ld code. It won't drain. Not the drain pump (I changed) and not clogged pipe.
Slow drain code. How high is the outlet pipe ABOVE the machine?
Jan 05, 2016 | Washing Machines
I have a whirlpool gold catalyst it will not drain water, reading says LD?
LD = Long Drain...  "Ld" flashes if it takes longer than 5 minutes to pump out water to a point where the operating pressure switch resets.  could be a bad pressure switch, the pressure hose, the water pump..  those are good places to start.
Jul 31, 2010 | Whirlpool GSW9800PW Washer
What does the code Ld mean???
Ld flashes when the water level does not change after the drain pump is on. ? Is the drain hose or the drain pump clogged? ? Is the drain hose height greater than 96′?
Apr 26, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Ld code on my whirlpool cabrio, won't drain water, what do you do?
Hi There
OK here's something you can read to help you with. I hope this helps.
Ld Long Drain Ld flashes if it takes longer than 5 minutes to pump out water to a point where the operating pressure switch resets.
Press STOP/CANCEL to clear the display. Thank you for writing to fix ya.
Best regards Richard
Dec 11, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Ld code appears intermittantly
ld is a long drain time...you may have something in he drain or a bad inpeller in the drain pump...it is taking too long to drain out
Sep 18, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
''LD'' error
“LD” stands for “long drain,” meaning it took an excessively long time for water to drain out of the washer. Common causes for this are kinked drain hose or clothing, like panties or socks, caught in the pump suction hose. Why, I’ve even heard of bra wires coming loose and getting stuck in that hose, collecting all sorts of gookus and pinching off the flow of water to the pump. Can you imagine? Yea verily, as surely as the Sacred Suds doth eternally pass my lips, the “LD” error code springs forth from such anomalies.
for more information follow the below link --
http://fixitnow.com/wp/2009/03/11/whirlpool-calypso-washer-full-of-suds-wont-drain-and-throwing-an-ld-error-code/
Mar 20, 2009 | Whirlpool WTW6600SW Top Load
LD is on my display-nothing will clear it and washer doesnt drain
the ld code means a long drain, what you probably have is something blocking the drain pump.
you can get to the drain pump from the back of the unit and it will be the pump on the left as you face the back.
you will need to remove the hose going into the pump and be ready for water to come out. sorry but you need to check inside the hose as there will be something blocking it. like a coin or some lint or a small sock.
when you get the item out of the hose then it should work again. you do not need to reset the control. once it knows the unit is draining properly it will be ok.
Jan 30, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
LD.;....................
LD= Long drain if the unit has taken more than 5 min to drain out the water this code appears.. you eiter have a pump issue or a pressure switch issue.. does all the water go out of the unit??
Feb 16, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
HELP? ob & ld codes
Ld means long drain you probally have a bad water pump.Those models have a seperate motor for pump, the shaft on the motor is a star type and has probally stripped out the pump.Replace your water pump
Jan 03, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore Elite Oasis 27052 Top Load Washer Logo
Sal DeAngelo
fordexpert
Mike Carew
