Question about Denon AVR-1603 Receiver
My Denon AVR 1607 is shutting off by itself and no matter how many times I turn it back on after several minutes it shuts off again; why is it doing it and how can it be fixed?
Gurudristi
  • 98 Answers
SOURCE: Technical Problem on my Denon AVR 2802
How good are you with electronic repairs...? Do it if only you are confident...
The way you describe you problem it seems more like poor solder connections somewhere on the board. Usually these are at the voltage regulators where there can be some heat. Also, look for any connections that appear to be grasiny or have rings and resolder them too.
Alternatively, suggest that you take it to the Denon service center closest to you.
Best of Luck..
Posted on Mar 05, 2009
  • 92 Answers
SOURCE: AVR-589 Denon Receiver Keeps Shutting Off
even if the wires are not touching they can still arch. make sure there is no bare wire showing ie. cannot see any unshielde speaker wires. id unplug then replug back in
Posted on May 18, 2009
localwonder
  • 6784 Answers
SOURCE: shuts off then red light indicator flashes, disconnected all speakers but still wont work
Hi, this is a power board issue. remove the cover and make sure that this unit doesn't have blow fuse. if the fuse is fine, you will then need to replace the integrated power/ main board.
Posted on May 21, 2009
  • 5 Answers
SOURCE: Denon AVR older receiver but worked fine; now
Did you try to reset the unit? Resetting the unit has fixed every problem I have ever had......turn off unit.....hold down A+B at the same time then turn the unit back on...hold buttons for roughly 3 seconds....Let me know if it works.
Posted on Mar 09, 2010
  • 163 Answers
SOURCE: Denon AVR 2105 power shuts off,
The receiver has an internal problem like bad power supply or burnt channel. You need to bring it to a local repair shop or mail it here.
Posted on Feb 07, 2011
Denon AVR-1513
disconnect speakers then try again if still shutting down you will have bad outputs.
Aug 26, 2014 | Denon Audio Players & Recorders
Similar situation as previously described with the Denon AVR-1508, but mine will shut off after about 10-12 minutes the first time around and then ~2 minutes after it is turned off and then back on. Unit...
Most new receivers have a fan on the back, if you have one check to make sure it is working, most won't activate until the unit gets warm, other issues are bad solder connections on the audio outputs causing intermittent shutdown, as a final inspection check speaker connections to the receiver and speakers.
Sep 18, 2011 | Denon AVR-1508 Receiver
Whenever I start playing on my xbox or playstation, the receiver will shut off (the red light is blinking around the power button). Once I hit the button, it stops and then I can turn the receiver back...
does it only shut off on high volume or a loud noise?
It's the amp tripping to protect itself.
look out for a shorting speaker wire or faulty speaker etc. disconnect each in turn to find out which
Sep 03, 2010 | Denon AVR-987 Receiver
My denon avr 1803/883 shut off while playing a cd that had only been in for 5 minutes. there have been no changes to the inputs or additions to speakers. atthis time when i turn it on it is on for about 10...
CHECK IC101 AND IC102 THESE ARE THE + AND - 15VOLT REGULATORS. iF THEY ARE OFF BY MORE THEN 3 VOLTS IT WILL SHUT THE UNIT DOWN/IC101 IS THE +15V AND IC102 IS THE -15V IF THESE VOLTAGES ARE GOOD THEN THE UNIT IS GOING IN TO THE PROTECT MODE AND YOU WILL HAVE SHORTED OUTPUT TRANSISTORS. I HOPE THIS HELPS YOU.
Mar 27, 2010 | Denon AVR-883 Receiver
Denon AVR881 Turns on for few seconds then shuts OFF
(Probably too late to help you, but I'll post so others can see)
I had the same thing happen to my trust AVR-881 two weeks ago. Even re-initializing the processor was no help.
I took it to the repair shop. They replaced three transistors on the board, and charged about $175 for the job.
Apr 25, 2009 | Denon AVR-881 5.1 Channels Receiver
Shuts off after only a couple of sec.
Your reviever is "clipping". You need electronics service from a professional repair shop.
If you are savy in the world of electronics... Most likely you have a bad cap or preamp circuits that are overdriving the amp supply.
Jan 22, 2009 | Denon AVR-2307 Receiver
Denon AVR-4802R automatically shuts off in multi-zone mode
i had the volume of the multi-zone tuned too high and was attenuating it in an external control box. Once i took the multi-zone volume down to -25db, the problem went way. My main zone was operating around -35db so did not have the problem.
Nov 23, 2008 | Denon AVR-4802 Receiver
Denon AVR-3802 Problem
Check that your speaker cables are not touching each other at the amp end and also at the speakers as this will cause the amp to shut down.
hope this helps.
CABLE GUY.
Jul 12, 2008 | Denon AVR-3802 Receiver
Denon AVR-1803 shuts down
I am a Tech in Michigan and have worked on lots and Lots of Denon AV Receivers. These units have Protection circuits for Overcurrent, Dc Protect, 15v Regulator inbalance, Rail Voltage Inbalance, Low Ac Voltage, Low Standby Voltage and Thermal Protection just to name the ones I remember. My guess is you Probably have either Poor Intermittent solder connections or Amp is not Ventillating Properly. Make sure you leave room above Receiver to Vent and You are using no Less then 6 ohm speaker Impedance per ch. Refer to Speaker Impedance chart on back panel . kstahl65@att.net
Dec 06, 2007 | Denon AVR-1803 Receiver
Denon AVR-1603 Receiver Logo
268 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
