Question about Hoover SteamVac Carpet/Upholstery Deep Cleaner Vacuum
Hoover SteamVac Deluxe
My cleaner is not dispensing the shampoo solution. Still sucks up the dirty water that I manually applied with a scrub brush. I use this on my tiled screen porch floor and it has worked great many times.
I need instructions for this model f7412-900
Posted on May 31, 2008
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 310 Answers
Http://geeksquad.fixya.com/ThreadView.aspx?prdid=618767&thid=624426
Posted by providence51 on May 26, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Hoover SteamVac Carpet / Upholstery Deep Carpet Cleaner.
There is a release value in the bottom the holding tank that may be bad and not opening or the trigger assm in the handle may be broken and not connecting to release the water to scrub and clean the carpets. You should really check with your local factory authorized Hoover vac dealer in your area or , please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on May 29, 2008
The brushes don't turn. It runs and dispenses shampoo and water and sucks it up but the brushes stand still.I cleaned them and filter etc still doesn't work.
There is a plastic shaft on the back of the block brush (spin scrubbers), these wear out or break. You may need to replace the block brush. Or if the shaft is not broken it could also be the Turbine Gear. This is what the block brush shaft goes into. You can get access to it by taking off the hood. You can find the parts and a schematic below follow the link. Please don't forget to give positive feedback.
F72XX Link
http://www.usavacuum.com/Hoover-Steamvac-s/110.htm
Jan 23, 2010 | Hoover F7220900 SteamVac V2 Upright Vacuum
My hoover spin scrub machine has stopped scrubbing. It still dispenses and pulls up the water, but the brushes don't move. I've checked the on off button for brush control and cycled it to off and back on,...
There is a filter on the front right hand side of my F5871-900 Hoover. If you remove the plastic covering and clean that filter (wet finger may do), you're Hoover will begin spinning again!
Jul 03, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Steamvac won't **** the water into the recovery tank.
This usually means one of a few things:
1. The lower tank is full
2. You did not dispense water (sloution tank empty), when applying solution to the floor.
Jan 19, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Hoover Steam Vac Spin Scrub Carpet Cleaner won't suck
http://geeksquad.fixya.com/ThreadView.aspx?prdid=618767&thid=728884
Hoover Steam Vac Spin Scrub Carpet Cleaner won't...
Posted by hoofbeats1 on Jul 01, 2008
My machine is a little more than a year old. I have used it about 5 times. It started leaking the third time I used it. The fourth time I took it out, the brushes would not spin (I did clean them and rinse them after use each time).
Now the engine screams and won't **** anything up. Do you have any suggestions? My last Hoover Steam Vac was great and lasted for 3 years! Hi,
I have a Hoover Dual V SteamVac F7425-900 that the brushes won't spin. The lint screen is clean & the brushes switch is in the on position.
It dispenses & sucks up the cleaning solution & water; just no brush action. Help
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The only thing that I can recommend is that you may have a bad switch, some vacs may have a broken belt or the drive mechanism inside the Hoover Dual V SteamVac F7425-900 in or by the brush assm section and is need of repair. Please check the trouble shooting section of the owner’s manual if you’re needing help and to save money. If you don’t have one then contact the Hoover factory cust serv. So, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
8 a.m. - 7 p.m. EST
Go Ahead. Use Us.
Jul 01, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover Steamvac Deep Cleaner
http://geeksquad.fixya.com/ThreadView.aspx?prdid=40578&thid=661545
Hoover SteamVac Deep Cleaner
Posted by Alex987 on Jun 10, 2008
I can't seem to figure out how to use it =(
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Hoover F5807 SteamVac Wet/Dry Vacuum. Well, there are 2 tanks, one is the water solution tank that is on top and the other is the water recovery tank of which is on the bottom. You use the trigger assm to release the water and the Hoover SteamVac works the best on the pull back. You can spry the water going forward but pull it back very slowly and let the brushes do the scrubbing for you and the dirty water pickup. There is a ball in the dirty water pup tank that will rise to the top and stop the water from coming in, @ that point you need to empty and rinse out the recovery tank and re-install. If you run out of solution the top tank cap or cover is the measuring cup to determine the amount of solution – usually it is one cap full and extremely hot water, there is a switch for the carpet and the upholstery, if the handle is in the released position then the brushes down below should be moving – just look in the brushes window and see if they are moving – if the handle is in the upright position then you can remove the attachment hose and then use the attachment and the revolving brushes will stop. I hope this will help you in working with the Hoover SteamVac. If not contact the Hoover Co and get an owner’s manual and give them the model # and serial #. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
8 a.m. - 7 p.m. EST
Go Ahead. Use Us.
Jun 10, 2008 | Hoover F5807 SteamVac Wet/Dry Vacuum
I have a hoover steamvac dual v and is leaking, bristels not working very food only two are speaning and is not sucking any water Very little solution comes out, or comes out in streaks when pressing the...
http://geeksquad.fixya.com/ThreadView.aspx?prdid=41020&thid=634728
I have a Hoover SteamVac
Posted by albazo on May 30, 2008
I have a Hoover SteamVac Dual V and it is leaking, bristles not working very well and only two are spinning and is not sucking any water
Very little solution comes out, or comes out in streaks when pressing the solution dispenser button on the handle. I think the lines may be stopped upped.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Hoover F5866-900 SteamVac Deluxe Wet/Dry. You probably have a couple of brushes that are broken – the brushes are and assembly unit and would have to replace the entire brush assembly, and you are correct that the suction part of the vacuum is probably plugged up. You can take a wire hanger and use that to try to clear the clogged opening, but to be honest you may have to disassemble the vacuum and clean it entirely and replace the brush assm and any type of belt if needed. Pleas, feel free to check with your local vac dealer in your area. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
8 a.m. - 7 p.m. EST
Go Ahead. Use Us.
May 30, 2008 | Hoover F5866-900 SteamVac Deluxe Wet/Dry...
Solution tank does not dispense--recovery tank still sucks up dirty water from tile floor on screen porch. I applied cleaner manually with a scrub brush and sucked it up with the hoover steam vac deluxe.
Check to see if the when you squeeze the trigger, the rod is hitting the reservior asm(tank sits on). If not then there is a problem inside the handle and the rod. If it is hitting, then the reservior asm. is bad. Also make sure fluid is coming out of the tank when you push the vavle in at the bottom of the tank.
May 26, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Cannot find replacement piece for the scrub brushes.
The part number for this brush block is 48437022, most repair shops will have or can get it for you.
Jan 22, 2008 | Hoover F5866-900 SteamVac Deluxe Wet/Dry...
Steam vac will not pick up dirty water
My Hoover Steamvac problem isn't with the bruches--it's with the suction. Dirty soapy water stays in the carpet instead of being returned to one of the holding tanks.
Oct 21, 2007 | Hoover SteamVac F5914-900 SpinScrub...
Suction button
This happens when the filter on the inside of the lid for the dirty water tank is pushed all of the way up. You need to leave a 1/4 in. gap from the top to the top of the filter
Sep 28, 2007 | Hoover SteamVac F5914-900 SpinScrub...
Hoover SteamVac Carpet/Upholstery Deep Cleaner Vacuum Logo
878 people viewed this question
Top Hoover Vacuums Experts
Roger Potts
Mike Cairns
Mike Cairns
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
