Question about Singer Pixie Plus Sewing Machine
I cannot thread the bobbin correctly on my singer pixie plus. I get it threaded and it will do three stitches and get caught. What am I doing wrong?
  • 29 Answers
SOURCE: a horrible tangle
This is a bit late, could the bobbin case not be seated properly? You need to put it into place and then turn it clockwise until it seats soundly in the opening. Also, check for burrs...the needle may have left a rough mark on the plastic or metal in the bobbin area. A piece of batting, or even an old knee hi should snag on any rough areas.
Posted on Jul 14, 2007
SOURCE: Singer Pixie - trouble threading bobbin
look at the bobbin direction. if it dont pick up that way, change the direction
Posted on Jun 26, 2009
  • 32 Answers
SOURCE: I have the singer pixie the bobbin wheel does not
you may have the wrong size bobbins. Most likely you have the wrong needles they are not long enough. Check your manual for the correct size.
Posted on Aug 08, 2009
  • 1116 Answers
SOURCE: Bobbin Thread is "birdnesting"
Get out the manual and refer to the maintenance section for cleaning the machine.
Especially the bobbin area. You want to make sure the area around the bobbin case is free of lint and thread.
Use a new bobbin and re-thread the machine, with the presser foot UP.
Install a new needle, again according to the directions in the manual. Installed incorrectly can lead to mis-stitching.
If the problem persits, the timing may need adjusting.
This should be done by the sewing machine tech for Kenmore.
Sewusa.com has a guide for this in the repair section, but you could end up with more problems.
Posted on Apr 30, 2010
SOURCE: Have a brand new Singer
I would try adjusting the tension on the machine - this sometimes causes the bobbin thread to jam while sewing. Re thread the entire machine including the top thread. Also it is recommended to use new thread as old thread can ball up after time. If no luck I would call the store you purchased the machine from.
Posted on Nov 30, 2010
My singer pixie plus will not pick up the bobbin thread. how do i fix this.
Install a brand new needle and verify the machine is threaded correctly. Also, use the correct needle for the machine, thread and fabric. If that doesn't help, then the machine is probably out of time and needs service.
Aug 16, 2017 | Singer Sewing Machines
Singer facilita 9858-1 top thread is winding around the bobbin case. It seems to get caught under the bobbin case retaining plate, around the left side of the case,& under the rim of the posi
try cleaning cleaning the tension disks, remember you tension setting,, take some unwaxed dental floss and go between the disc's to clean in them, and then reset the tension disc's by to normal
Dec 10, 2014 | Singer Sewing Machines
I just bought the pixie plus sewing machine by singer. It worked great for about 10 minutes the then thread and bobbin weren't catching. The top thread is neat but the bottom is a mess of loose thread. The...
The bobbin could be wound loosely or backwards but the bobbin also must be able to go into place and not fall out so check those things first
Nov 24, 2014 | Sewing Machines
The upper and lower thread are not locking together in the fabric
The easiest possible option is that the bobbin is not threaded correctly. This happens to my students and 99% of the time the bobbin thread is going the wrong direction, ex: it's flipped to go counter clockwise instead of clockwise.
Apr 14, 2014 | Singer Pixie Plus Sewing Machine
SINGER MODEL 3130 WILL NOT STITCH CORRECTLY
Have you tried cleaning and oiling your sewing machine.Sometimes old thread gets caught up under the pressure foot near bobbin if not cleaned out the bottom teeth that pull material through will not move bobbin thread up to be caught by needle thread. P.S. Are you sure your using the right needle for the machine? To short of a needle will also cause this problem
Apr 10, 2012 | Sewing Machines
Pixie plus bobbin housing
if you have the reciept for the machine, I'd take it back & get another one
maybe some place else
Feb 23, 2012 | Singer Pixie Plus Sewing Machine
Can't get the needle thread to loop over the bobbin thread. The bobbin thread is already thru the hole.
You only need the thread to loop over the bobbin thread to bring up the thread when you are threading the machine. If, you mean it is not sewing after threading then I need more information.
Nov 17, 2010 | Singer Pixie Plus Sewing Machine
Need instructions on threading singer pixie sewing machine
i need help too i bought this machine for my 9 year old daughter i thought she was just breaking it bieng so young and inexperienced but my husband and myself have tried also and the same problem accured i tried to follow the instructions but they are so very hard to follow can someone please help me? I keep threading the machine the needle and the threading the bobbin but i get half a stitch and it breaks again. Does
anyone know what im doing wrong?
Apr 24, 2009 | Singer Sewing Machines
Singer Pixie Plus Sewing Machine Logo
395 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
