Question about HP Photosmart C6180 All-In-One InkJet Printer
The message center says" The door on the device is open. Please close the door to continue." and the machine info screen says "carriage jam. Open door, clear carriage jam, and press OK to continue" I have opened the door in the back and replaced it, opened the ink cartridge door and closed it, turned the machine off and on . I don't know how to clear the carriage jam. The first part of the last paper that I printed jammed and I still haven't found a missing piece but have looked through the printer with a flashlight etc
  • 10,515 Answers
To start with, this is a VERY common problem. Many reports were already published for the same. Google and you would be surprised to know, how many people are already affected by the same. Kindly take a look at :-
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=au&lang=en&docname=c00829896&product=1153494
Follow all the 3 steps carefully.
Next make sure that there is no paper jam. Take a look at :-
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00720198&lc=en&dlc=&cc=us&product=1153494
If the problem persists,something is wrong with the sensor and sensor flag.
The door sensor is visible when the door is open -- located on the left side of the opening, just about an inch below a silver screw head. (kind of hard to describe where it is.) The sensor is a black horizontal bar. If you see it, try pressing it in with something thin like a paper clip. Press the sensor in about a 1/2". If the "door open" message goes away, then you know your sensor is good. Next look to see where the sensor flag is located on the back of the door. Again, it's on the left side toward the top of the door. The flag is simply a section of plastic that that sticks out far enough to engage the sensor.
If the problem cannot be detected, you need to send the unit for repair.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Oct 02, 2010
Print head jam
Check the LCD on your printer control panel or the status monitor on your computer for an error message. If there is an error message, follow the instructions to clear it.
If there is no error message, or if the problem continues:
  1. Open the access door.
  2. Disconnect the power adapter from the back of the printer.
  3. CAUTION: Do not use force on the printhead carriage to move it. Gently move the printhead carriage from side to side to see that it moves freely and there are no obstructions.
  4. Remove any obstructions that may prevent the printhead carriage and ink cartridges from moving to the center position.
  5. Close the access door.
  6. Connect the power adapter to the printer.
  7. Remove the ink cartridges from the printhead.
  8. Verify that the labels on the ink cartridges are intact, and that the cartridges are not damaged.
  9. firmly until you hear it click into position.
  10. Insert the color ink cartridge into the printhead, then press down firmly until you hear it click into position.
  11. Close the printer access door.
  12. Press OK to clear the error.
  13. Make a print.
May 06, 2014 | Kodak Office Hero 6.1
Carriage jam
Hi
The carriage door is the cartridges access door.Access the cartridges and make sure they're properly installed.To open:
  • Turn the machine on.
  • Open the cartridges door by lifting from the front center of the device until the door locks into place on its own.
Feb 27, 2012 | HP C6250 InkJet Printer
Display message Carriage jam: open door, clean carriage jam and then press OK to continue
This error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
Mar 21, 2011 | Office Equipment & Supplies
I get a message carriage jam and told to clear jam. However there is no paper jam. It tells me door open and it is not open. It seem the door does not go all the way up. I keep getting the message that...
It seems you mistook Carriage Jam as Paper Jam, but they are different issues. Carriage jam means the carriage that carries the cartridges is jammed which needs to be moved or be cleared manually after opening the door.
Please follow the instructions mentioned here (Click Here) [source HP Support].
Good Luck.
Let me know if you need further help.
Thanks for using FixYa.
Jan 14, 2011 | HP OfficeJet 6210 All-In-One InkJet...
I have a Epson stylus CX9400fax a piece of paper is jammed way inside the machine, I can't even see it to try and get it out! I've tried turing the machine on/off numerous time (still not expelling the...
If paper is jammed, a Paper jam message will appear on the control panel display.
Follow these steps to clear the jam:
  1. Gently pull any jammed paper out of the output tray or sheet feeder.
  2. If the paper is stuck inside, turn off the Epson Stylus CX.
  3. Open the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the Epson Stylus CX back on.
    alert_note.gif Note: Be sure to check the far left of the carriage area when checking for jammed paper. Paper that is jammed there may be hidden from view.
If paper jams inside the Automatic Document Feeder, clear the jam as follows:
  1. Open the Automatic Document Feeder cover and remove any jammed paper.
  2. If necessary, lift the document cover and remove any paper that has jammed inside.
  3. Press OK to clear any messages on the display screen.
Jun 02, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Stylus CX9400 Photo Printer: paper jammed inside printer...
May 18, 2010 | Epson Stylus CX9400 Photo Printer
Error message= open door clear carriage jam and
I think the message is instructions, as in
(1) open door (2) clear carriage jam (3) press enter
So there is something internal to the printer that makes it think it has a carriage jam, piece of paper under a sensor, dirty or stuck sensor.
If you can't find it using a bright light, try canned air.
Feb 01, 2010 | HP OfficeJet 6110 All-In-One InkJet...
HP Officejet 5110 - Carriage Jam Message
I have an Hp Officejet 5110. I have an error message saying "Open door,clear carriage jam, then press enter". But where is its door? How can I clear the carriage jam?
I tried pressing the # & 6 at the same time, but the error message still there.
Mar 09, 2008 | HP OfficeJet 5110 All-In-One InkJet...
HP Photosmart C6180 All-In-One InkJet Printer Logo
104 people viewed this question
Seeker5211
Seeker5211
