Question about Frigidaire GLEQ642A Electric Dryer
A noise starts when i turn on,later disappears. I think is the bearing.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 113 Answers
This is a very common problem with these dryers. The back bearing wears out fast. It's part no. 12 in this diagram. You have to remove front panels, top, and lift drum up and out to release from bearing. Hope this helps,
Posted on Oct 02, 2010
2006 Cadillac DTS makes noise when the wheel is turned, noise started after wheel bearings were replaced in the two front wheels
If it's a "squealing" sound - check the power steering fluid. If it's more of a grinding sound - then the wheel bearings were not properly "packed" with grease. Note - the grease needs to forced into the bearings by hand while rotating the bearings. I had a this problem myself when a "mechanic" just smeared some grease around the bearings.
Aug 15, 2014 | 2006 Cadillac DTS
High pitched whine while accelerating
remove the belt and start the engine ..IF THE NOISE disappear it might be idler bearings that driven by belt but if the noise still there check the pcv valve..
Sep 24, 2013 | Toyota Tacoma Cars & Trucks
My 2003 gmc envoy slt 4wheel drive had a wheel bearing go bad on the front driver side. I took it in and had it repaired. about a month later I started getting a grinding or rubbing sound. I took it back...
Hi! It should be on the trans axle or cv joint these could be the common problems when you are turning the wheel from left to right. Sometimes if ball bearing damage it would craete noise.. You must get back into your mechanic and remove and check for mechanical error..
Aug 24, 2013 | 2004 GMC Envoy
Engine roaring above 30mph
Is it possible you are hearing a wheel bearing instead of the engine or exhaust ?
Normally a bearing will roar on a turn and not on a straight stretch, but I guess its possible to do it the other way. A tire will make a roaring noise too.
I can't think of anything related to the engine that would roar only on a turn except maybe the power steering.
Feb 19, 2013 | 2006 Mazda 6 s
It began when I made left hand turns, there would be a vibration in the truck, like the tire was rubbing in the wheel well. Two days later I made a left hand turn and a noise of metal on metal grinding...
Sounds like a wheel bearing, and or a bad brake pad. Decide which wheel you think it is and pull that wheel to look at at the brake shoes or pads. feel for roughness when you turn the wheel by hand.
Nov 07, 2009 | 1993 Ford Tempo
Ford F150 2004 4x4 passenger side rear wheel noises
You can try the bearings but I think if you take off the rear rotors and look at the emergency brakes you'll find the problem. You might want to ride the emergency brake a little in lieu of removing the rotors to confirm the problem. Also some wheel covers make noise-drive without them and see if it helps.
Jun 18, 2009 | 2004 Ford F150
Engine noise
You guessed it, the shaft bearings are shot.
Jan 27, 2009 | 1995 Jeep Wrangler
Steering creeks when turning left or right. front wheel noise.
My advise is when u get a humming noise when banking left or right. Its beter to change both left and right wheel bearing and ball joints. Cause if u think about it those parts are put on at the same time . So if u think about it they have the same where in Terre . left or right hope this helps you.
Jan 25, 2009 | 1999 Chrysler Cirrus
Humming sound when driving
hi there sounds if your wheel bearing is shot best way to find out is drive your motor & if you can either turn steering left or right when driving you will find that humming noise will probably disappear if it does then its your wheel bearing.
Jan 21, 2009 | 2005 Nissan Maxima
Frigidaire GLEQ642A Electric Dryer Logo
268 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
