Question about Uniden BC350 Base Scanner
Dear Expert, I have BC350C. I set up a good scanner antenna and the high quality cable at the roof which works perfect with the other scanners. BC350C gets deaf in some of the bands, while perfect on other bands. At deaf bands if I change the antenna with a piece of wire it works fine. This is not an antenna and cable problem. Is there any solution for me to solve this problem. A.Tahir DENGIZ, TA2T
    An expert who has answered 20 or more questions within one hour.
  • 37 Answers
Suspect you live in a metropolitan area and your antenna is too good. You are experiencing RF overload into your scanner on certain bands. All I can suggest is some sort of band pass filters or a better scanner.
Posted on Aug 26, 2017
  • 14 Answers
SOURCE: i dont know how to progam it
This link is the owners manual with step by step instructions.
Note: Pleas vote for me.
Posted on Jan 27, 2008
  • 3051 Answers
SOURCE: how yo program a 2003 uniden bc350c scanner
Hello there:
the first thing that you will want to do is to go on line to and then from there look for scanners then look for your model number and you will see the section that refers to manuals you will be able to print it out if you have to and if not you will be given a telephone number that you can call to order a manual that will help you set up your scanner . ok hope that this helped out.
best regards mike
Posted on Jul 31, 2009
  • 20 Answers
SOURCE: To get celluar frequencies on bc350c 800mhz 100 channel scanner.
You can no longer listen to cell phones with police scanners as all cell phones are now digital. Years ago when cell phones were using the 800mhz band it was possible. But only with select older models of scanners such as the BC-200XLT and after an internal modification to allow tuning of 860-880 mhz range. I do believe there is equipment out there that can listen to digital cell phones but its very expensive ($10,000) and only for law enforcement use. Hope this answers your question.
Posted on Oct 15, 2009
SOURCE: How to pick up cell phone frequencies on scanner.
I had a scanner with 800mhz .. programed it to scan from 900.000
to 800.000 .. between those freqs. ..found several calls ... from cell phones .. but that was not what I was looking for ... I just ran into it by accident.
Police Officers ...from all agencies .. monitor cell phones .. all the time so if it illegal for citizens to do it , it should be for them also but I under the impression judges turn a blind eye to that fact.
Posted on Feb 24, 2010
  • 1274 Answers
SOURCE: 30 channel 10 band radio scanner uniden 8c60xlt
Make sure you have fresh batteries,turn on the unit,press manual,enter the channel number,press manual,enter the frequency you want,press E enter,if you make a mistake, press CLR to erase. Get the frequency,s for your state at ..hope this helps..
Posted on Mar 19, 2010
How can i reach far away but not a couple miles away?
you may try getting you a bigger antenna...or an outside antenna..
Jul 10, 2011 | Uniden BC350C Base Scanner
My scanner is new but squelch drowns out the transmission
Hi, my name is John. Welcome to FixYa. you might try a different location, the station might be to far away, extend the antenna all the way out, mack sure nothing is blocking it. Good luck and thanks for choosing FixYa...John
Nov 02, 2010 | Uniden BC350C Base Scanner
I have a unidenbc72xlt scanner--I live in a rural area and reception is terrible. when i get to city(about 25 miles away) it works good but at home is terrible--any solutions
Your ONLY solution is an external antenna. The best scanner is only as good as the antenna that feeds it. A discone would be the best, but a less-costly vertical would probably do a good job for you. The least costly, and least effective solution would be an indoor antenna - the ones enclosed in PVC pipe do a fair job. If you can't mount the antenna on your roof, a balcony or an attic will usually work fine. As a last resort, you can always set up a vertical inside a closet. eBay is a good source for scanner antennas, and you might also try
For a comprehensive database of active frequencies in your area, visit:
Dec 30, 2009 | Radio Shack Pro-97 Handheld Scanner
HELP with bc350c scanner, won't pick up feeds
Sounds like an antenna problem. Remove your back-of-set antenna and see if reception changes. If it's the same or nearly the same, check the antenna solder connections inside the set and resolder if necessary. You might also try an outdoor antenna or one of the indoor/outdoor units that's enclosed in PVC pipe. These are fairly inexpensive and can be found on eBay or other sources.
Nov 28, 2009 | Uniden BC350C Base Scanner
When my scanner is on all I hear is static . I can hear pick up on it but inbetween it is all static
That's a hard one to answer without seeing the scanner and not knowing the location where you're operating it. Assuming that you've already adjusted to squelch to "mute" the scanner between transmissions, you might be in a weak signal area that requires something better than the back-of-set antenna that came with the scanner. Check eBay and other sources for inexpensive ($15-$30) indoor/outdoor antennas that are enclosed in PVC pipe. They can drastically improve reception.
Oct 28, 2009 | Uniden BC350C Base Scanner
I need to sawder the antanna back on is there a certain way
if the telescopic antenna is broken you cant solder it, but you can buy a replacement antenna,some scanners have an antenna that just screws into the circuit board through a hole in the top of the case,or you can get a telescope antenna that will attach to antenna jacks on the back of the set if it has those, which im sure that model does. Antenna jacks came come in several types , one is called a BNC which just pushes in and turn about half a turn to lock in place,also some scanners have the type of jack like the back of a car radio, with those you just push them in and you can find telescopic antennas with the auto type plug at a 90 degree angle that will work fine.If you need more help let me know
Jan 07, 2009 | Uniden BC350C Base Scanner
Need telescoping antenna for Bearcat BC350A scanner
hope this helps.....Good Luck!
Dec 15, 2008 | Uniden BC350C Base Scanner
Scanner will not scan to printer.
try to check ur scanner settings on the control panel of your coouter it might not be added to your hardware that's why....
Feb 26, 2008 | Samsung SCX 4200 All-In-One Laser Printer
Uniden bc 350a
Hi, Is you CB gear grounded to an "earth" ground? Also try moving the scanner around, away from the CB coax, as your probably getting stray RF from there. I've run 100watt with my scanner 5ft. away from it and no problems for the last 6 years,,
You are using good quality coax, aren't you? Cheap coax leaks like a soaker hose. Hope this helps you,, Mechanic
** and preaching about ham radio does not solve this persons problem!**
Jan 31, 2008 | Uniden BC350C Base Scanner
Scanner error
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
Sep 24, 2007 | Canon PIXMA MP160 All-In-One InkJet...
Uniden BC350 Base Scanner Logo
143 people viewed this question
Top Uniden Radio Communications Experts
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
