Question about Compaq Presario 5005 (470014-507) PC Desktop
WHEN I PLUG IT IN THE SCREEN SHOWS THAT THERE IS NO VGA PLUGED IN. WHAT CAN I DO TO FIX THIS?
  • 570 Answers
Please just follow the below steps fix your problem
1. Check for loose electrical and VGA cables. Remove the electric cord from the back of the monitor, then put it back in place. Remove the VGA cable from the computer and monitor and put it back in place. Make sure the connection is tight. If you're using a cable extender, remove it.
2. Plug the monitor's electric cord into a different outlet. If you're using a UPS or surge protector, plug it directly into a wall outlet.
3. Attach the monitor to a different computer. If the monitor still doesn't work, replace the monitor's cable. Make sure the cable is less than 5 feet long. If it still doesn't work, the monitor will need to be replaced or repaired. If it works with no problem on the other computer, troubleshoot your video card.
4. Unplug your computer from the monitor and power outlet. Remove the cover. Pull the video card out of the slot on the system board. Push it back into place. Be sure the connection is secure.
5. Put the CD that came with your video card into your computer's CD-ROM drive. Follow the directions to reinstall the video card drivers. Download a new version of the drivers from the manufacturer's website if necessary.
6. Right-click a blank area of your Desktop. Choose "Properties" from the display menu. Click the "Settings" tab. Try different screen resolutions to resolve the problem.
7. Determine whether the problem is caused by electrical interference. Electrical interference will make the monitor appear jumpy or wavy. Move any speakers, radios, fans or other items that can cause electrical interference away from the monitor.
Thanks.
Posted on Oct 02, 2010
I have HP Pro3000MT, and it has vga and dvi port. I want to use dual monitor for this pc. the monitor are HP LCD and it only has vga input. first i use vga port, secondly i use this dvi cable to connect to...
you need a dvi to vga adapter not a dvi to vga plug and you must also go into your graphics card setup catalyst control center if its ATI Nvidia Display manager for Nvidia if you boot the computer with it pluged in and you can see the boot screen on bolth displays then its an os thing just right click and select the display manager the activate all display's through the managers
Apr 01, 2011 | HP SmartBuy Pro 3000 MT Pent Dual Core...
DGM screen monitor problem ''22
the light blinking makes me think that the moniter is going in to sleep mode...try turning the computer on while the moniter is not pluged in(pull the blue vga cable) wait a bit then move the mouse around then plug the vga coble back in...(while the screen is already on)
Jul 09, 2010 | Computers & Internet
My ipod touch turns on and shows the apple sign and cuts right back off i pluged it up and it did the same thing and i went to i tunes and pluged it up and same thing happend
Hold the power button and home button for 10 seconds to ensure the device is off. Let go.
Hold the home button down, plug in the ipod to the computer, after the screen changes to the itunes plug screen, let go of the home button.
The ipod will now be in recovery mode, and you can attempt to perform a restore within itunes.
If the restore fails, and the ipod screen stays black, this means the battery is dead and must be replaced. If you replaced your battery and this still happens, then your logic board has gone bad.
Aug 19, 2009 | Apple iPod touch Second Gen (8 GB,...
No picture on my tv from cctv camera
it is neither clear what sort of output your cctv cameras produce, nor what sort of input your dvr accepts. but, for the most part, dvrs record digital tv signals, whereas cctv cameras output analogue signals. so, even though you may be able to plug a cctv camera "straight" into a tv via a scart connector, it is unlikely that any scart connectors on a dvr have the necessary circuitry to accept such signals.
May 24, 2009 | Sharp Cameras
Hooking a PC to your laptop's screen
Unfortunately you cannot use a laptop screen to view output from other computer sources. As you are surely aware, you may plug another monitor into the VGA plug on the laptop to view the laptop's output, but the plug is only for the laptop's output.
Nice thought, though.
Sirwriter
May 23, 2009 | Dell XPS M1330 Laptop
Trying to connect my laptop to Hdtv with vga wire?
Ok, 14-pin is for really OLD VGA. Your cable will simply NOT work. Find a S-VGA cable (15-pin) and you are on your way to fame. By the way, make some room trashing that old cable.
Apr 18, 2009 | HP Pavilion dv9700t Notebook PC
LG 710s monitor problem screen turns green
Your AUTO settings button is stuck in! Try tapping on it a few times. Otherwise you may have to take the frame apart so you can get at the button.
Dec 28, 2008 | Amptron AMV 17V5 17" LCD Flat Panel...
LINES ON SCREEN.
Hi
there are very few troubleshooting you can do with the monitor
1.) Powerflee: unplug both the cables of the monitor from the computer and power socket. then press and hold the on button for 15 seconds this will release all the static current..
if this does not work then doa Monitor on self test.. just conect the power cable of the monitor and make sure the VGA (Blue plug) is Not pluged in with the computer. switch on the monitor and you will get a message either a question mak or No Vga cable see the color if itn ios not coming right then the monitor has gone bad
thanks
AJ
Jun 04, 2008 | HP vs15 15"LCD Flat Panel Monitor
Compaq Presario 5005 (470014-507) PC Desktop Logo
44 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
