Question about ViewSonic VX2235WM Monitor
I have a blue vertical line running all the way through from top to bottom of my Viewsonic VX2235 computer monitor. Any ideas? CK
  • 11,361 Answers
That can be bad TFT driver on the LCD panel assembly, new panel will be needed it, you can check the connection between the logic board and the LCD panel first. Also inspect the caps in the power supply as well. read more here:
http://s807.photobucket.com/albums/yy352/budm/Viewsonic%20VX2235W/
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Please post back what you find.
Posted on Oct 02, 2010
    Problem Solver:
  • 15 Answers
Is there high magnet speakers behind the monitor pls replace
The bottom of my screen is black and blue starting solid on bottom and sides for about an inch give or take then gradually becomes spotted balck with blue background and has a pink line running vertically...
I suggest either trying another monitor on the computer with this problem or plugging the monitor into another computer.
That will isolate the fault to either the computer or the monitor.
Nov 15, 2017 | ViewSonic VX910 19" LCD Monitor
Hey I have a viewsonic VX2245WM and my problem is that when I turn my computer on the monitor light goes red-ish like a red light that is starting to fade away and the screen is completely black like its...
Almost the same chassis as VX2235.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed VIEWSONIC monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.badcaps.net
May 19, 2010 | ViewSonic VX2245WM LCD Monitor
I have a viewsonic LCD VX2235 and it just went black. It switches from the green light to amber light with no picture but you can see a faint flicker in the background. Please help
Look for bad caps with bulging tops as shown in my pictures here: http://s807.photobucket.com/albums/yy352/budm/Viewsonic%20VX2235W/
They should be replaced as a set (6 black cases, 2 brown cases). Use PANASONIC FM or F series from Digikey.
Apr 20, 2010 | ViewSonic VX2235WM Monitor
My VX2235 sometimes goes blank (black) for 2-3 seconds, then back on. This has happened thru 2 M/Bs and 3 Gr.Bds. Happens more on digital connection than on analog. Any ideas?
Common failure in this monitor is bad caps in the power supply or lamps, you need to open it up, post back what you see inside so we can guide you further, see example of failed VIEWSONIC monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Feb 25, 2010 | ViewSonic VX2235WM Monitor
"Lines" or irregularities through the monitor image display
Check power supply section for bad caps with bulging top first, may be a sign of failing power supply: http://s807.photobucket.com/albums/yy352/budm/Viewsonic%20VX2235W/
Jan 27, 2010 | ViewSonic VX2235WM Monitor
I have a ViewSonic VX2235. No picture at all
sounds like a burnt or a cold solder around the TRANSFORMER section of the power supply , I suggets if your handy w/ tools to open the monitor and inspect the PC BOARD for any burnt or cold solder THAT not making the connection , hope it helps AJ
Nov 09, 2009 | ViewSonic VX2235WM Monitor
Vertical blue line has appeared in the middle of the screen
Hi, is the blue line from top to bottom or from left to right?
is it on all inputs all the time, or just one input sometimes?
if its there all the time all inputs sounds like a bad panel, probably damage to the tiny ribbon cable on the edge of the screen, probably not user fixable, Viewsonic does warranty there monitors for 3 years by serial # though worth a phone call. good luck
Jul 31, 2009 | ViewSonic Televison & Video
Black screen
Don't let the computer turn the monitor off. Go into control panel and click on power option. don't let the computer turn anything off and disable hibernation if on. go to screen saver and have it come on in about 30 mins.
May 27, 2009 | ViewSonic VX2235wm LCD Monitor
ViewSonic VX2235WM Monitor Logo
114 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
