After copying, printer will no longer print from computer
  • agaliana Oct 18, 2008
    When I turn the printer on, it's automatically set to "copy" and I can't turn that off in order to print from my computer.
How to copy long bond paper to fuji xerox wokcentre 3119
Posted on Sep 19, 2008
Brother DCP-7040 Laser Printer Issue
With the computer off will the printer still make a copy? If the printer can still make a copy stand alone, then try deleteing the printer and reinstalling the printer driver.
Mar 31, 2014 | Brother DCP-7040 Laser Printer
HP DESJET 694C - NO LONGER PRINTS IN COLOR - TRIED SEVERAL CARTRIDGES, CLEANED PINS, ALIGNED AND REALIGNED - NO CHANGE.
Did you checked Printer Settings? May be option is check Marked that "Always print in Gray Scale" if yes then remove check mark.
Disconnect printer from computer and Try to press resume copy or start print button for 5 seconds to start Test Print directly from printer. it prints in color then there definaly a setting problen in your computer printer settings.
Last Option is to check or replace print head.
Mar 09, 2010 | HP Office Equipment & Supplies
After a paperjam my printer will not print fom the computer and i no longer have the software to reinstall. I have checked the connections and the printer work to make copies or fax but will not print from...
Check in the control panel and go to printers. Then make sure your printer is still set as default printer. If it still is try restarting your computer. At times even though these are elementary things these are usually all it takes to repair minor printing problems.
Sep 30, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Dell All in One 926 won't print from Vista
Go to the control panel and select printers.See if it there and set as the default printer.
Jun 18, 2009 | Dell 926 All-In-One InkJet Printer
Can no longer print i tried it all but it will not print
you need uninstall all the existing printer driver and then restart your computer and install the driver again....because there is a corrupt files on the driver you currently using..^_^..
thanks ..
May 26, 2009 | Dell 924 All-in-One InkJet Printer
HP Laserjet 2300 printing 5 copies
Friend,
There shouldn't be any need for a parallel-to-USB device, since your printer has both ports - and you could use ONE of the ports for printing. One, since two ports does NOT mean that the printer can serve two PCs simultaneously. On startup, it determines which port is active and "forgets" the other.
So I would have gone for either a parallel cable (IEEE 1284 standard, no longer than 10 feet) or a USB cable, running the cable directly from PC to printer.
If there's a need for several users to access this printer, I would either have shared it from my computer (where it's physically attached) to the other users in the network - or, purchased a jetDirect network card for the printer. With a JetDirect card the printer is accessible for all users over the network regardless of which computer is switched on.
Hope this clarifies and gives an answer to your question.
//Al
Mar 10, 2009 | HP LaserJet 2300d Printer
Hp2400 will scan, copy, fax, but not print from computer any more
sir,
u need to install the drivers and software for ur printer. if u have already installed try to uninstall and install them...
click this link for drivers
also this
thanks
good luck
Dec 13, 2008 | HP PSC 2410 All-In-One InkJet Printer
Dell Printer will no longer communicate
RELOAD DRIVER FROM DISK THAT CAME WITH YOUR PRINTER.
IF YOU DONT HAVE A DISK DO INTERNET SEARCH FOR DELL PINTER DRIVERS DELL 924
YOU NEED TO KNOW WHICH OPERATING system you are using Windows 98,xp ETC.
DOWNLOAD DRIVER INSTALL AND HAPPY PRINTING.
Oct 17, 2007 | Dell 924 All-in-One InkJet Printer
100 people viewed this question
k24674
jasbo
jasbo
