Question about Acer Aspire One PC Notebook
Can you adjust the screen brightness to brighter? ACER ASPIRE ONE?
  • 10,865 Answers
Hello. yes. to adjust the screen brightness, go into the control panel and find the brightness or contrast adjustment. Joe
please rate my answer as 4 thumbs up. thanks.
Posted on Oct 02, 2010
  • doogen77
    doogen77 Jun 08, 2012
    no screen brightess on the control panel........ so can't do that
4 Suggested Answers
  • 33 Answers
SOURCE: acer aspire 5735 screen brightness
How old is yor laptop is it still under warranty as I think it may be the back light, There is 2 small fluro tubes top & bottom of your screen & they may be on their way out it can me expensive to fix
Posted on Jun 15, 2009
Geekman
  • 32281 Answers
SOURCE: adjusting screen brightness
If you hear the hard drive spinning and you think Windows is working but you can't see an image or a very dim image then :-
You could have a defective screen - a defective inverter or a CCFL lamp or simply the video cable needs reseating. After reseating the video cable and the problem is still there then :-
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display or appear black.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Posted on May 20, 2009
  • 111 Answers
SOURCE: how do i fix the screen brightness in vista on a acer aspire 3690 BL50Laptop Fn keys for brightness in vista on a acer aspire 3690 BL50
try to install luanch manager. you can download it from acer website.
Posted on Sep 26, 2008
How do i change the brightness
Hold the Fn Key and repeatedly press the left or right arrows depending on whether you want it brighter or dimmer.
Jun 17, 2014 | Acer Aspire One 521 532H 533 D260 NAV50...
How do I make the screen brighter on my Acer Aspire 5100 Laptop?
Try using keyboard combination Fn+right arrow. If this doesn't help right click on battery icon on taskbar, select Adjust screen brightness, then move slider for Screen Brightness to the right.
Sep 05, 2011 | Acer Aspire 5100 Notebook
How do I darken my screen ..it is to bright - acer -aspire 5100. Where is the Fn key located on the keyboard?
Hi
Fn key at the bottom left between the Ctrl and Winkey
To adjust the brightness, hold the Fn key and press the cursor key - down darker, brighter up
Sep 20, 2010 | Acer Aspire 5100 Notebook
How can i make my screen brighter?
usually there are keys that you press in conjunction with another key like the Fn key and a key that looks like a bright Sun, or a Dark Sun, shape, on one of the keys usually on the number keys on top row under Function keys. So you press the Fn key and at same time. tap the Bright sun key, and it will step up in brightness, plugging in the adapter also makes it brighter too.
Mar 01, 2010 | Acer Aspire 3000 Notebook
Acer aspire 3000 display dim can i make it brighter?
You should be able to adjust the screen brightness using the "FN" key and the keys that have a sun on them with a arrow up and down. Or you can right click on the desktop and change the screen's brightness in the display properties. And sometimes laptops are set up to automatically lower the brightness when the power properties are set to power saver...like when running on batteries only and no ac power connected.
Nov 23, 2009 | Acer Aspire 3000 Notebook
How do I adjust brightness on my acer 5570Z
Use the special function keys to adjust screen and speakers:
<Fn> + <→> = brighter
<Fn> + <←> = dimmer
<Fn> + <↑> = volume up
<Fn> + <↓> = volume down
Jul 10, 2009 | Acer Aspire 5630 Notebook
Acer aspire 5735 screen brightness
Jun 15, 2009 | Acer Aspire 5630 Notebook
Screen brightness
You have a "FN" key in the lower left section of your keyboard. There should also be other keys with ink the same color as the FN. Look for one that has a sun and upward pointing arrow. Press both and your screen will get brighter.
If that does not work then your video inverter is starting to go bad and will have to be replaced.
Dec 10, 2008 | Acer Aspire 5100 Notebook
How do I make my acer aspire 3000 screen brighter
Most monitors have adjustment buttons to align the screen or brightness and contrast Etc. If the buttons are not visible to you on the front of the Monitor, feel and look under the monitor window in the front and see if they are there. Good Luck.
Oct 30, 2008 | Acer Computers & Internet
Screen is too dark
<Fn> + <→> Brightness up Increases the screen brightness.
<Fn> + <←> Brightness down Decreases the screen brightness.
Jun 05, 2008 | Acer Aspire 5100 Notebook
Acer Aspire One  PC Notebook Logo
1,096 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
