Question about Sylvania Dx Antenna Digital Atsc TV Smart Antenna
How can i get my 2006 sylvania tv to switch to antenna mode to hook up my hd antenna
2 Suggested Answers
SOURCE: how can i switch my
kindly check the remote settings and your manual for it. Select Menu and click Settings, then sort it out until you see the option Wide so that you can select it to widen your screen..
Posted on Sep 06, 2011
I want to hook up my old 1992 Sylvania TV to HD Antenna, but I cannot figure out how to scan or auto-program the channels. Model SRC1351 101
Hello... Somewhere in the same menu as the Air/Cable setting should be an option to scan for channels. It might be called Auto-Program, or something similar. The bad news is that: "On June 12, 2009, the Federal Communications Commission (FCC) mandated that all U.S. based television signals must be transmitted digitally." Since your TV was manufactured in 1992, it isn't capable of detecting or displaying digital channels. If you're really fond of the TV, you will need some sort of conversion box. If you can afford to, I'd recommend buying a new TV, and get the extended warranty. I hope this helps!
Nov 26, 2017 | Sylvania Televison & Video
How can I switch channel from Ant. Over to TV with no remote on a 2006 Sansai tv set
Every TV has buttons that can do all a remote does, check the user manual or google the make and model. user manual for instructions,
Nov 10, 2016 | Televison & Video
No picture or sound
You need a antenna HD for air signals. I hope this helps. leave feedback and thank you
Jul 11, 2016 | Televison & Video
How do I get my Sylvania model 6620LCT to imput mode antenna for clear tv. I don't see the option in the menu
You need a digital to analog converter box to watch TV from any antenna since the switchover to the broadcast of digital only TV signals.
Feb 11, 2016 | Sylvania Televison & Video
How do you hook up regular coax cable to the TV?
You simply need an "F" connector to "Belling-Lee" converter. about $4.00. At any Radio Shack, Antenna shop. This screw onto the end of the existing antenna connection & makes it so you can plug it into the Socket at back of set.
I have included a link that has a picture.
http://cgi.ebay.com/1-Coax-TV-Adapter-Connector-PAL-Male-to-F-Female_W0QQitemZ110386773163QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item19b3907cab#ht_683wt_1139
Feb 16, 2010 | Sylvania 6842PE 42 in. HD-Ready Plasma...
How to un-Dish a t.v.
In the USA broadcasts are not analog any longer they are digital. So if you have an antenna hooked up to your TV you will need a digital converter hooked up to your input wire (from antenna) and then an output from the converter to the TV. Most satellite and cable companies use RG56 cable which will work fine with an antenna set up as well, so cabling should not be a problem.
Make sure you set your TV mode (input or source) to the proper input where you have hooked up the cable to the TV as well. It is unimportant which input you use, but the TV has to have it set to the same one.
If you are outside of the USA, the above should be the same because broadcast over the air and antennas set ups are universally the same in nature and design. I hope this helps and good luck!
Feb 02, 2010 | Televison & Video
Keeps saying no signal once plugged in to tv
you may be in the antenna mode, your T.V. is searching for singnal for an antenna. Switch your settings in the menu to one of the following
CABLE,HD Input,VIDEO 1,2,3.
try that
Dec 10, 2009 | Televison & Video
I have a jvc tv model av27530. Disconnected cable box b/c going
You probably have to find your original remote to the set and go through setup in your menu. On most sets, there will be a menu item which will allow you to switch from Cable mode to Air mode. If you have no Cable connected, then you must set tuner in Air mode.
If you are using an external device to run on channel three, then try this:
Make sure device (rather it's a vcr or game console), is hooked up to your Antenna Input connector. Also, some of these devices will have a small hidden switch on back that says 3 and 4. Move the switch to 3 position. Turn on device. Go into TV menu and do a Channel scan. This should auto program any device hooked up to the TV antenna input jack to channel three.
Keep in mind that you may not receive anything by Feburary of this year without an HD converter box to tune in channels with and outdoor antenna.
Jan 09, 2009 | JVC AV-27530 27" TV
HD Hookup on Dish Network 2nd Location
In order for you to receive HD broadcasting you must have a HD-TV, otherwise you wont get the picture in HD. Also I should point out that you need to make sure that the signal itself is being broadcast in HD.
Apr 28, 2008 | Mitsubishi WT-46809 46" Rear Projection...
Electronics - Others Logo
Top Sylvania Electronics - Others Experts
Are you a Sylvania Electronics - Other Expert? Answer questions, earn points and help others
