Question about Maytag Washing Machines
Is leaking water at the back and running in the floor the hoses are tight drain pipe is in right
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 113 Answers
Here's what I've seen. Water will be full, machine goes to spin/drain and expects the water to be pumped out as predicted. If pump is clogged, the pump cannnot pump out water quickly enough and the spinning causes the water to spill over the back of the tub, between the tub and balance ring. The balance ring is never sealed tightly to the tub so water will get through. Fill the basket with water, extra high, hold lid switch down, and see if it drains out fast enough so water doesn't spin out. If this is the case, pull pump, dislodge debris.
Posted on Oct 02, 2010
Water leaked out from under washer while it was running. No leaks visible from hose connections at hose bibs, nor where water supply lines (hot and cold) thread on to the top right at the back. No leaks...
I would open the door and puled up the bottom. Part were that fan twister spins on the bottom.. and check that the ida filler is not gonskie or may be blokidge right there So water would v come out. And clean it all there. It prolly never been done ????. Hope that helps ?? Tony
Apr 19, 2017 | Kenmore 24732 Top Load Washer
My whirlpool ultimate care 2 washer was leaking underneath while running, I removed the back panel and dropped the drain hose to the floor and extended it out the door to the yard and while filling the tub...
The drain hose must be at least level with the top of the actual tub in the washer. The water pump is only bad if it is leaking. If it is leaking from the front you either have a cracked outer tub, but it sounds like your water pump, easy to change out just get the model # and order it through an appliance parts distributor. The cost is about 40 to 50 bucks. good luck!
Aug 20, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Periodic water leaking from Kenmore Elite K701
hello Adrian. I am suspicious that the standing drain pipe behind your machine may sometimes over flow. To find out, pack some dry newspaper around the drain hose where it enters the drain line behind the machine. If that newspaper gets wet you will know that the drain is sometimes overflowing. If that is the case, snake that drain or force a garden hose down it and run hot water thru it for ten minutes. J.
Jul 05, 2010 | Kenmore 24 in. 17482 / 17484 / 17489...
My washer stopped during the spin cycle. Now I can get it to fill with water But aggitate and spin it just makes a noise and the tumbler is locked up tight
Your shaft coupler / motor coupler has likely broke. Not too hard to fix yourself, but you will have to remove the water from the washer first.
Remove the clothes, place them in the bathtub. Roll a garden hose from the washer to outside where drain water won't matter. Tape the garden hose to the drain hose, and lower the drain hose to the floor. Water will flow through the garden hose outside. Turn the washer over, follow directions supplied with new part, and replace the motor coupling. When finished, reorient the washer, remove the garden hose, place drain hose in the drain stand pipe. Run the washer through a couple of full cycles, then rewash the clothing.
Jun 11, 2010 | GE WBSR3140DW Top Load Washer
Maytag MDB4621AWB0 The pump runs but nothing comes out the drain. The hose is disconnected, so there in no problem outside the dishwasher.
This is a typical Anti Flood system activation. This system activates when water leaks onto the floor of the machiene due to a leak fault (pipe/hose clamp/ partly blocked pipe). The machiene automatically switches to pump out mode and stops water inlet. The anti flood system is a polystireen float / micro switch at the base of the machiene floor. Dry the floor and drectify the leak and it should work.
Jan 24, 2010 | Maytag 24 in. MDB5600A Jetclean II...
LSR8233JQ0Washer won't fill
The water is syphoning out the drain hose.
Many times when the stand pipe is backing up someone will seal the washer drain hose to the pipe to avoid overflow of the stand pipe.
This causes the water to syphon from the washer.
Or the opening for the stand pipe is just big enough to put the drain hose in and is to tight causing the syphon.
Putting the drain hose to far down the pipe can cause a syphon also.
Jan 20, 2010 | Washing Machines
Ford Fiesta 2003 1.3 If I run the aircon water leaks onto the floor of the drivers side (by the pedals, alot of water.
In the dashboard,set down low is a driptray.It collects water that comes off the aircon.It has a hose (sometimes 2) that drains the water out of the car via the firewall so it drips onto the road.This is blocked or the tray has a buildup of gunk.The hose is about 1/2 inch thick.If you lay on the floor where it leaks with a torch you should find it.Or look in the engine bay,just to the left or right of centre(which side leaks?)and backtrace it into the car.You may find the inside hose has fallen off allowing the water to drip inside.Hope this helps you
Jan 01, 2010 | 2007 Ford F
The water fills and drain from the bottom of the washing machine. Have checked all the pipes no problem. Please advice
front load or top ? drain hose must be elevated to 36 '' 34 min. if hose on floor it will not work .. needs stand pipe . if its leaking inside you may have a hose off . reinstall and wala it works .. mm hope some of ans work for you ..
Dec 03, 2009 | Ovens
Water leaking on floor from my front loader
it sounds like it's a prob from the water solenoid to the drum and/or the soap box there is a hose that runs between these items to get the water into the drum
Jun 11, 2009 | GE WSXH208A Front Load Washer
Washer runs over
I would advise you to check the outlet hose for an obstruction at the end it discharges the water, there could be a partial blockage, which can result in the water filling up the outlet stand pipe and overflowing.
It would not neccessarily do it every time., and make sure the outlet stand pipe is the right size as the hose has not to be stuck in tight.
Plz rate this solution.
thanks.
Jan 02, 2009 | KitchenAid KAWS850LE Top Load Washer
Washing Machines Logo
70 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
