Question about Memorex Computers & Internet
My cd-room receives power but it won't work - Memorex Computers & Internet
  • 39 Answers
First try to re-install the driver for the cd-rom. If still the same so the lens of your cd rom broken.
Posted on Oct 02, 2010
I moved the box to another room and now I get a message light and cannot get the power button to work
Especially with newer systems (ie MoCA) you can't just move a receiver from one room to the next, they are set up more like a computer network with one receiver performing most actions and other receivers accessing the main receiver for content. Find the area where the cables all meet and make switch the cable that is going to the room the receiver was in with the cable going to the room the receiver is. If you can't tell which cable is which, you can get cable tracers for a few bucks, but it may be easier to call your provider for a technician.
Feb 28, 2015 | Televison & Video
I have a Tivoli Music System radio/CD player. When it is moved to another room and plugged in at the new location, it won't run! The screen lights up a little, but has to sit for 30-40 minutes bef
The Tivoli Music System must be left without power for a minute (60 seconds or more) anytime it is unplugged, before being plugged in again. If you observe this little rule when changing rooms, it should turn on and be usable immediately (after ensuring it has been at least a minute since it was last connected to power.)
Nov 18, 2012 | Tivoli Digital AM/FM/CD Hi-Fi Music System...
My remote won't work at all.
If no remotes work it is likely the remote receiver (ifrared and at front of set) is either dirty (lens) or bad.
A hint here is try original remote right up against the receiver--if works receiver is bad.
Note: original remote can be tested by a shop or even with most digital cameras--in a dark room the remote pointed at the camera and the lcd display will flash faintly when buttons on remote are pressed.
Apr 22, 2012 | Toshiba MV13M3 / MV13M3W 13 in. TV/VCR...
Just bought a brand new jvc cd receiver and it won't turn on.
Please check if the wiring was done correctly. check the ground the all time +12 volt and the swittched +12 volt. If the set does not power up then I suggest that you MUST take the warrranty claim being a new set. Refer to the dealer before you can open the player so as not to void the warranty
Jul 02, 2011 | JVC KD-G801 CD Player
When I turn the system on the CD Drawer keeps going in and out repeatedly by itself. When I load a CD it won't recognize it and won't play it and keeps going in and out opening and closing by...
Hello
Check all connections, such as from player to amplifier or receiver and receiver to speaker. Check and clean contacts on RCA jacks and cables and try a different input on the amplifier or receiver.
Clean the lens. Use only a special CD lens cleaner and follow the instructions carefully.
Check the traverse assembly (the metal rod that the laser travels along and the gear that drives it) if CDs aren't recognized or won't play, frequent skipping occurs at random, CDs randomly get stuck in one spot, the player can't find tracks correctly, or cleaning the lens doesn't work. Dust and lint may be interrupting its function.
Have the laser-head assembly checked by a repair person if the traverse assembly seems intact and free of debris.Look for broken plastic parts, such as gears and clips,look for loose or broken internal connections.possibly have gears and belts replaced.
Jun 09, 2011 | Audio Players & Recorders
My computer won't turn on properly. It keeps saying disk error press control alt delete. When I do it just says it again and again. It won't load and turn on.
First you should check if there is any disk on your cd room, if there is any disk you should remove the disk from the cd room, if there is no disk the possibility is your hard drive getting error
Press f2 or delete to enter your bios set up system
Look for boot menu
Set the first boot as a HDD and the second boot as cd room and disable the third boot
Save and Exit the setting
if your computer still won't load you need to reinstall your windows
insert windows cd and go to set up again by pressing f2 or delete button
Set the first boot as cd room then the second boot as HDD
Save and exit the setting again
When the message press any key to boot from cd appears you should press the space bar or another key
Then just follow the instruction of formatting
Jun 03, 2011 | Acer Computers & Internet
Multi room will not play any digital input, just analog. I.e. Video 1 when analog connection plays in multi room, but optical 1, when set as input for vid 1 will not play in multi; works fine in main...
I have a Marantz 7.1 AV receiver (sr5500) and I run a 5.1 set up for home theatre and use the 2 extra channels to run a pair of outdoor stereo speakers... When I first set it up I also found I could not get a digital signal output, only analog, after reading the manual(!) I discovered that it can only output an analog signal...so I have used the phono outputs on my blu-ray player into the CD input of the AV amp and play CDs outside through this and it also outputs the optical digital signal into the AV amp through the DVD input...my iPod also plays through a dock and it's analog output to the speakers outside through another (CD-R) anolog input on the amp... Hope this helps
Dec 24, 2010 | Harman Kardon AVR 335 Receiver
Fan is Erratic
Ceiling fans with wireless remote controls have an electronic receiver installed in the fan, which controls the light, dimming, and fan speed. Sometimes the receiver goes bad and needs to be replaced. If you have had any power outages or power surges, they may have fried the receiver. I've noticed that my ceiling fan light turns on when the power is restored after a power outage. Now, whenever my power goes out, I shut off the light switch that powers my ceiling fan so It doesn't experience a surge to to the controller when the power comes back on. I've purchased new receivers on eBay and Amazon to replace my blown remotes and receivers.
Sep 07, 2008 | Hunter 22451 The Brookline Brushed Nickel...
No subwoofer output
1. Try twisting the RCA plugs from CD player and see if they are not connecting right.
2. Replace the cable from the Cd player to the receiver
3. Try a different input
4. Try a different CD player
See if any of those solve your issue. Replacing the cable worked for me one time
Aug 30, 2008 | Yamaha RX-V995 Receiver
Computers & Internet Logo
20 people viewed this question
Top Memorex Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Piyal Perera
Piyal Perera
Jax Planet
Jax Planet
Are you a Memorex Computer and Internet Expert? Answer questions, earn points and help others
