Question about Bissell 8910 ProHeat Clear View Upright Vacuum
My Bissell model 8910 pro heat will pump solution or water for like the first couple times you pull the trigger as you can see the mixture window spinning. After that it stops spinning and nothing else will come out until you turn the machine off, and restart. Then again same process works for a couple trigger pulls then quits.
  • Bissell Master
  • 43,501 Answers
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
Posted on Oct 02, 2010
  • brianp66 Oct 03, 2010
    Well I went through all the directions and service info. Didn't really find anything relevant to what my machine is doing, so I decided to install all new hoses since the ones on the machine looked really bad. After doing this when I started the machine and hit the trigger the fluid would never start coming out or fill all the hose with water. So i am assuming that this means the pump is bad. Could someone confirm this
The sprayer wont work
my bissell pro heat model #8910 leaks the water out of the tank whenever i set in in place , HELP?
Apr 13, 2011 | Bissell 8910 ProHeat Clear View Upright...
Water and solution do not dispense.
heatman101
wrh
Jun 30, 2010 | Bissell 8910 ProHeat Clear View Upright...
Carpet not getting moist
heatman101
eyrye
Mar 09, 2010 | Bissell 8910 ProHeat Clear View Upright...
Bissell proheat model 8910 water will not come
  • check pump belt
  • seat tank properly
  • check tank filter
i have repaired many of these and found that 90% of the time its the pump! #41 on diagram < click
9% its the heater clogged up #65 on diagram < click
1st check the small problems i wrote above
if all else seems fine start by removing the heater and disconnect the hoses from it. blow through one end of the heater (should be no restriction)
Oct 08, 2009 | Bissell 8910 ProHeat Clear View Upright...
I just replaced the pump on my bissell proheat and now it spray's water all the time how do i fix it
The pump wiring may not have been reattached correctly.
Sometimes the trigger can get stuck, so try working that back and forth a few times. Power cycle the machine (unplug it) and try again.
Mar 30, 2009 | Bissell 8910 ProHeat Clear View Upright...
Bissell 8910 ProHeat Clear View Upright Vacuum Logo
237 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
