Question about HP Compaq Presario SR2010NX PC Desktop
No operating system installed or partition corrupted. Press 'R' to perform a full PC Recovery.
  • HP Master
  • 8,404 Answers
Check ... do you have a non booting CD in the CD drive or do you have a floppy disk drive that may have a non boot disk in it? Remove them.
Your operating system is corrupted OR the boot sector of your disk is failed or failing ... maybe your entire hard disk is failing ...
Try the press "R" to try to recover ... which will fix the corrupted files. If it is a hardware failure ... your computer wioll not 'recover'. If that is the case ... you will have tp put in a new drive.
If you have valuable files on the drive ... you may want to get professional help with this. There is that possibility that you can get a new drive and use the preent drive as a slave long enough to get your files off safely.
Posted on Oct 02, 2010
I have an HP Compaq tc4400 that I got from an old friend that had no use of it . but when I turn it on it says Non-system disk or disk error replace and strike any key when ready but I dont have a disk ....
It sounds like there's a problem with Windows (assume that's the operating system it used to have). I think you'll need to get a Windows install disk. Installing Windows is actually not that hard, and it sounds like you've got nothing to lose.
If you don't have access to a copy of Windows, why not try out Windows 8 - http://windows.microsoft.com/en-AU/windows-8/release-preview
I assume it'll only be free for a few more days as Windows 8 will be released in under a week now.
Hope that helps.
Cheers,
Derek.
Oct 21, 2012 | Computers & Internet
Laptop start up repair
The hard drive has issues or the window files are corrupted, press ALT and F10 together this will access your recovery partition for a full install of your operational system to factory setting, if this fails use your backup recovery disc if available, now! if the CD does not work have the hardware checked out for possible replacement.
Apr 23, 2012 | Acer Computers & Internet
Sony laptop model# pcg-8112L. if press on power bottom. laptop screen come on. but laptop not start up. screen only show ing on a message" operated system not found". that " s message...
Boot into bios to verify system can see the hard drive. If system shows drive in bios and you are using windows xp or later try using the recovery console options by tapping F8 repeatedly to enter menu. , if you have one. If no recovery console...use either the recovery disks created by the system administrator or the original install disk to attempt a repair option on the boot of windows.
Your hard drive might have damage or the OS my be missing or corrupt.......you might have to re-install the system.
May 24, 2011 | Computers & Internet
Key note book vaio cr failed to start because some recent hardware or software change might have screwed it up, any way to solve ? Without a windows installation disc?
Hi kevin_yomama,
This issue may occur due to any Software or Hardware changes in the Computer. Restoring the Computer to an earlier date when the Computer was working correctly should fix the issue. However, it is required to restore the Computer in the Safe Mode.
Please restart the Computer, press and hold the F8 key to access the Safe Mode. Once you are there in Safe Mode, please click All Programs, Accessores, System Tools and System Restore. This will open the System Restore window, there, please select a date when the Computer was working correctly. Performing the System Restore to an earlier date should fix the issue.
If the issue still perists even after performing the System Restore in the Computer, you will need to perform the System Recovery in the Computer. Your Computer is shipped with a recovery partition which is present in the hidden part of the Hard Drive. You can use the Recovery Partition to re-install the Operating System in the Computer. Performing the System Recovery using the Recovery Partition will erase all the User Data in the Computer.
To access the Recovery Partition, please restart the Computer, press and hold the F10 Key. This will boot the Computer to an Edit Boot Options screen, please press the Enter Key there. This will launch the VAIO Recovery Center. Please select the "Restore C: Drive" option at the VAIO Recovery Center to perform the System Recovery. Performing the System Recovery will re-install the pre-installed Operating System, Drivers and Applications to restore the Computer to the factory settings.
Good Luck!
Please let me know if you have any further questions or require any further assistance.
Thank you for using FixYa.
Dec 15, 2010 | Sony VAIO VGN-CR220E/P Notebook
My sony vaio vgn- ns10l isnt loading the windows vista o/s. even the recovery thru f10 is not working. pls what is d problem. i dont have recovery discs.
Hi.
As the Recovery Partition in the Hard Drive is not working, you may try performing a BIOS reset.
Performing a BIOS reset should resolve any issues related to the Recovery Partition.
Please open the below link to view the steps to perform a BIOS reset:
http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&docType=kc&externalId=C94679
As the Operating System installed in the Computer is Windows Vista, you may also try performing the "Windows Startup Repair".
Please open the below link to view the steps to perform the Windows Startup Repair:
http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&docType=kc&externalId=C1002354
Please try performing both the steps which I have mentioned above.
Performing the above steps should resolve the issue.
If the issue still persists, then the issue might be due to the Recovery Partition
The Files in the Recovery Partition might have been corrupted.
However, you may also perform the System Recovery by purchasing the Recovery Discs online.
You may purchase the Recovery Discs for the Computer by visiting the below link:
https://servicesales.sel.sony.com/ecom/accessories/web/productSearch.do?searchOperation=partSearch&searchText=Y8316061A&sessionId=ddyNo-T9pA_dxgMgnzHn_WX
Once you have obtained the Recovery Discs, you may perform the System Recovery.
Please open the below link to view the steps to perform the System Recovery using the Recovery Discs:
http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&docType=kc&externalId=C460645
Please try performing all the steps which I have mentioned above.
Performing all the above steps should resolve the issue.
Hope this helps.
Please feel free to contact for further information and assistance.
Oct 02, 2010 | Sony VAIO FZ Series VGN-FZ140N/B Notebook
Reset a sony laptop w/o recovery disk
If you haven't reinstalled a different Operating system to that, the recovery partition would still work. To boot to that you have to tap F10 key several times immediately after pressing the power button when turning on the computer. Choose Recovery Center then press enter. Do a Complete Restore System, follow the prompts to finish. It will run the progress bar as like installing the OS with a Recovery Disc. That is if the recovery partition is not corrupted.
Sep 18, 2010 | Computers & Internet
How can i restore my laptop to factory settings
Most of the HP Notebooks are shipped with recovery partitiona d you can restore to factory settings uisng teh recovery partition.
Perform ing Full System Reocvery will completely remove the data on the hard drive. Hence it is recommended to take the back up of the important data present in the Notebook before perform ing the Full System Recovery.
1. Restart the notebook.
2. At the Compaq logo, press F11 to initiate the Recovery options.
3. The PC Recovery screen will be displayed. Select PC Recovery and
press Next.
4. In the next screen, click OK to access the Recovery menu.
5. You will receive a screen explaining the System Recovery Process.
Click Next to continue.
6. Once the Recovery process is completed, you will prompted to either
restart or turn off the computer.
May 16, 2010 | Computers & Internet
How do you restore the laptop with the internal restore system
1. According to the specifications available online, your Computer is shipped with the VAIO Recovery Center software, present in a hidden partition. You can use the VAIO Recovery Center to install the preinstalled Operating System, Applications and the original Drivers.
2. Restart the Computer and press the F10 key when the Sony logo appears to check whether the Computer is able to access the VAIO Recovery Center.
NOTE: Restart the System, tapping the F10 key immediately. This should trigger the System to boot directly to the Recovery Partition, and initiate the VAIO Recovery Center, without requiring the Windows Operating System to load.
3. If you're able to access the VAIO Recovery Center, select the option 'Restore C: Drive' and follow the onscreen instructions to perform a C: Drive Recovery to resolve the issue.
4. Performing a C: Drive Recovery will erase all the data present in the C: Drive and will reinstall the pre-installed Operating System, Applications and the original Drivers.
For further information you may refer this link also:
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C459775
Good Luck!!!!!!!!
Oct 07, 2009 | Sony VAIO VGN-NR498E/S Notebook PC
Operatings systems disc not working properly
The cd that you got with your system may be a recovery cd; not an operating system disc.
Dec 17, 2008 | E-Machines Open Box D3107 AMD 1.8G 256M...
Windows not installing
Sir please specify the Operating system which you want to install.
You can perform the following troubleshooting steps.
1) Your computer comes with a preinstalled operating system. The model also have recovery partition ( mostly in your D: drive) for installing Genuine Windows Vista Home Premium. You can use this recovery partition to install the operating system...
2) If you have created Recovery disks from the recovery partition then you can install the operating system from those disks.
3) If you have deleted the recovery partition and your recovery disks are damaged, then if your Notebook is under warranty , you can get recovery disks from HP with out any cost( FREE).
For more information contact HP 24X7 chat support.
For drivers you can visit the following HP link and select the operating system and download the drivers...
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=3545112&lc=en&cc=us&dlc=en&lang=en&cc=us
http://welcome.hp.com/country/us/en/contact/chat_1.html
Jun 30, 2008 | HP Pavilion dv2000t 14.1" Notebook Laptop...
HP Compaq Presario SR2010NX PC Desktop Logo
180 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
