Question about Sunbeam Heating & Cooling
I just unpacked the space heater model SFH612-UM-1LC. As soon as I turn it on, the red light blinks and there is no heating. It will not oscillate when heating. As soon as I turn it back on, place on low heat and set temperature, the red light start blinking and everything shuts off. Please help. Thank you.
  • Sunbeam Master
  • 494 Answers
If it has a reset button, push it and try again. If it still does not work, return the heater where you bought it and exchange it. Douglas
Posted on Oct 02, 2010
I have a Sunbeam heater, I bought it January 2011, Today it would not heat, I have no receiptt, no manuel and no box to return it. Can you help me solve my troubleshooter.
Posted on Oct 03, 2011
Bionaire heater sometimes turns on at very low intensity and just kind of chugs along as the yellow button flashes. It works fine just wondering why it does that
Amazon.com - Bionaire Heater with Rotating Grill ...
www.amazon.com > ... > Space Heaters
Amazon.com, Inc.Amazon.com - Bionaire Heater with Rotating Grill, BFH2242M-SM - Space ... The ultraquiet Bionaire® Heat Circulator with Rotating Grill circulates warm air ... High-intensity, sun-like warmth, Gentle heat, Medium intensity, whole room .... When temperature reaches what you have set it to, the heater turns off and sometimes.
Bionaire Office Heater with Worry Free Motion Sensor
www.amazon.com > ... > Heaters & Accessories
Amazon.com, Inc.
Rating: 4.4 - ‎71 reviews
Amazon.com - Bionaire Office Heater with Worry Free Motion Sensor - Space Heaters. ... Heat turns off after 30 minutes of no motion detected. ... If you place it under the desk, your feet will be very warm, but not so much the rest ... CONS: The High setting gets too hot sometimes, while the Low setting doesn't get hot enough.
Bionaire® Electric Fireplace Heater BEF6500-UM - Bionaire
www.bionaire.com/bionaire-site.../bionaire...heater/BEF6500-UM.html
The Bionaire® Electric Fireplace Heater provides the ambiance and warmth of a ...Flame Intensity; 12 Hour OFF Timer; Free Standing or Wall Mountable; 2 Heat .
Jan 30, 2016 | Bionaire Heating & Cooling
Electrical ignitor on Kenmore Hot Water Heater Not Working
The water heater uses a thermocouple to generate a small voltage from the pilot light. This voltage is used to blink the led and allow the main gas jet to turn on. Either your thermocouple or the wiring from it has failed and needs to be replaced, or realigned if perhaps it moved out of position above the pilot light.
Mar 26, 2017 | Rheem 40 Gallon FVR NATGAS Low WATER...
Well my dishwasher won't turn on and it keeps blinking clean and I cleaned it and it won't work
1st unplug or dispower appliance for 2 min. Then, be sure door is cloesd, press heated dry key and Hitemp repeatedly until all lights on panel light up; if no....
The clean led blinks 7 times which indicates a heat circuit error.
Pull the kick plate off and behind should be a tech sheet..Look for heat cicuit... Check the heater for continuity..Some models come with kits main erc w heater....If heater test good then replace main erc and neutral line door switch located inside panel w main erc... Estimate for tech to repair $249-$329.... If you follow my directions you may soon one day become a tech..... A good tech would make $100-$150 on this job profit
Oct 29, 2012 | Dishwashers
I have a sunbeam SCH2101-UM Ceramic Electric Heater. How do I get it to rotate?
It doesn't Oscillate on it's own,but if you want to swivel the base up to 180 degrees, just grab the base and turn it.
Nov 19, 2010 | Sunbeam Heating & Cooling
The heater no longer moves from side to side. It's an oscillating heater. How can I fix this?
Check out this tip that I wrote about space heater problems..
DeLonghi Space Heater does not Heat
heatman101
Oct 05, 2010 | Honeywell HZ370 Space Heaters...
Have heating pad model 818-7. blinking red light for high when connected- but no heat. what to do. I love this soft, terry cloth hour glass heating pad controller model number: SW204. e12107 is also on...
I had this problem with a heating pad too. I tried turning it off, unplugging it, then plug it back in and see if the light is still blinking. If it's not, set it to the temp you want. My heating pad was very temperamental that way, it didn't want to be set before it was plugged in. I hope this works for you.
Dec 16, 2009 | Sunbeam 805810 HeatSense Heating Pad...
Turning on shuts off red light starts blinking
Hi
You have defective Oscillation Circuit maybe you have leak small parts like capacitors and resistors. and also the HOT Area.
Thanks!
Dec 04, 2008 | Televison & Video
Sony KV-35S66
power supply kit hozout plus flyback 1fuse 1restor
Nov 10, 2008 | Sony KV-35S66 35" TV
TV won't come on, just blinking red light...
Hi
You have defective power oscillation! in power section and or power oscillation!
Thanks!
Sep 19, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Heating & Cooling Logo
622 people viewed this question
Top Sunbeam Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Jay Finke
Jay Finke
Are you a Sunbeam Heating and Cooling Expert? Answer questions, earn points and help others
