Question about Coleman Mach 15 Air Conditioner
The compressor on my coleman series 7000(roof top) wont shut off.The fan kicks on and off like its supposed to,but compressor will not stop.It does blow cool air.Hope someone can help me.Thank you.
Check the relay and the thermostat
Posted on Oct 20, 2010
COLEMAN SHROUD REPLACEMENT 7000 SERIES
If you Google airxcel.com, you should get some options. to get either their literature or tech support and they should be able to help you.
Apr 15, 2013 | Coleman Air Conditioner Shroud Rv Roof Top...
Coleman mach rv roof ac, the fan comes on but the compressor doesn't, i've replaced all capacitors and stll is not comming on, how do i check voltage to the compressor to maske sure i have pow
At the compressor connectors you have a live and a neutral phase. The live usually goes to a ptc relay starting mechanism which you can test with a meter. If you can disconnect the relay and check the windings of the compressor from one pin to the other two it will tell you if the compressor is open circuit. It is more often than not an overload fault.
Apr 23, 2012 | Coleman Heating & Cooling
Roof top Ac the commpressor does not seem to be kicking on fan works any thoughts.
Several things can cause this. The most common are a bad compressor, burned off wires, and bad capacitors. Turn off the power and check your wires in the control box and at the compressor. Look at your capacitors for signs of bulging. Replacements can be purchased at local ac or electrical supply houses.
Oct 09, 2010 | Coleman Heating & Cooling
Duo therm roof top camper a/c. fan runs but compressor stopped kicking on all of a sudden. replaced both capacitors; getting 110 to compressor but it still wont kick on
Sounds like the compressor is toast...if the caps have been changed and there is voltage there, you have done all you can...replace the compressor or buy new...
heatman101
Sep 01, 2010 | Dometic Rooftop RV Air Conditioner
My coleman 13,500 roof a/c year 2000 does not blow as cold as used to. I have cleaned the top condenser coils, with no help. It also at times will seem to pull a heavy load when I assume the compressor...
if the compressor started and stoped means
1 thermostat need settings
2 compressor over heated due to low suction pressure need to check and repair the leak then charge the freon
Sep 14, 2009 | Coleman Mach III Air Conditioner
My coleman mah 3 roof top will not blowon fan side
Sounds like you have either a bad fan motor or a bad fan motor capacitor. When you turn the unit on with the fan not working, the compressor (the humming noise) runs and gets real hot real quick resulting in the compressor cutting off ( the nothing after) on it's inside high temp switch. This is what the compressor is designed to do so that when this happens, it does not burn the compressor out. Replace you fan capacitor, give the compressor an hour to cool, then try it. In most cases and if I'm correct, the unit will run just like you want it to. Good luck.
Please rate solution
Sep 09, 2009 | Coleman Mach III Air Conditioner
We have a 2000 Coleman Cheyenne pop up with a Coleman mach roof unit. We turned it on today at home and the fan blows but the heater doesn't heat up and the air conditioner doesn't cool. Someone said if...
The distance of the cord is a big deal, 10AWG Cord would be best for this situation. If you have a 50ft cord, make sure that the cord is not wound up on top itself as this can cause a drop in voltage and a spike in amperage. Is the compressor trying to come on at all? If not, then you may have a problem with the selector switch or the thermostat. If the compressor is humming for a few seconds and then stopping and then trying to come on again, it could be a problem with voltage loss. Anything below 98.5 plus or minus 10% is too low the for the compressor to kick on.
Jun 06, 2009 | Coleman Mach 15 Air Conditioner
Coleman (RVP) 7000 AC unit compressor problem
I had a problem with my coleman mach 3 AC, we were at an RV park up at lake shasta CA and the fan would stay on but the compressor would come on for a few seconds and then trip off. It was the motor overload relay on the compressor that was tripping. the RV park was old and apparently the wiring to the panelboard at the RV park was too small, when you are drawing a lot of current there was too much voltage drop across their line, to make up for this the motor tries to draw more current and heats up the motor overload and it trips off. I solved this problem by buying an autoformer from Camping World, it senses a voltage drop and automatically boosts the voltage.
I am now having a seperate problem, the compressor is either locked up or has too much back pressure and trips off the service breaker when trying to start. The only solution I can see with my current problem is to replace the entire unit.
Oct 07, 2008 | Coleman Mach 15 Air Conditioner
Coleman Mach 15 Air Conditioner Logo
298 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
