Question about Fisher and Paykel Washing Machines
Have just set up washing machine after moving Model no MW 512 AU Fault When power is turned on a constant beep emits and as this model has few options I have two green lights on and the red spin light stays on also How do I reset to normal Kind regards Sean Ifland
  • seanifland Oct 02, 2010
    Will not let me download manual
    Keeps telling me server is reset at 99% of download
    sean
  • seanifland Oct 03, 2010
    Cannot download manual
    And I was told my problem is a simple one so I would appreciate a simple solution otherwise it seems I have wasted my time using this service
    regards sean ifland
  • Fisher and P... Master
  • 713 Answers
Hi just read your posting.Now when the machine is beeping the lights that are lit will be in a row of 8 lights.Starting from the left to right which lights are lit when the machine beeps,Is it the 2nd and 5th or the 1st and 7th ---etc---?Please reply with additional information and I am sure I can help.Looking forward to your reply.
Posted on Oct 03, 2010
  • 2,272 Answers
The first RINSE light or SPIN light is flashing:------ The machine has a suds build-up. (Too much detergent may have been used for the amount of soil in the load.) Wait for suds to dissolve (about 20min). Rinse clothes using a deep rinse. -------- First RINSE or SPIN light is flashing as well as the Spin Speed light.:--- Wash load is out of balance. Ensure the machine is stationary. Manually redistribute the load. Check the machine is level. ------ Single Beep Every Second and... Possible Solutions:-- Some lights are on but the pattern of lights is unfamiliar. 1 Turn your machine off at the wall, 2 Wait for 60 seconds and turn it back on. 3 Check the machine is level. 4 Remove load and retry. 5 Put through a Deep Rinse and Spin. 6 If the fault re-occurs repeat Step 1. --------- If your Smart Drive® gives a musical series of beeps every 5 seconds it is telling you that it has a problem which YOU can solve using the checklist below. * The beeps are the same sound your autowasher makes when you turn it on at the wall. Musical Series of Beeps* Every 5 Seconds and... Possible Solutions HOT water temperature light is flashing:-- Hot water supply is not hot enough to maintain the wash temperature you have selected. Select a lower wash temperature. Inlet hose screens may be blocked. There may be a kink in the hose. Hot tap has not been turned on. Inlet hoses connected to the wrong taps. --------- COLD water temperature light is flashing:-- Cold tap has not been turned on. Inlet hose screens may be blocked. There may be a kink in the hose. Inlet hoses connected to the wrong taps. Cold water temperature exceeds recommended limits. The flow rate of the supply water is too slow. --------- HOT and COLD water temperature lights are flashing:-- The taps have not been turned on. Inlet hose screens may be blocked. The hoses may be kinked. The drain hose is too low or the drain hose is pushed into the standpipe too far and the water is siphoning out of the machine. The flow rate of the supply water is too slow. --------- HIGH water level light is flashing:-- The machine is overloaded and can not agitate. Ensure the machine is stationary. Remove items until the remaining ones can move freely. Select a higher water level. -------- click this link for more help:-- http://manuals.appliancesonline.com.au/mw512/mw512_user_guide.pdf ---------
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation
Posted on Oct 02, 2010
  • 10,865 Answers
Hello. Here is a complete set of free downloadable manuals for your machine. http://safemanuals.com/user-guide-instructions-owner-manual/FISHER%20%2526%20PAYKEL/MW512-_E
The problem you are having is not a serious issue but was caused by moving the machine without securing the basket for the trip. This is all covered in the manuals. Joe
My washing machine goes through the washing cycle normally but does not spin.
spin not clicking in
no power to motor or its kick in solenoid
check timer or control circuit board
Apr 30, 2017 | Washing Machines
I don't know where to put the washing detergent
Take out the fabric softener cup(top of agitator) and put your powder detergent down in the middle of the agitator and put cup back on.
Jan 08, 2014 | Fisher and Paykel Washing Machines
My fisher and paykel top loading q washing machine won't start. It beeps and lights 5 and 8 come on. Any ideas what the issue might be?
That is fault code 9 machine not sized
9. (00001000) Size Switch Error
The Display size switch setting does not match that which is stored in memory.
Action GW Machines: Reselect the size of the machine by using the SIZE SETTING
MODE.
To set the size switch, turn the power on at the power point and off at
the console. Press and hold Wash Temperature Setting Up then
press Power. SmartDrive will give 4 short beeps and the pattern of
LEDs will change.
One of the following buttons needs to be pushed to lock the size into
memory.
• Press Wash Temperature Setting Up, the Cold LED is on for 5.5kg
(560mm wide).
• Press Water Level Up, the Low Water LED is on for 6.5kg / 7.0kg
(600mm wide).
517790C
35
• Press Spin Speed Up, the Spin Hold LED is on for 7.5 / 8.0kg
(650mm wide).
• Press Power to confirm the setting and also exit this mode.
Action IW Machines: To access Size Setting Mode, push and hold the Fabric Care button
and then press the Power button to enter Size Setting mode. Select
the correct size on the display by pushing the Adjust button to
highlight the correct size. Size setting is then achieved by pressing
the Power button. Powering off will set the size into the memory.
Note: Fault code 9 will only be logged into the memory of IW machines. GW and MW
machines can display this fault but it will not be recorded.
Aug 13, 2012 | Fisher and Paykel Washing Machines
My top loading fisher and paykel q washing machine beeps with lights 5 and 8 on - what is the problem?
That is Error code 9 machine needs resizing.
MODE.
LEDs will change.
memory.
(560mm wide).
(600mm wide).
517790C
35
(650mm wide).
Fisher and Paykel MW 512 AU is not running. The first and the last lights(long wash and spin leds) on the displays stays ON in red and keeps on beeping. I appreciate any help in resolving this issue
This(130) is the only code that comes close to that,
There is no code for 129.
130. (10000010) Single Rotor Position Sensor Error
The Motor Control Module has found an error in the pattern received from the Rotor
Position Sensor. Likely causes of this fault are a bad connection on the harness between
the Rotor Position Sensor and the Motor Control Module, or a faulty Rotor Position Sensor.
Primary Source: Wiring.
Action: Check for corrosion on the RAST connector of the Rotor Position
Sensor and the Motor Control Module connector.
Secondary Source: Rotor Position Sensor.
Action: Check the Rotor Position Sensor with an R.P.S. tester. Replace if
faulty.
Tertiary Source: Motor Control Module.
Action: Replace Motor Control Module.
Quaternary Source: Rotor
Action: Ensure the correct rotor for this phase of machine has been fitted
May 26, 2012 | Fisher and Paykel Washing Machines
Washer won't drain
DIAGNOSTIC MODE
To enter diagnostic mode follow the steps below.
1. Turn the power on at the power point but off at the machine.
2. Press and hold WASH TEMPERATURE SETTING DOWN and then press POWER until the
machine gives 2 short beeps and lights up.
3. Release the buttons after the beeps as the beeps indicate diagnostic mode has been entered.
4.1 Last Fault Data
When in diagnostic mode the last fault can be found by pressing the SPIN SPEED UP or DOWN
buttons until the HOLD and SLOW lights are illuminated. Binary can then be read from the wash
progress lights.
4.2 Drain Pump Test
MW Washer
When in diagnostic mode press SMART TOUCH CYCLES to activate the drain pump. To
deactivate the pump, press SMART TOUCH CYCLES again.
GW Washer
When in diagnostic mode press REGULAR to activate the drain pump. To deactivate the pump,
press REGULAR again.
4.3 Water Valve Test
The water valves can be activated in diagnostic mode by pushing WASH TEMPERATURE SETTING UP to activate the Hot Valve and WASH TEMPERATURE SETTING DOWN to activate
the Cold valve as with previous models.
Pressing each button once will activate the valve. To de-activate valve press the same button
again. This is also good to use when installing machines as it takes the shock out of the fittings
and seals and allows checking for leaks on the inlet hoses, both machine end and tap or super-tub
end.
Caution: Do not leave the machine unattended when either or both valves are operating
May 23, 2012 | Fisher and Paykel GWL11 Top Load Washer
Fault 9 come on
MODE.
LEDs will change.
memory.
(560mm wide).
(600mm wide).
517790C
35
(650mm wide).
May 14, 2012 | Fisher and Paykel GWL11 Top Load Washer
Hi my Pride Washer model MW 512 gives long beeps and 1st longwash n 7th after the rinse orange light flashing as well, As it starts to fill the washer it stops n starts with continuos beeps even though i...
Hi just read your posting.Now you mentioned in your posting that the lights that are on when the machine is beeping are 1and 7.This is on the row of 8 lights and you started from left to right.Is this correct? If it is correct then the fault you have on your machine is called SINGLE ROTOR POSITION SENSOR ERROR.This means that the rotor sensor which is attached to your motor is faulty or your control module is faulty.Please reply with confirmation on the lights that are on when the machine is beeping and I am sure I can help you rectify this fault.Looking forward to your reply.
Oct 14, 2010 | Fisher and Paykel GWL11 Top Load Washer
Washing Machines Logo
110 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
