Question about Gilmour 486 Sprayer Dial A Spray
Instructions for dial in millileters [metric] web?
15 ml of perfume equals how many ounces?
Hello, Nancy -
If you think you will ever need to convert metric measurement to
"English" measurement (used in the USA), this is a great web site (for all kinds of conversions):
http://www.metric-conversions.org/volume-conversion.htm
This is the link to the home page for conversions:
I suggest you save that web page address to your Favorites / Bookmarks.
Using the conversions calculator for milliliters to U.S. fluid ounces, this is the result:
50 ml = 1.690701 U.S. fluid ounces
This is the result for U.K. fluid ounces:
50 ml = 1.759754 U.K. fluid ounces
I assume your question has to do with liquid perfume.
Jan 10, 2018 | Math
50 milligrams = how many millileters?
Milligram is a unit of mass (or weight), while milliliter is a measure of volume. There is no direct conersion betweenthem.
For examole, 50 milligrams of lead will occupy less volume than 50 nilligrams of feathers.
Nov 28, 2016 | Miscellaneous
How to convert mL to fl oz ?
One millileter is about 0.033814 fluid ounces, so to convert ml to fl oz multiply by 0.033814. To convert the other way, divide by 0.033814
May 01, 2011 | Texas Instruments TI-30XA Calculator
How many mls in 6 oz
6 ounces is about 177.441 millileters.
May 01, 2011 | Office Equipment & Supplies
Why does 100 grams equal 100 milliletres
100 millilitres of water weighs 100 milligrams. 100 millileters of lead weighs quite a bit more. The reason for this is that initially one gram was defined as the weight of one milliletre of water.
Apr 23, 2011 | Office Equipment & Supplies
Convert metric weight to pounds
1 Kilogram (Kg) = 2.20462 Pounds (Lbs)
1 Pound = 0.453592 Kilograms
See the following links for Online Conversion Calculators:
http://www.metric-conversions.org/weight/kilograms-to-pounds.htm
http://www.metric-conversions.org/weight/pounds-to-kilograms.htm
Just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information at the website indicated.
Good luck.
Apr 22, 2011 | Office Equipment & Supplies
I have lost the instruction manual how do i change the setting from miles to kilometers
If you have the model, Ped Alarm - PE319, it doesn't have metric units. Correctly, Brunton sells one model programmed for metric and one with Imperial units. The units are fixed, and no conversion information is programmed into the units. The product web site doesn't come up correctly on my browsers: http://www.brunton.com/product.php?id=45. However a FAQ is available at http://www.brunton.com/faq.php . The manuals are also available here, for the Ped Alarm, click on Instruments and look in the list for that model (followed by .PDF).
I wish I could be of more help.
Oct 30, 2010 | Brunton Digital Pedometer with Alarm
Instruction manual for invicta elite 9225 need help with the dials and need to know how to use it
Their web site gives a list of generic instructions which you need to
scroll through to find the section that suits your watch.
You can get an instruction manual by going to their web site
(www.invictawatch.com/), put your cursor over "collections" in the
menu across the top and then clicking on "instruction manual".
Click on the link below the "Invicta" logo and download the instructions.
May 21, 2010 | Invicta ELITE 9225 Wrist Watch
How do i set this thing? and what do all the dials mean?
If you go to the Fossil web site http://www.fossil.com/en_US/shop/customer_care/static/fossil-Instructions.html
You will find a list of diagrams and associated instructions. (As you run the the curser over each model the picture changes to show the layout of the wach the instructions are for).
I could not find the model you mentioned but there must be one of these that is close to yours.
May 19, 2010 | Fossil Metal Chronograph Silver Dial...
Gilmour 486 Sprayer Dial A Spray Logo
158 people viewed this question
Top Gilmour Garden Experts
cackelberry
Level 1 Expert
Charles T Nevin
Charles T Nevin
Are you a Gilmour Garden Expert? Answer questions, earn points and help others
