Hp Pavilion, tx2000, Black Screen, running, lights are flashing, Nothing on monitor
  • 56 Answers
As soon as you turn on the computer keep tapping the F8 key until you see a screen called advanced boot options ..using the arrow keys in the keyboard select the option last known good configuration and press enter hope this works if this doesn't work.
again go to that advance boot options screen by following the same above said procedure and this time select the option safe mode then if your computer boots up in the safe mode then try to do system restore from start button->all programs->accessories->system tools->system restore select a date at which your computer was working fine and let it do its stuff if this works your computer will boot to the home screen..
good luck
Posted on Oct 02, 2010
I have an hp pavilion dv9815nr notebook pc. My laptop turns on, but when I enter the first letter of my password the screen goes black. Computer sound like it is still running but just black screen
Shine a flashlight on the dark screen to see if you barelysee the icons on the desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can beany kind of monitor even the old big fat crt monitors as long as it has a vgacable to connect to your computer's vga port. If so that proves yourvideo card is ok. The video will show on most systems when you rebootwithout you having to do anything. Some systems will require you to hit the FN(Function key) + F1 thru F12. Hold down the FN key then hit the correctkey for displaying on the monitor (F1 thru F12). The correct key willnormally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works,then your screen is bad. If you see no icons by shinning the flash lightand nothing shows on the external monitor, then most likely your video card isbad.
May 30, 2012 | HP Pavilion dv9815nr Laptop
Hp Pavilion DV-4000 Screen
Are you saying the lcd screen is black? It seems like it booted up but nothing appears on the screen?
May 03, 2012 | HP Pavilion dv4000 Notebook
On power up, caps lock led flashes and screen is black. the fan is running, but nothing else.
Remove the battery, and unplug the A/C adapter and hold down the power button, for 40 seconds.Soon your laptop will reset,and run well.Now you will install all the accessories and start.
Hope this helps you.
Feb 25, 2011 | HP Pavilion dv7-1132nr Notebook PC
What can I do to fix my hp pavilion tx2000 because it shows a black screen when I turn it on but everything else works fine and it even worked perfect when I connected it to another monitor by vga
You might have either a faulty LCD cable or screen inverter board.
The LCD cable transfers data signal from the motherboard & video card to the LCD screen. It also supplies high voltage DC power to the screen inverter board. The screen inverter board works as a power supply for the backlight lamp mounted inside the LCD screen. It converts low voltage DC power to high voltage AC power needed for the backlight lamp.
Sep 15, 2010 | HP Pavilion TX2000Z Notebook
HP tx2000 - black screen.
Hi
The problem you are experiencing is related to the screen of your Hp.
All you need to do is to is to get to a computer store and get your screen replaced.
You can not fix a damaged screen.
GOOD LUCK
Jun 17, 2010 | HP Pavilion TX2000Z Notebook
Hp pavilion ze4930us notebook pc is dead
Hi danielb59,
Let do troubleshooting together.
First) if possible, connect a external monitor to your laptop. If you get a picture on the external monitor, then this means your pc is ok but the monitor screen on the laptop has gone bad.
Second) if the monitor screen on the laptop has gone bad, most likely the inverter component on the screen went bad (inverter provide back light). The inverter is replaceable but I do not know what they run. If your laptop is still under warranty, then please allow the manufacturer to fix it.
Those are your choices. Hopefully it helps and good luck.
Jul 26, 2008 | HP Computers & Internet
Flashing Power Light
When this occurs an inverter, backlight, vga connectiosn, etc could be the cause, my suggestion is connect it to some other device, if you get the same result then your monitor is bad!
Nov 26, 2007 | HP Pavilion F1903 19" Flat Panel LCD...
Computers & Internet Logo
911 people viewed this question
David Payne
David Payne
