Question about Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal
Why is my garbage disposal beeping? - Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal
4 Suggested Answers
  • 2976 Answers
SOURCE: Garbage Disposable won't work.
If the cutter plate will turn freely, look for a reset botton. Some units have them and depending on how it was installed, it will be around the back. It should be a push button, about 3/8" diameter. It takes a good hard push to reset it.
Posted on Jan 03, 2009
  • 10865 Answers
SOURCE: Removing dishwasher drain plug on a new garbage disposal.
The plug is thin plastic. Use a flat blade screw driver and a hammer to knock it out. I know this sounds primitive but this is how it is done. I have been a plumber for thirty years.
Posted on May 16, 2009
  • 25 Answers
SOURCE: Resetting Garbage Disposal
should have came with a alen key use it. to loosen the blades that are stuck on the bottom of the gaburator theree should be a hole in the middle. Just fine a alen key that fits in the hole and turn it around and then turn it on should solve your problem
Posted on Jun 07, 2009
Tip
How is the best way to use a Garbage Disposal
Garbage disposals can be a great feature in the kitchen if there are used correctly. If they are not used correctly they can be a real pain to get unjammed or to get them cleaned out.
To keep a garbage disposal from smelling up the kitchen, proper use and care must be followed.
There are certain foods that a garbage disposal will handle well and there are some that do not do very well in a garbage disposal.
Some that do well and you can put into the garbage disposal are:
1. soft bones, like chicken or fish bones
2. ice cubes
3. coffee grounds
4. citrus fruit peels
5. store bought disposal deodorizers and cleaners
Some foods that do not do well are:
1. very fibrous vegetables, like onions, corn husks, celery, etc…
2. hard bones, like beef or pork
3. large pits, or seeds like peach seeds
Also, while it is good to run water while grinding food in a garbage disposal, it is not a good idea to run very hot water in the disposal. This can cause the motor to over heat.
Do not run the garbage disposal longer then a half minute after the food id ground up. Running an empty garbage disposal can cause excessive wear.
It is also a good idea to start a full stream of water and the garbage disposal motor before putting large quantities of food into the disposal. Staring the motor with a large amount of food inside the disposal is hard on the motor, and may cause a jam.
http://www.fixya.com/support/r4062688-garbage_disposal_smells
http://www.fixya.com/support/r4062599-garbage_disposal_clogged_or_jammed
on Feb 06, 2010 | Dishwashers
Titan garbage disposal
Push reset button located bottom of disposal? Use broom stick and rotate stuck cutter disk?
Copy following link to troubleshoot by type of problem:
http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.html
Titan appears to be repackaged sinkmaster garbage disposal.
There is no service manual or installation manual on brief web search. However link above has manuals sinkmaster and other brands .
Add a comment and say what you discover
Jun 09, 2013 | Garbage Disposals
Garbage disposal is jammed kitchen aide kwd-200a
Use broomstick:
Copy following link to repair, troubleshoot and replace disposal:
Add a comment as needed, or repost question with detail
Sep 07, 2012 | KitchenAid Batch Feed Garbage Disposal...
How to fix a leak from a garbage disposal?
Check location of leak. If from bottom, replace disposal
Aug 18, 2012 | KitchenAid Batch Feed Garbage Disposal...
Water draining backinto dishwasher from garbage disposal
You have a clog where the drain pipe leaves the garbage disposal that isn't draining fast enough or not at all. Or it could be a clog in the dishwasher drain hose where it connects onto the disposal.
Apr 07, 2009 | Buck In-Sink-Erator BADGER 5XP BADGERVEXP...
Oe code on LG dishwasher following garbage disposal replacement
Hi. I just had the same trouble. Your garbage disposal comment there gave me an idea. The drain hose from your dishwasher likely goes to the garbage disposal and then out the drain. My hose had a little blockage at the joint where the hose goes into the disposal. I was able to clear it just by giving it a wiggle....all is well now.
Good luck.
Sep 01, 2008 | LG 24 in. LD-12BS6 Stainless Steel...
Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal Logo
616 people viewed this question
Top Ace Hardware Electrical Supplies Experts
handygirl911
handygirl911
Mike
Treefrog15
Treefrog15
Are you an Ace Hardware Electrical Supply Expert? Answer questions, earn points and help others
