Question about Remington Powder Actuated To Power Load .22 Brown #R029280
It appears that the 22 shell has become lodged in the barrel.
    Scholar:
  • 67 Answers
I'm assuming you are using something like a powder actuated nailing gun. If so the tool should come apart for just this reason. Do not try to mechanically force the spent shell from the barrel. You can damage the inside of the barrel. If you have the manual or know the brand name and model number you should be able to find a manual online that will tell you how to dismantle the tool.
Posted on Oct 02, 2010
Anything you can tell me about Winchester Model 97 Ser# 201413. when it was made and value.
The Winchester Model 1897 evolved from the Winchester Model 1893. The Model 1897 and 1893 were both designed by John Browning. The Model 1897 is an external hammer shotgun lacking a trigger disconnector. This means that the user can hold the trigger down while cycling the shotgun and once the action is returned to battery the gun fires. The gun itself is classified as a slide action pump shotgun. It was the first truly successful pump-action shotgun produced. Throughout the time period the Model 1897 was in production, over a million of the type were produced in various grades and barrel lengths. 16-gauge guns had a standard barrel length of 28 inches, while 12-gauge guns were furnished with 30-inch length barrels. Special length barrels could be ordered in lengths as short as 20 inches, and as long as 36 inches. Along with various grades and barrel lengths, the Model 1897 came in two different chamberings. One was the 12 gauge and the other was the 16 gauge. The shells should be of the 2-¾ inch or 2-? inch model. Any shells larger are not recommended. An average Model 1897 held 5 shotgun shells in the magazine tube. After including the one shell that could be held in the chamber, the average Model 1897 held a total of 6 shotgun shells. However, this would vary from grade to grade. When working the action of the Model 1897 the forend (fore grip) is pulled back, forcing the breech bolt to the rear which extracts and then ejects the spent shell while simultaneously cocking the external hammer by pushing it to the rear. When the forend is slid forward again, the breech bolt pushes a fresh shell into the gun's chamber and locks into place. This action of sliding the forend back and forth (pumping) is why the gun is classified as a slide action (or pump) gun.
Oct 23, 2016 | Winchester Optics
How to build a silencer for
Try YouTube as there are some excellent videos on silencer manufacturing
Most important thing is to get the barrel screw cut correctly to the bore not the barrel
Jul 30, 2014 | Ruger Model 77/22 .22 Winchester Magnum...
I have a early model 12 remington pump. 22 short, long and long rifle, the shells load into the barrel fine but are very tight and hard to get out after fired. why is this?
Sounds like it's actually made for 22 shorts, only, and the long and long rifle are extending past the chamber and wedging in the slightly smaller bore beyond the chamber after firing. (the casing expands slightly...)
Feb 16, 2014 | Sport & Outdoor - Others
I bought a Remington 870 at Christmas time. The first time i shot it the shells are jamming in the gun. I took it home cleaned it and oiled it real good. Went and shot it again same problem. Either...
If the 870 is a Magnum model it should accept 3" shells. After making absolutely sure you have an unloaded shotgun, both chamber and magazine are empty, empty, empty, proceed with these few checks.
Assuming it may be a 2 3/4' model, have you double checked on the left side of the barrel near the receiver? There will be gauge and shell length stampings on the barrel. If you are jamming 3" shells in to a 2 3/4" shotgun you will get jams as you describe. Look at the empty shell casings if you have any and see if the shell appears to be damaged from the chambered and firing process. This could also indicate you have a improper shell length issue.
If you are shooting reloaded ammo make sure it has been properly re-sized, crimped and reloaded.
sloppy reloading of shotgun shells can cause jams as you describe. Improperly re-loaded shells can also cause leaks of bb's, (shot) in to the receiver and bore area.
Check for a loose bb. or bb's, (shot) in the receiver and chamber area. A lodged bb. in these areas will cause problems you have described.
Run your fingers along the barrel and visually check it for any slight bulge. If you detect or suspect a bulge do not shoot or load the shotgun until a gunsmith or the factory check the barrel thoroughly. If someone had loaded a 20, 16 or similar smaller guage shell in the chamber by accident and the gun was fired it will usually cause at minimum a stressed and bulged barrel. Many times a slight bulge in the barrel may not be visually obvious.
Most of the time if a 12 gauge shell gets loaded behind that one and fired you will have catastrophic failures, i.e. the gun can blow up and cause serious harm, blindness or even death in rare cases to the shooter. Shooters call this a "20/12" catastrophic failure. This type of accident is not to be taken lightly! this is why shotgun shells of different gauges are different in color normally.
Never ever, mix shotgun gauge shells in a pouch or box.
If you pump the shotgun too easily, (i.e. wimpy) it can jam up. Always pump, "rack" a shotgun with vigor. I'm not suggesting abusive action, just don't be slow or overly gentle with the pump action that ejects a shell and reloads the next one. Something related to this is if your action/slide bar is out of alignment or has become torqued out of it's proper alignment this will cause problems as you have mentioned. The action/slide bar is a long single piece of flat metal that is in alignment with the barrel and is attached to the front forearm of the shotgun. This is the flat piece of metal that actually makes the action open and close as you pump the shotgun. There is one on the left underside of the bore and forearm of the shotgun. When you pump the action you will easily observe it moving with your pumping action.
Check how the empty action feels to you. While dry-firing, (using an unloaded shotgun), does the action feel smooth or perhaps, gritty, sluggish, overly tight? If any of the later the you need to double check for debris, shot, excessive old lubrication, gumming of the action, a bent action/slide bar, etc. A normal 870 has a very smooth action.
Also, check the bore for any obvious nicks or obstructions that don't belong there. A good quality shotgun such as your 870 should operate best with very little lubrication. Excessive lubrication over time can cause gumming up of the receiver area. Also, improper lubrication products. Improper lubrication can cause problems you have described.
I am not a gun smith. I am simply an avid gun enthusiast. If you have any doubts as to anything that you observe while performing these basic checks on your shotgun, I strongly advise you to call the factory or take it to a local gun smith. Many gun shops will give your shotgun a courtesy check over and if you don't find a solution, many times they will within a few minutes. Do not be embarrassed to take the gun in to a gunsmith! Trust me, they will most likely treat you and you gun with respect and courtesy. Otherwise they won't be in business much longer.
If the gun shop fixes your problem make sure and purchase some shells and perhaps something else from them. We must support our small business firearms dealers and gun smiths
Hope this helps you!
Feb 02, 2011 | Remington Shotgun Mount 12Ga Lh, B Square...
Remington Powder Actuated Tool Model 476D. Ram set. Drives concrete nails with a 22 size charge. Barrel seems to be clogged. Looking for a manual that shows the interior cross section. There is not a...
the tool got stuck, after a shot, it stayed up and I cannot release it to put a bullet and a nail for the next shot, what can I do, I tried to undo the nut in the top of the tool with no success.
Mar 06, 2010 | Remington Powder Actuated To Power Load...
Have I possibly damaged my Browning 16 gauge Standard weight shotgun Belgium made.by loading/shooting 2 3/4'' shells
Europe loads 2 1/2" and 2 3/4" shells for 16 gauge shotgun as standard and the US only loads 2 3/4" shells. If your shotgun chambers the 2 3/4" shells it should be OK. You can measure the chamber and see if it measures 2 3/4". You can also check your barrel for and bulges in it by looking down the barrel with a bore light shinning down the other end. A bulge should be able to be seen with the eye. If your gun has any bulge, do not fire it again. You will need a new barrel. But It should be OK and I would not expect their to be any bulges.
Nov 14, 2009 | Sport & Outdoor - Others
I have a shell stuck in the gun and can't get it out!
if it is exploded run a rod through the gun when you break it apart. if it is unexploded be careful - it's probably a rim fire cartridge. use plenty of penetrating oil.
Sep 29, 2009 | Remington Powder Actuated To Power Load...
Remington 1100 12 gage won't load a shell from the magazine
Are you shooting very light load?
Have you tried different ammo?
Light loads may not produce enough energy to work the action properly.
If different ammo doesn't help, make sure the two holes inside the barrel ring are clean and gas from the barrel can pass through. Next I would check the o-ring for cracks. If you shoot lots of shells (competition clays) the recoil springs inside the stock or over the magazine tube may have become weak and need replacing.
Jan 12, 2009 | Remington Shotgun Mount 12Ga Lh, B Square...
Remington Powder Actuated To Power Load .22 Brown #R029280 Logo
630 people viewed this question
Top Remington Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Remington Measuring Tool and Sensor Expert? Answer questions, earn points and help others
