Question about Sylvania LC320SLX 32 in. LCD TV
My LC320SLX keeps displaying some weird screen randomly and at random times when I press any button on my remote that displays the following words from top to bottom. Code: ZS77SC320SA-134, Pic Code: US_CM6_32_775N_005, MIPS: E1D9B079, Tuner: SANYO_UCO20AF, Safety: Safety_Non. A message in the middle of the screen says "Press POWER key to exit." When I press the power key it will go black and I think its about to go back to normal but then it just goes right back to the same screen and I cant get out of it.This starting happening about 2 weeks ago and wasnt a big problem because I could just press the power key and it would go back to normal. But the problem has gotten worse since then, Now it happens more frequently and when it does happen its alot harder to get back to normal. The video of whatever is on the TV still is in the background behind the message but the sound cuts out when this happens. I need help because now its at the point where there is nothing I can do to remove the message and I cant use the TV.
  • 44 Answers
You should be able to exit using the power button. Funai needs to address this issue, using many universal remotes with their TV's can access this menu, this menu is used for diagnostics and is not supposed to be accessible by consumers.
Posted on Dec 03, 2010
  • Matt Casdorph
    Matt Casdorph Dec 03, 2010
    also you could try updating or reloading the firmware through the usb port (using a usb flash drive) if your TV supports this.
    Matt
I can't 'tune' my ASDA TV Remote
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name list" in alphabetical order. Pull up older posts.
http://electro-medical.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Search the site by type in the brand name to your device, in the "Search box at the top right of the display window" to see the set-up codes to your device, with different brand remote controls.
Dec 09, 2015 | Televison & Video
Have model TE02DHB/TE22DHB. Setting random mode but I do not see any "RND" on screen after following directions for random mode.
http://waterheatertimer.org/pdf/TE02DHB-manual.pdf
Timer has to be programmed first with on and off times.
Manual says press FUNCTION and RND digits 'flash' on display
Then press set button
Then RND will appear on display.
Timer then uses your programmed on-off times, and randomly varies programmed on-off times in range from 2 to 30 minutes.
So if regular program says ON at 7, then random will vary ON time from 6:30 to 7:30, assuming timer functions as shown in manual and timer is not defective.
If above information does not work, then use circuit analyzer and check polarity of outlet.
http://waterheatertimer.org/How-to-set-timers.html#polarity
Jul 18, 2011 | Hardware & Accessories
My lc320slx is about a yr old and two days ago we were sitting watching tv and all of a sudden the channels started rsndomly changing, I thought something was on the remote control but there was nothing....
The control on the television itself is probably dirty or malfunctioning. Unplug the television and remove the back. Find the board underneath the buttons on the TV and gently clean off any dirt using rubbing alneeded and cotton swabs if needed.
Apr 24, 2011 | Sylvania LC320SLX 32 in. LCD TV
Why does a black box keep appearing on my screen?
The box is probably because you have closed-captioning turned on and set to "text" mode. Check the TV remote control for a button marked "CC" or "CAPTION" or something similar. Press the button to cycle through captioning options until you get to "OFF". This should clear up the trouble.
What's happening is that in text mode, the TV blanks out the area on the screen where the text should go, but there's nothing to display. Text mode isn't widely used, but in some markets it's used to display weather or other information. What sometimes happens is that the caption button on the remote gets pressed and you don't know the TV is set to text mode until the box starts coming up. And it doesn't happen on every channel, or even all the time on the same channel, so it can seem very random.
Thanks for using Fixya!
Oct 06, 2010 | Sylvania SRT2232S 32" TV
Where can I download instructions for utilitech timer
UTILITECH - Grounded in Quality
Digital 2-Outlet Timer (TE06WHBL)
Instruction Manual & Warranty
Before using your timer please read the following instructions carefully.
FEATURES
- Up to 8 ON/OFF events per day/56 ON/OFF events per week
- Option to program individual days or 8 different weekday groups
- Minimum switching period one minute
- Summertime/wintertime change over
- Easy to read LCD display
- Random automatic ON/OFF security feature
- Countdown feature
- Manual override button
- Rechargeable battery back-up (if there is no LCD display, plug
timer into a wall receptacle, this will recharge the battery)
SETTING TIME
Press and hold CLOCK key, then press DAY key to select correct day,
HOUR key to select correct hour, and MIN key to select minutes. When
MIN key is released, time will be set with seconds starting from 0.
Either holding down or repeatedly pressing appropriate button can
advance days, hours and minutes.
Do not set ON and OFF for same time.
PROGRAMMING EVENTS
The timer has the capacity for 8 ON/OFF events per day.
Save program capacity by using available blocks of days.
Blocks of days are:
1. M,T,W,Th,F,S,Su
2. Individual days of the week
3. M,T,W,Th,F
4. S,Su
5. M,T,W,Th,F,S
6. M,W,F
7. T,Th,S
8. M,T,W
9. Th,F,S
For each ON time and each OFF time--DAY, HOURS and MIN must
be set. Press PROG key onceto set first ON time--"ON" and number
"1" appear to left of LCD display indicating to enter first ON time.
Press DAY button to choose required day or blocks of days, then set
hour and minutes using HOURS and MIN buttons. After setting required
ON time, press PROG button to validate entry and move onto first
OFF time--"OFF" and number "1" appear to left of LCD display
indicating to enter first OFF time by using DAY, HOURS and MIN
buttons as above. Press PROG button to validate this entry. Repeat
remaining 7 ON/OFF settings as required. After setting required
ON/OFF settings, press CLOCK button to return display to clock. Timer
is now ready to operate. Check programmed settings by pressing
PROG button repeatedly--each setting will appear on screen.
MANUAL OVERRIDE
To choose permanent Manual ON, permanent Manual OFF,
Auto ON or Auto OFF, press Manual button. Each mode will be
displayed on screen. When choosing Auto ON, timer turns ON until
next programmed OFF time. The programmed settings will only work
on Auto mode. When Auto mode OFF is chosen, timer is OFF until
next programmed activity. (Inverted black triangle on LCD points
to either AUTO or MANUAL indicating which is selected)
COUNT DOWN FEATURE
To enter count down feature, press CLOCK and PROG buttons
simultaneously. Using HOURS and MIN buttons, set count down time.
(Maximum selection is 9 hours 59 minutes, minimum is 1 minute.)
Press MANUAL button to start countdown. Output will turn ON until
end of count down. Count down may be paused at any time during
period by pressing MANUAL button. To re-start, press MANUAL button
again. To review time during count down period, press and hold
CLOCK button. Release CLOCK button to return to count down display.
Note: To return to timer mode, press CLOCK and PROG buttons
simultaneously.
RANDOM AUTOMATIC ON/OFF SECURITY FEATURE
With this option selected, timer will switch ON and OFF in a random
pattern at least once in every 8 hours. (This may mean timer will
switch OFF within a set ON period, or vice versa.) Ideal for use with
a light--switching it ON and OFF automatically gives appearance of an
occupied home, but not at exactly the same time every day. To enter
Random mode, press DAY and HOURS buttons simultaneously.
An "R" will appear on display and unit will start random switching.
If no programmed times are set, timer will switch ON or OFF
approximately 1 minute after entering Random mode, then continue
randomly. To turn Random mode OFF, press DAY and HOURS buttons
together again.
SWITCH OVER SUMMERTIME/WINTERTIME ZONE CHANGE
To change from wintertime to summertime, press HOURS and MIN
buttons simultaneously. Clock will be set forward one hour and
"S" will appear on display. Repeat same procedure to return to
wintertime.
Note: if unit is purchased during summer, set clock time for one hour
less than correct time, select Auto mode and press HOUR and MIN
keys simultaneously. The unit will then adjust to correct summertime
and "S" will appear on LCD.
RESET
To reset unit for time and programmed ON/OFF settings,
press RESET button.
IMPORTANT SAFETY PRECAUTIONS and
RATINGS
[Contact the manufacturer; I've already wasted too much time typing
this in:
AmerTac
Saddle River Executive Centre,
One Route 17 South, Saddle River, NJ 07458
800-777-0802
www.amertac.com
Made in China
May 05, 2010 | Kitchen Appliances - Others
2 remotes....same problem
try a firmware upgrade if a firmware upgrade doesnt work, try e-mailing them from www.logitech.com go to contact us and send an e-mail:
1. Log into the Logitech Harmony Remote Software on your computer
2. Click on the Downloads button at the top-right corner of your screen
3. Click on the Firmware button. Follow the onscreen instructions to upgrade the firmware on your Harmony remote
4. Once the firmware upgrade is complete, click on the Update Remote button
5. Test your remote.
Apr 04, 2008 | Logitech Harmony 880 LCD Remote Control
CD player won't play random
the most likely problem is a weak or failing optical pickup. try a cleaning disc first there may be dust on the lens. do not use any liquid to clean the lens. remember this is an optical system if it can't focus properly or "see well" it can't read.
Feb 03, 2008 | Audio Players & Recorders
Random beeps, oven almost starts itself
The touch pad may be defective. There is a membrane behind the buttons that will cause problems like that. The only cure is to replace the touch assy.
Sep 11, 2007 | GE Profile JKP18 Electric Single Oven
Buttons dont respond correctly
Sounds like one or more of the keypad buttons are sticking - That would also cause the remote control to stop functioning.When you saw "P:0 V:0" you somehow managed to put the tv into the service menu. Pull the keyboard away from the plastic buttons and make sure nothing is in the way.
Aug 22, 2007 | RCA P52929 52" Rear Projection Television
Sylvania LC320SLX 32 in. LCD TV Logo
156 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
