Question about Panasonic Microwave Ovens
Panasonic NN-T687 (The Genius) door release button does not open front door. Appliance is mounted with a stainless steel frame over the oven.
  • Panasonic Master
  • 9,098 Answers
You will need to remove the oven from the frame, then remove the outer cover from the door.
Once the outer cover's off, you'll be able to see that door opening button presses against the door opening lever, which presses up on the door key/hook to open the door.
Usually the problem is a broken door opening lever.
You can order that part directly from Panasonic here.
Once it's fixed, if you want to download the owner's manual, it's here.
We have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on May 26, 2008
How do I switch my Panasonic NN-CD989S from Celcius to Fahrenheit?
talk with your local service agent and see if he can advise on what to do as he probably has met this problem in servicing units and has to change the setting
Jul 07, 2016 | Panasonic NN-CD989S 1.5 CU FT GENIUS...
Door release button does not work
busted plastic part in microwave send model # we can find the part you need
Feb 20, 2015 | Panasonic NN-SD277WR - NN-SD277WR...
If we open door microwave still spin and some time microwave do not work but some time work fine.
Microwave ovens have "microswitches" on the doors as safety features. Some have one or two. Some as many as 4. If they don't all work correctly, your oven won't start, won't stop, etc. I've had to replace switches on both my Sharp ovens. Likely same issue with yours.
Jul 07, 2014 | Panasonic NN-SN997S Prestige Countertop...
Door release does't work
It may be a broken door open button, door open lever, or grease in the channel where the door open button moves in the control panel frame.
See these files:
http://wwww.microwavedisplay.com/safety.txt
http://wwww.microwavedisplay.com/disassembly.txt
You can order Panasonic parts from Encompass here but without part numbers, it may be best to call them toll-free at 866-779-5835.
Dec 20, 2011 | Panasonic NN-H275 Microwave Oven
Door Release Button not working on Panasonic Microwave NN-T664SFT
The problem I had experienced with the Door not opening easily will be resolved by removing the micowave oven top cover with a tamper proof torx head, replacing the door switch and reinstalling the top cover.
Jan 19, 2010 | Panasonic Microwave Ovens
NN-T774 INVERTER STOPPED WORKING AFTER 4 WEEKS
Check to make sure one of the plastic hooks on the door was not broken off. If both door hook latches are functional then the most likely cause of your problem is one of the latch switches located behind the control panel. These switches will fail if the oven user opens the door frequently BEFORE the cook cycle ends. Always push STOP/RESET before opening any microwave oven door.
Dec 30, 2009 | Panasonic Microwave Ovens
The door won't latch closed and the door release button pushes all the way in
I have the NN-T994 SFR model and it had a switch that was staying depressed. I removed the screws to (in my case) the stainless steel cabinet, removed the cabinet and unhooked the wires to lay it aside. Found that the switch was cracked or broken, glued it back exactly as it was, then put the cabinet back on and it fixed it! Now about a year later, I have another problem...oh well. Hope this works on yours.
Sep 28, 2009 | Panasonic NN-T990SA Microwave Oven
My Panasonic nn-s262 fan and light not working. All other functions are operational. Is there a fuse in the microwave that needs replacement?
Hello, you will need to take the cover off the microwave and look for a fuse internally which should be mounted onto a pcb or electronic board.
NOTE: Be very careful if the microwave is stainless steel as they are very sharp.
Jun 18, 2009 | Panasonic NN-S262SF Microwave Oven
Microwave Ovens Logo
1,278 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
