Question about Nokia 6300 Cellular Phone
I just got my 6300 and i noticed that everytime i use it, it looks like its getting warm. how this happen? or is something to do with the steel case of my model
My 6300 gets warm when i used it, is it a normal thing?
  • lhenz Jun 13, 2008
    oh i see now thanx for that helpful info to me...
  • 94 Answers
Ya thats ok when u use ur cell phone it gets warm as u r transmitting signals 2 cell site and ur battery provieds current which is used by ur cell componets and they get heated up , u might be thinking why other cells dont get that much heat as ur cell body is metal and others r plastic body. hope u r satisfy with my ans,.
Posted on May 26, 2008
My Acer z5600 just shuts off while I'm doing something without any notice.I gets very hot at the top of the screen and then shuts off without warning.The screen just goes black and I can not turn
Your processor is overheating. Or the fan for the CPU is dead or the way to eject the warm air is blocked. Try to work with your laptop on a table, if the problem persists, is the fan other way you have to work everytime on the table.
Aug 06, 2012 | Acer Aspire Z5600 PC Desktop
Tip
How to keep your fridge clean
Everytime you are waiting for the kettle to boil or waiting for something to warm up in the microwave, even if it is only 1 or 2 minutes, use this time to open your fridge and wipe the bits of the shelf that you can see with a damp cloth or piece of kitchen towel. Just one shelf. Just one minute.
At the end of the week, notice how clean your fridge is looking and wipe down the inside of the fridge door too.
on Sep 12, 2010 | Refrigerators
Hi there! My acer laptop aspire 4736z built-in microphone is not working. But I was able to use this before. i just don't know what happened to the microphone.It says that "no microphone has been...
Only two things could have happened ....
One- the mic is broken and you need to get it replace
or
Two- You might need a driver to help the pc to communicate with your mic....(Whats a driver? A driver is a light weight software that helps the windows to notice a device that is attached to the pc)....
the driver can be found at the company's website under the title "Drivers and Support"...... in this case you would go to acer.com to look for a driver
Apr 05, 2011 | Acer Aspire 4520-5582 Notebook
We have had sears tech's here 3 seperate ocassions. They replaced a circut board, thermostat, and heater on 3 seperate occasions. Today I noticed the refigerator getting warm, looked and the freezer side...
you have an airflow problem in the freezer. Is something blocking the vent in the freezer compartment? cold air is produced in the freezer section and flows to refrigerated side through air vents. If they are blocked, the air cannot flow from the freezer and it will freeze over. Not a major problem, just move your stuff around.
Nov 24, 2010 | GE GSH25JSTSS Stainless Steel Side by Side...
I have forgotten my memory card password for nokia 6300
My dear:
Soft Reset will clear pending errors and bring your mobile to an initial state by restoring Factory setting. To operate this function on your mobile, the shortcut is: *#7380#
It may happen that despite you have restored your mobile to factory setting, the error still exist. In this case, it is recommended that you opt for Hard reset
Enter the code: *#7370# and press Yes to confirm initialization.
Important Notice: Before making a Hard reset better backup all your important information: contacts , memo...etc
have a nice day brother:
Aug 17, 2010 | Nokia 6300 Cellular Phone
New maytag washer
hi there,
since your washer is under warranty, have a tech take a look at it.
sounds like you may have a loose belt.
is there an error message on the display?
Sep 10, 2008 | Maytag Neptune MAH5500B Front Load Washer
Transmission trouble
Transmission model is a 4R70W,totally electronic,no vacuum to the trans.A common failure on that transmission is the 1-2 accumulator springs...they break,causing a harsh 1-2 upshift.An accumulator is a mechanical/hydraulic assembly also called an accumulator piston.It is made from steel with rubber lip seals bonded to the steel.The accumulator piston takes a certain portion of the hydraiulic fluid produced when the 1-2 upshift happens,and strokes up and down with springs providing resistance.It acts as a hydraulic shock absorber for the 1-2 upshift,providing cushion.When the springs break,it no longer provides shock absorption,hence the harsh upshift.It is located just inside the trans pan,on the passenger side front of the case.It is retained in the case with a cover and a round snap ring about 2" in diameter.A new piston and springs can be purchased from a transmission repair shop,or better yet,have them check the assembly for broken springs.Good luck
Sep 04, 2008 | 1999 Ford Crown Victoria
DRYER MAX Dryer Balls Dents all over Stainless Steel Drum of New Dryer??
if the dings are inside the drum and they look like someone took a hammer and hit the inside of the drum then it's what you put in it but if the dings are comming enward twards you then there's something hitting it from outside the drum. and if that be the case call the store were you got it and have someone come out that is if it has a warnnity and if the dings go out twards the dryer then contact the person who sold you the dyer max balls and tell them you won't payed for a new dryer you may have to take them to court and then again you will have to prove that the balls did it
Jun 13, 2008 | Dryers
Problem with bluetooth headset
just purchased Nokia 6300 cell phone and connected it with my bluetooth headset Samsung Wep200. As my new phone has advanced voice call, everytime the headset's button gets pressed accidentally even once and someone is talking, it starts calling on it's own. Is there any way to disarm the advanced voice calling? Have the same problem? Click Here
Dec 10, 2007 | Nokia 6300 Cellular Phone
GE Profile- Freezer/ Fridge at 56 wont go cooler!
check freezer for frost build up and if fan is blowing, check condenser, make sure its clean, and fan blowing, check vents in refrig. make sure no blockage, controls should be in the middle setting, check make sure compressor is running
Aug 25, 2007 | GE Profile PSW26P Stainless Steel Side by...
Nokia 6300 Cellular Phone Logo
24 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
