Question about Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag
Removal of blade from black & decker lawn mower gx530
I used penetrating oil for weeks and am still unable to remove the blade from the lawnmower gx 530. Any suggestions of how to do it?
thanks
  • pwillie27 Jun 25, 2008
    B&D MM850 - Extreme vibration - I tried to remove Blade.
    The blade is loose on the spindle. How do I remove Blade?
    The retaining nut free wheels in both directions.
    This mower belongs to a neighbor widow lady. I would like
    to help her. HELP
    pwillie27@yahoo.com
    Champion:
  • 313 Answers
I used impact gun with 3<4 socket and run the impact in reverse
Posted on May 29, 2008
Black and decker electric mower hums but blade does not turn. appears the brake is not releasing for the blade.
Something has the motor unable to turn. Do not turn on till you locate the source of the problem lest you burn it out.
Aug 02, 2016 | Black and Decker USA Black & Decker MM1800...
How do I remove the blade and the sprocket piece that holds the blade on?
looks like it might have a pin thru the shaft then use a gear puller.lots of penetrating oil too
May 08, 2015 | Briggs & Stratton Briggs Stratton...
Suddenly cut out whilst mowing the lawn. now wont start, pull cord stiff to pull
Something just like this happened earlier this year with my pressure washer. This is what I did to fix it and now it runs great. Check the oil. If it's black or feels the least bit tacky, drain a pint or two of the oil out and re-add that amount of Marvel Mystery Oil. Now, attempt to pull the cord all the way out, but slowly at first. It should get easier to pull after about 5 pulls. If the mower restarts, let it run for 10 minutes until the Mystery Oil is hot and has cycled around inside the engine. Then drain that oil and refill it with a quality brand of oil. To top it off, either clean or replace the air filter, and put a shotglass of Lucas gas & injector cleaner into the mower's full gas tank. I also do this to my lawnmower and weedeater. It works wonders. BTW...If you're unable to turn the engine over by pulling the cord, remove the spark plug and tilt the mower up, so you can turn the blade easily by hand (use gloves). BUT FIRST MAKE SURE THAT SPARK PLUG IS REMOVED. REMEMBER... SAFETY FIRST! Let us know if this helped you any.
Jun 29, 2014 | Garden
My 24 volt lawn mower is all of a sudden not working, it is just over 2 years old. You can hear it but the noise it was giving off is missing?? It doesn not have the same sound. The blade is turning, I...
If the blade is turning it should cut grass. Try mowing. If it's not cutting the grass then the blade is not turning, or is no longer turning at the proper speed. Look for a fuse or circuit breaker.But after 2 years the battery may have a problem. Try the manufacturers website for help: http://www.blackanddecker.com/en-us/support
Sep 24, 2017 | Black & Decker Black Decker Cordless 24...
Pull cord wont pull,briggs 500 series
Pull the spark plug out and see if it isnt hydro locked. Someone might have overfilled the oil or the carb float may have stuck open and filled the intake with gas!
If the recoil is still stuck you can remove it from the mower and try it without any load on it. Still stuck? The unit might be rusted solid!
You can spray a little penetrating oil into it but be careful.....the oil will soak the pull cord which should be cleaned and degreased immediately following using the penetrating oil.
Jun 22, 2010 | Briggs & Stratton Briggs Stratton...
Broken Belt on a overeign SLM 1500. Have replacement belt but am unable to get the blade/plastic blade off its shaft. Any suggestions would be appreciated
I am not sure what an over reign SLM 1500 is and I have never seen a power mower with a plastic blade but in order to remove the lower belt guard from most walk-behind, self propelled lawnmowers so equipped, it is necessary to remove the blade adapter from the bottom of the engine shaft to allow the guard to slide off.
To remove the blade adapter, tip the mower to where you can spray some penetrating oil on the shaft above it and let it soak for a little while. When you think it has had sufficient time to soak down between the shaft and adapter, set it up on your work bench if you have one available or you can do this on the ground as well. Tip the mower back on the handle bar (this will keep your oil from running out into your air filter and clogging it), secure it in the fully tipped back position, take a small hammer and tap downward on the blade adapter while pulling downward, away from the engine at the same time. Use caution not to strike it so hard as to damage or break it. They usually slide of with just a little bit of effort. Once the adapter is off you can easily remove the plastic guard. When reassembling it, I always use a little anti-seize on the adapter to make it easier to remove next time.
Oct 27, 2009 | Garden
Mower Blades
most lawnmower shops can help you prob just a worn keyway ! or goto black&decker.com for closest repair shop?
Aug 27, 2009 | Electric Lawn Mower
Lawnmower blade turns but does not cut
You have either bent the blade and its to high to cut or you need to sharpen the blade with a grinder.
Aug 01, 2009 | Black & Decker Lawn Hog 18-Inch 12 Amp...
How to remove blades from black and decker lawn mower
all switch off for safety. hold the blade & turn nut to counter clockwise. i use impact gun. socket 3/4".
Jul 22, 2008 | Black & Decker 19" Electric Lawnhog...
Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag Logo
356 people viewed this question
Top Black & Decker Garden Experts
Jim Parker
Jim Parker
Nick Olsen
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
