Question about Craftsman Garden
How do i adjust the mower blades on a craftsman 917.270311
  • 333 Answers
I think all you can do is adjust the deck. That would be with the 4 wheels around the outside of deck. And posibly the linkage from mower to deck. One side is adjustable. But I think I know what you are talking about. One of the blades is cutting deeper? Or the outside edge is lower than the other side?
First of all tire pressure is number one on even cuts.
Next If it is one blade then it could be bent or the bearing could be going out on it. Check them out by shaking em to see if it wobbles. Or could be the deck bent. If none of these are right. Then you can take the bearing assymbly off and adjust them individualy using washers in betweent the jack shafts and deck.
Posted on Oct 02, 2010
  • 6 Answers
SOURCE: how to install mower deck belt on a lt1000 craftsman riding mower
The manual will cover it.
http://www.disruptit.com/manuals/L0104168.pdf
Posted on Apr 06, 2009
  • 376 Answers
SOURCE: Craftsman 42 inch riding lawn mower is not cutting evenly
The first thing to check is your blades. If one is bent, it will never cut even. It happens a lot hitting roots, antbeds, etc. Mulching blades will bend easier than a straight blade. It's best to take them off and lay one on top of the other to see if they're bent.
Posted on May 25, 2009
wadembly
  • 475 Answers
SOURCE: Craftsman riding mower blades will not engage
maybe the safty switch under seat might be starting to go out if that switch doesn't work the blades wont come on at all for safety
Posted on Jun 28, 2009
  • 13 Answers
SOURCE: nothing happens when you turn on the lawn mower
Check your seat, drive safety switches. Can you turn the engine with jumper cables attached to the starter? It won't start, but should turn over, one of your safety switches is not working.
Posted on Apr 16, 2010
saailer
  • 1868 Answers
SOURCE: craftsman riding mower-what year was it made
Hello! The 917= American Yard Products...A major supplier to Sears...The first six digits of the SN#...00/00/00= date of manufacture...In your case...May,1,1997...
Guru.....................Saailer
Posted on Jul 08, 2010
Testimonial: "Thank you very much!"
i believe there is an adjustable rod on each side to adjust for evenness. loosen the retaining nut and turn what ever way you are wanting to go.
Jun 06, 2016 | Craftsman Garden
Why does my blade drive belt on my riding mower not stay tight
You likely have a bearing going bad causing the belt to slip and wear out, or you are not getting the adjustment tight enough. (most use springs these days)
May 15, 2014 | Craftsman Garden
I have a Craftsman SL3500 42" riding lwan mower. the two blads make uneven paths ans the left blade makes a cut about 1/4" lower than the right blade. What do I do?
You should be using a up lift blade it will help by sucking up the grass to be cut. You should have an adjust on both sides of the blade deck . As for the strip check to see if you have a wheel behind the mower deck. If you do it might be the cause for mower leaving a strip uncut . Sears has been noted for putting wheels in the path of the blade area and smashing the grass down . That is also why I suggest to use an up draft blade it should **** the grass back up again so you can cut it.
Oct 07, 2013 | Craftsman Garden
Craftsman rideing lawn mower will not go in reverse
check the linkage might be out of adjustment also for the blades check the safety switches
Apr 23, 2012 | Craftsman Garden
HOW TO ADJUST THE CUTTING BLADE TENSION OF THE MOWER BELT.
There is no adjustment on the Craftsman mower belt tension. The tension is maintained by a spring. If the belt is to loose you either have the wrong belt or something is broken like a mandrel housing that holds the fixed pulleys in place.
Oct 10, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
How do I adjust blade drive belt tension on Craftsman G4000 riding mower/tractor?
Belt was excessively worn and after replacement and adjustments made all ran well. Thnaks.
Sep 02, 2009 | Craftsman Garden
Blades won't disengage
When the mower is off and the clutch is disengaged you should not be able to physically turn the blade(s) if you can then you need to adjust the blade brake (look on the mower deck and you should see what appears to be a brake pad). Your owners manual will show you how to adjust. If you need a copy of the owners manual then I would suggest going to www.managemyhome.com and downloading a free copy of the manual for your mower (Need model number which starts is located under the seat).
Jul 27, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Cuts lawn uneven, one side shorter than other
Was it cutting uneven before you changed blades? If so, you may not have gotten the blade on the shaft correctly. There is an adjustment in the center of the deck hanger on each side. You can turn the 9/16 nut up or down on each side to level it out.
May 28, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
May 25, 2009 | Craftsman 42 in. Precision Cut Plus 24hp...
Garden Logo
91 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
