Question about Whirlpool ACD052MM Air Conditioner
For some reason my ac was working fin until I came home tonight .It really does not blow any air out and also it keeps making like a poping sound .I have cleaned the air filter etc .And its only about three years old .. Thanks Kenny
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 23 Answers
Its one of a few things, your fan motor, or fan capacitor, or also possible fan control. but popping could even be the fan disconnected from the motor, can you unplug it and safely take it apart remembering were each piece came from screw etc, an let me know what you see inside (do not touch or test the capacitor with discharging it first).
Posted on Oct 02, 2010
The unit is blowing hot air it will blow cool and then make a loud noise and start blowing heat.
Sounds like your ac is kicking out on high limit or internal overload. Several factors come in to play. Outdoor coil fins blocked or bent.
Check temp of compressor.
Aug 29, 2014 | Heating & Cooling
2006 Subaru Forester. AC always runs properly cool except once or twice a day when air turns warm for about 1-2 minutes. Then back to normal.
IT may be that there is ice forming on the evaporator in the car. This prevents the ac from working as the thermostat setting is affected and the ac shuts down until the ice clears and the thermostat gets a new reading. Check that the ac evaporator core fins are clean and free of gunk build up. Some times you may be a clink sound as the ice breaks away and falls into the ac box
Feb 14, 2014 | 2006 Subaru Forester
Fan blows room temp air, I can hear the AC kick in but it only runs for about 30sec to 1min before cutting out and making a sputtering sound that shakes the whole unit. Then it just goes back to blowing...
check you condenser fan motor make sure it turns on, if ok you must clean the fins on the outside unit,with a water hose , make sure you turn power off first before taking a water hose to unit
Aug 30, 2009 | EdgeStar AP420HS Portable Air Conditioner
Ac fan on, blowing air, but not cold
Check outside unit if unit and compressor are running feel the large line to see if it is cold. If compressor is running and line is not cold possible charge problems. You may have a capacitor problem outside. they go out quite often. You can change this yourself, Open up outside unit and the cap is the silver bullet with terminals out the top. Bad cap can cause compressor to not operate and also the fan. You need to clean the coil inside or at leat check the coil to see if it is clean. You can clean theis with a toilet brush do not go against the coil bit brush with the fins. You may need to call a service tech but try these options first. russ
Aug 15, 2009 | Heating & Cooling
Freezer and fridge not cooling properly
Clean it up. Check under it and behind, clean ,vacume and or blow out all dust and check the fins on the bottom, a soft brush and portable air compressor work really well but very dusty, take out side if possible, or just vacume really well.
Jan 26, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Air flow for AC and vent not working right for 1995 Sonoma
sound like heater box has issues. doies the heater box have trash in it, like leaves???? It might be a vacuum line dry rottering and making the dampher not work properally. I need to be there to really check it out??????
Dec 03, 2008 | 1995 GMC Sonoma
Hums and freezes up????
The fan motor must have been stopping. If the fan stops, for sure the fins will freeze because there is no air flowing. common Fan motor problems defective bearing or bushing and starting condenser. If the bearing is defective, it will heat up and seize. Have the fan motor checked. The fact that the fins are freezing, means that there is enough freon and the compressor is working.
May 29, 2007 | Frigidaire FAS155K1 Air Conditioner
Whirlpool ACD052MM Air Conditioner Logo
Top Whirlpool Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Tim Whalen
Are you a Whirlpool Heating and Cooling Expert? Answer questions, earn points and help others
