Question about Dyson DC07 Animal Bagless Upright Cyclonic Vacuum
I have no suction from the bottom - Dyson DC07 Animal Bagless Upright Cyclonic Vacuum
  • 377 Answers
If there are no obvious air leaks, check to see that the belt that turns the beater brush is not broken and that the beater brush has not frozen up. Remove the beater brush and clean it, spraying a bit of WD40 at each end by the hard rubber pieces that hold it in place. Turn the beater brush by hand to be sure it moves freely around the rubber pieces. When you reassemble, make sure the belt is properly installed.
Posted on Oct 02, 2010
Too much suction on smooth surface
Check the wheels on the bottom plate to make sure they are not allowing the bottom to sit flat on the floor. The wheels must keep maintain a gap between the plate and floor or it will suck down like a suction cup.
Jan 26, 2014 | Dyson DC14 Animal Bagless Upright Cyclonic...
Lost suction from cleaning dyson roller brush
This is actually a very common problem that we see for repair on Dyson Vacuums. Usually what happens is that the vacuum doesn't loose suction like most people think. You can test this by feeling the suction power on the hose. If you have suction coming from here, then most likely the machine isn't clogged.
What happens is that the bottom soleplate on the vacuum cleaner can easily be re-installed the incorrect way. If this happens the brushes on the vacuum cleaner can not even hit the carpet, which makes the vacuum feel like it's not picking up, but when the suction is tested from the hose it has plenty.
We see a lot of Dysons come in for repair with this problem. The bottom plate is not flush with the rest of the vacuum cleaner. Here's a picture of what an improperly installed bottom soleplate looks like:
When the bottom plate is put back on the vacuum, you should make sure that the bottom plate (the purple colored part in the picture) is flush with the agitator housing tray (red part in the picture). If not, the brushes will not hit the carpeting, and the vacuum won't really pick up anything.
This is how a correctly installed bottom soleplate should look like:
This should be the first thing you should check on your vacuum cleaner as it's the easiest and most common solution. If this doesn't fix your Dyson, please just use the Clarification Request form, and let me know which exact Dyson model you have, and whether the vacuum has suction power from the hose, whether the brushes turn when set to the carpet setting, and how old the vacuum is. I'd be happy to try and further diagnosis the problem with you.
I hope that this was helpful to you. If it helped you, please be sure to rate the repair as helpful by clicking the thumbs up icons in the top right hand corner.
Thank you very much,
Chris J.
GoVacuum
Mar 31, 2010 | Vacuums
Our Dirt Devil D2 bottom has no suction
I would check the bottom of the unit to see if there is any blockage. I don't know if this unit has a switch that you set to switch from hose to floor. If so I would set it to floor and see if there is any suction in the hose, indicating a switching problem. If there is no suction in the hose, I would still check the bottom of the unit and disassemble it as much as you feel comfortable to see if you can see any blockage. Good luck!
Mar 13, 2010 | Dirt Devil Reaction Twin Cyclone Upright...
My vacuum tools have very weak suction.
There is a foam ring filter in the bottom of the canister that collects the dirt. It screws off of the bottom on the canister. Take outside and shake it out. It fixed our suction problem.
Jan 31, 2010 | Bissell 3576 CleanView II Bagless Upright...
My DC17 suction hose doesn't have any suction occasionally.
check the seal on the filter is not broken,And check for any blockage at the bottom of the pickup pipe.
Nov 18, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
No suction from bottom, the suction is all coming from the hose at the top
At the bottom you have a plasic plate with a yellow screw remove that and you will find that the suction tube is blocked.
Nov 08, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
No suction at the twirling brush
take a coat hanger and clean out under ...take off the brushes theres a small tunnel gets stopped up..
Sep 20, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
No suction or very little
Make sure you have a good bag installed in the vacuum and the door is properly in place. Remove the attachment hose from the bag chamber and turn the machine on. You should have good suction coming from the hose inlet. If you don't you have a problem in the bag chamber. Bad bag, door is not on correct, door is defective, dirty secondary filter.
Connect the hose back to the machine and pull the other end out from the bottom, and turn the machine on. You should have good suction there. If you don't you have a clog or hole in the attachment hose and it needs to be unclogged or relplaced.
Reconnect the to the bottom. Flip the mahine upside down. Take the screws out of the bottom plate and remove. Remove the brushroller and belt. Turn the machine on and you should have suction at the inlet coming off the brushhousing. It you don't, then you have a clog in the nozzle hose and it needs to be removed. It will probably be more accessable from the bottom side since that is the way that it entered.
Sometimes a suction problem can be confused with an brush problem. The belts on that machine should be replaced every 6 to 8 months because they will strentch and wear. This is an inexpensive maitainance that will dramatically improve its function. Part Numbers are 38528-035 and 38528-034
Nov 21, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Low Suction/No Soap
Check the seal at the bottom of the dispenser, it needs to be on the valve not sitting in the hole, part 2101795 if you need to replace it. If suction is low, check the filter on the bottom of the tank lid, if clogged, suction will be low. Also check window gasket, sits between the tank and the nozzle window, if missing, you won't have any suction part #2104052.
Sep 28, 2007 | Bissell 7901-1 ProHeat Scotchgard Upright...
Dyson DC07 Animal Bagless Upright Cyclonic Vacuum Logo
85 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
