User manual for radio shack SSM-60 stereo sound mixer
PyroPCMan
  • 405 Answers
SOURCE: Radio Shack 17-6020 Paging system
Good Day,
See this link for all available documentation:
http://support.radioshack.com/productinfo/DocumentResults.asp?sku_id=17-6020&Name=Pagers&Reuse=N
Hope this helps
Posted on Jul 09, 2008
smartr10U
  • 1305 Answers
SOURCE: PRO-60 RADIO SHACK SCANNER
Here is the lin to the manual download... CLICK HERE
Posted on May 31, 2009
jyackle5
  • 8197 Answers
SOURCE: I need to find the
You can det the manual here. on link below.
http://www.radioshack.com/graphics/uc/rsk/Support/ProductManuals/3202056_PM_EN.pdf
Posted on Dec 22, 2009
SOURCE: just bougth this mixer (psm-8080) the guy who
Hello my friend
Ialso have the PSM 80 80 Professional Stereo Mixer & the manual
Posted on Aug 11, 2010
technical114
  • 1851 Answers
SOURCE: Realistic (Radio Shack) model STA-430 AM/FM Stereo
If the receiver is a new one (a couple of years) I suggest you don't replace the balance potentiometer. It's a potentiometer with rare use so the inner carbon film can't be destroyed. I suggest you to open the case and use a contact cleaner spray (clear, without oil) and spray direct at the potentiometer. Turn it all the way from left to right many times. When it will come dry you will see the diference. As far as the suggestion for clear (without oil) contact cleaner spray, I insist on that because the lubricating oil will cause a trap for the dust and will ask for cleaning again and again. Also for potentiometers with rare use there is no need for lubricating oil.
I think that this solution is much easier than chanching a potentiometer, since the device is not too old.
In case of a problem or clarification, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Posted on Aug 30, 2010
Where can i get manual for radio shack SSM-8030 audio mixer?
Does your audio-mixer have "pan" control on each input channel?
Pan the channel from "100%-left" to "100%-right".
What about the main output from the mixer?
Does it feed into a stereo-mixer?
Can you adjust the gain on either the left or right channel?
May 10, 2014 | Audio Players & Recorders
I need help setting-up my sound system with following equipment listed below:
Wow....what you have here is a total system design. I really feel you need to get a professional in your area to help you out. There has to be a buddy of yours that knows enough to help out. There are just way too many variables in this that are unanswered. Amp channels, amp output, speaker impedance, other equipment needing balanced or unbalanced, type of jacks, stereo/mono, length of runs, power requirements. It would take me hours to look up the specs of your equip, a couple hours to design and hours of questions back and forth. At best if you let me know where you are I may be able to set you up with someone local to your area.
Nov 14, 2013 | Car Audio & Video
My optimus ssm-50 does not fade in or fade out
It is probably a bad slide pot. Try this Radio Shack link for help and the manual: http://support.radioshack.com/support_audio/40119.htm
This link is the manual but it did not work for me. http://support.radioshack.com/support_audio/doc62/62615.pdf
Aug 26, 2013 | Audio Players & Recorders
How to listen thru headphones using a yamaha emx 88 mixer
Did sound for a southern gospel group, using a yorkville powered mixer. Not familiar with your mixer, but, on the Yorkville I had an unused 1/4" line level output with the monitor mix on it. I bought a cigar-sized, 3-channel headphone amplifier / splitter from Radio Shack, called a Boosteroo. Has 1/8" stereo plug that I adapted to the mono output, with a 1/8" stereo to 1/4" mono adaptor. It receives the line level (monitor in our case) signal and supports up to qty 3 - 1/8" plug headphones. Battery operated. No volume control, so I added an inline dial (rheostat) volume control cable. Can't pull up on Radio Shack, now, but, found it available, elsewhere, online. Worked great for me!
Good Luck SdDude
Feb 19, 2012 | Yamaha Emx88s Powered PA Mixer System
How to connect a Behringer XENYX 2442FX Mixer to a laptop
you need a cable with two A3F  XLR s going to a 1/8" stereo phone plug, male. plug the XLRs into the Main out L&R on the mixer. plug the 1/8" into the LINE Input on the laptop. You should be able to get the cable from any music store,or Radio Shack. below is a link to the manual,in case you don't have one. Good Luck!
http://www.behringer.com/assets/1622FX_P0557_M_EN.pdf
Aug 30, 2011 | Behringer XENYX 2442FX Mixer
How do i get my sound to work
Here is the user manual: http://office.manualsonline.com/manuals/mfg/hewlettpackard_1/wf1907.html
You will need the audio cable, mini stereo phone jacks at both ends, Radio Shack should have them.
Apr 15, 2010 | HP Compaq WF1907 Monitor
Just bougth this mixer (psm-8080) the guy who
Hello my friend
Feb 03, 2010 | Audio Players & Recorders
Pioneer djm 800 will only play through 2 channels on mono??
try to clean your fader with contact cleaner and move it many times after cleaning -check your connection plugs(buy it from radio shack near you.
Apr 11, 2009 | Audio Players & Recorders
481 people viewed this question
 Grubhead
Grubhead
