Refrigerators Logo
Posted on May 26, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Any tips on how to clean the graphite gray doors on a viking fridge? Any regular cleaning products leave stains and fingerprints.....
Anonymous
Level 3:
  • Master 828 Answers
  • Posted on May 26, 2008
Anonymous
Master
Level 3:
Answers
828
Questions
0
Helped
454785
Points
1944
Have you tried a window cleaning product?
2answers
I have a Viking pro model oven VGIC3064BSS that doesn't light fully
Viking Gas Range Burners Won't Light? Here's What To Do... We'll discuss how to properly check the power sources and igniter when your Viking gas range burners won't light. We'll also provide a step-by-step guide illustrating how to clean Viking range burners with the right methods and materials.
Check For Power And Loose Connections
Are your Viking stove burners not igniting on demand? This may be more of a power issue and not a range malfunction. Even though you have a gas range, electricity is still required to ignite the burner. Here's how to check your stove's electrical sources to make sure they're functioning properly:
  • Make sure the stove is correctly plugged into a functioning outlet.
  • Check the stove's circuit breaker or fuse in your home's circuit breaker or fuse box. Reposition a tripped breaker or replace a blown fuse.
  • Refrain from using an extension cord to power your range. Most cords can't safely transmit the electricity required to power the stove.
How To Clean Viking Range Burners
Despite our best efforts, cooking spills and accidents can leave range burners compromised. Liquids, grease, and grime that go unnoticed during a hasty post-dinner cleaning can impair range components, resulting in burners that won't light.
This step-by-step guide provides Viking range cleaning tips that clean your burners and other stove components safely and effectively:
Grates:
Remove the grates and soak them in a sink of hot, soapy water for 15-20 minutes. For stubborn stains, add ammonia to the soaking liquid or scrub with Soft Scrub cleanser. Rinse with hot, soapy water and dry completely before replacing.
Burner Caps:
  1. Remove the caps by lifting straight upward.
  2. Scrub with hot, soapy water and a non-abrasive pad, using Soft Scrub cleanser for tougher stains.
  3. For persistent staining, place burner caps outside on a sheet of newspaper. Spray with Easy-Off Fume Free Max oven cleaner and allow to sit for 1-2 hours.
  4. Rinse with hot, soapy water.
  5. Allow caps to dry completely before replacing.
Burner Heads:
  1. Remove burner heads by lifting gently upward.
  2. Combine Bar Keeper's Friend and water to make a paste.
  3. Apply the paste to the burner head and leave for 30 minutes, resting on a clean towel.
  4. Scrub the paste into the burner head with a non-abrasive pad to remove stains.
  5. Rinse with hot, soapy water.
  6. Allow to dry completely.
tip
How to clean an LCD TV
<span>An LCD screens must be cleaned as it attracts dust like a magnet. Cleaning is risky as the screens are very sensitive and there are chances of you damaging the screen if you don't know the proper method to clean it. To help you in this read the article below to the various tips on cleaning the LCD TV.</span> <b>Tips On Cleaning LCD TV</b> <b>Basic Facts About LCDs</b> <ul> <li>LCD screens or displays should not be cleaned through normal methods, as they are not glass. LCD or liquid crystal display is a soft film and it can be damaged through improper cleaning agents.</li> <li>The popularity of LCD TV's is on a rise as they can be can be run on low battery power and also have<a href="http://lifestyle.iloveindia.com/lounge/how-to-clean-lcd-tv-8061.html#"><span>sharp</span></a> picture clarity.</li></ul> <b>LCD Screens Problems</b> <ul> <li>LCD screens regularly gather dust and smudges and sometimes fingerprints and ink markings.</li> <li>Cleaning the screens with a <a href="http://lifestyle.iloveindia.com/lounge/how-to-clean-lcd-tv-8061.html#"><span>paper</span></a> towel, dishcloth or tap water can do considerable damage, as the screens are very sensitive. It can cause clouding and can cause damage to the pixels.</li> <li>Tap water contains chemicals like chloride and wiping the screens with it can leave a residue on the screen.</li></ul> <b>Cleaning Tips And Guidelines</b> <ul> <li>The LCD TV must be cleaned regularly for you to enjoy the proper clarity of the display.</li> <li>First of all, turn off the LCD TV and examine the condition of the screen.</li> <li>Note the smudges and the areas to be cleaned.</li> <li>To remove dusts use a microfiber cloth and brush off the dust particles.</li> <li>It is best to use proper cleaning solutions that come with LCD cleaning kits. However, you can mix one part of isopropyl alcohol with one part of distilled water and using cotton or microfiber cloth, clean the screen. Another cleaning solution that can be made at home to clean LCD TV's is to mix one part of vinegar in one part of water. Pour this solution on a soft cloth and then wipe the screen.</li> <li>Take care not to spray any sort of cleaning solutions directly onto the screen. Instead take it on a piece of cloth and then wipe.</li> <li>Wipe the screen in a circular motion and be very gentle. Don't press hard.</li> <li>Also do not touch the screen with your fingers or there are chances of leaving oily prints.</li> <li>Rub a soft cotton dry cloth to completely remove excess liquid from the screen as the moisture may damage it.</li> <li>Before switching back the TV on, let the screen dry completely.</li> <li>If some stains or marks are hard to remove, don't apply pressure to remove it. Instead, repeat the cleaning procedure several times to get rid of it. For ink marks and other hard stains, you have to invest in special cleaners.</li> <li>To clean the dirt from the edges or corners use a Q-tip. Dip one end of the Q-tip in the cleaning solution and squeeze out the excess moisture from the cotton tip. Now gently drag this tip along the edges.</li> <li>Do not use cleaning solutions that contain ammonia, ethyl alcohol, acetone, toluene, ethyl acid, or methyl chloride. These chemicals can react with the LCD screen materials and damage it.</li></ul>
on Jan 18, 2011 • Televison & Video
1helpful
Please tell me how to get water stains off the front a stainless steel fridge. I have tried everything I can think of.
James, If really stubborn stains, you may have to use a chrome polish and buff. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Cleaning Stainless Steel Appliances Cookware and More
Removing stains from stainless steel refrigerator
How to Clean Stainless Steel Appliances Easy Kitchen Cleaning Ideas That...
Coulter Cleanup Refrigerator Rejuvenation
Washer leaves oil type stain on clothes.what could be cause?
Stains on clothes from this model of washer are usually caused by the door boot or the tub bearing going out. I recommend cleaning off the surface of the door boot and if you still get stained clothes I recommend having the rear tub & basket checked. I am also sending you more troubleshooting tips in the image below.
Soap stains on dishes
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Stains on black enanamel stove top
use caustic soda power mixed with water and wallpater paste so its a thin jelly . apply with a brush and leave over night . rince with warm water on a clean cloth. use rubber gloves and glasses for protection
500g caustic powder
2 pints water
add wallpaper paste powder little at a time till jelly like
How can stains from stainless steel be removed
their are many products now for stainless steel from dollar shop wipes to $15 commercial all work great if ur stains are from fingerprints the cheep wipes work great for food like chicken or food dye disinfect or clean first than use ss wipes
Fingerprint stains on stainless steel fridge doors
going with the grain( s/s has grain just like wood product) try cleaning with a stainles steel cleanlingcloth and some wd40, this will remove any defect in th metal go with the grain not across you will leave rub marks if going avcross t he grain!!
3helpful
How to clean LG Titanium fridge doors??
3M 7447 pads get at auto parts store or more aggressive 180 grit sandpaper going with the grain of course. For daily cleaning use DeBruce Polish, it is non-toxic and odorless. DeBruce polish is also non-abrasive, also use DeBruce Polish on glass/ceramic cook tops. We get DeBruce Polish at debrucepolish.com
2answers
How to remove smoke stain ?
Try a mild abrasive cleanser like Bon Ami or Soft Scrub and wipe clean.
Top Viking Refrigerators Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Jay Finke
Jay Finke
john h
Are you a Viking Refrigerator Expert? Answer questions, earn points and help others
