Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
I have an rca d52w20, it will come on but the channel buttons, the voulume buttons, and the menu buttons wont do nothing. the power button works but i dont have any sound, and just a fuzzy screen. thanks
  • 1,476 Answers
Tony1318,
All the symtoms you mentioned point to the mainboard as the problem. If you are not an electronic technician you should call a reputable shop to come an fix your unit.
I would think that a reasonable price would be less than $300.00 US.
Thanks for using FixYa and for the great rating.
hardrocko
Posted on Oct 02, 2010
Rca L40FHD41is stuck on menu,cant change input or volume . how to reset the tv???
Unplug the TV for a few minutes it should reset itself.
Make sure the menu button is not stuck, if it is try cleaning the button.
www.aaatvservice.com
Jan 28, 2012 | RCA Televison & Video
Where is the auto convergence button
Hello
From it menu option, suf through and come to automatic convergence display option and press Ok button on the remote control.
The List & Labels part of the setup lets you edit your channel list and choose or create a
personal six-character label for each channel.
Note: Changing List and Labels can be time consuming. You can change these at a later time by accessing the
Setup menu.
1. Press the left or right arrow to scroll through the available channels and choose the
channel you want to edit.
2. Press the down arrow to highlight the In channel list option. Press the left or right arrow
button to add (the box is checked) or remove (the box is unchecked) the channel from the
list.
3. Press the down arrow to highlight the Channel label option. Press the left or right arrow
button to scroll through the available list of 25 most common labels. The last option in
the list allows you to create your own six-character label for the channel (the first letter of
the label is highlighted).
4. Press the 1 or 2 number button to change the first letter of the label.
5. Press the right arrow to highlight the second letter, then press the 1 or 2 number button
to change the second letter, etc...
6. When you are finished creating your label, press OK. For model D34W20, your TV tunes to
the last channel available in your channel list. For models D40W20 and D52W20 only, the
Auto Convergence menu appears next.
Auto Convergence (for models D40W20 and D52W20 only)
Your TV's picture tubes might have been disturbed during delivery or after you moved the TV,
causing the color in your TV to be out of alignment. The colors adjust by starting auto
convergence.
1. Press OK to begin auto convergence.
2. When the auto convergence is complete, the Red center convergence menu appears. The
cross in the middle of the screen should be yellow. If it is not, use the arrow buttons to
move the red cross to overlap the green cross. Press OK when adjustments are complete.
3. The Blue center convergence menu appears with a cyan cross in the middle of the screen. If
it is not, use the arrow buttons to move the blue cross to overlap the green cross. Press OK
(the TV tunes to the last available channel in the channel list).
Ok
Mar 16, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA HDTV D52W20 menu button no longer works.
The front keyboard circuits will need replacement. You can get a new keyboard panel from www.tvrepairworld.com
Jun 27, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
MY RCA D52W20 52" WONT TURN ON!!!!!
Check the fuse on the AC filter board. If you trace the power cord into where it plugs in on the small skinny board located on the right side when looking in the rear there is a fuse on that board. If its completely dead I would suspect that fuse.
Nov 28, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA 52 is los the configuration after a blackout.
One or more of the buttons on the front of the set is bad. Best thing is to take the front panel off. About eight TORX T-20 screws from the back to get the speaker grille and panel off, then three more on the front and the whole panel with the button assembly will come off. Simplest fix is to just pull the plug off and disconnect the button assembly. the remote will still work.
Apr 18, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Access Service menu
Hey there!
Its really easy to do, but write down any settings before you go changing them..
1. Turn off tv.
(use buttons on tv for this)
2. Push volume down and channel down both at the same time, and hold them for about 10 seconds, or until the tv turns on.
Jan 23, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca 53" wont power on, please help
The cicuit board behind the power on and off button needs to be replaced.. good luck everyone
Jan 07, 2009 | RCA D52W19 52" Rear Projection Television
Bad power botton,volume,channel,and menu botton
The buttons in front panel of the tv are bad,part number for these are 268854
Dec 16, 2007 | RCA P52937 52" Rear Projection Television
RCA d52w20?
ok ...first question ... what happens when u push menu?...do you get any osd...on screen display...menues volume.. channel number. HOw bout any sounds... the light comes on and the stays on..?
Dec 03, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Menu wont work, continuos channel search
Usually, this means that something has spilled into the front of the set and has contaminated the pushbuttons. If one of the channel pushbuttons has fluid in it, the set will just sit there searching for channels and will not respond to any other commands. The computer thinks you are pushing the channel button and responds accordingly. When you push another button the computer does nothing because it thinks that you are pressing 2 buttons at the same time. The board should be cleaned and any contaminated pushbuttons replaced by a qualified tech.
Aug 23, 2007 | RCA F36715 36" TV
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
14 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
