Question about Epson Stylus Photo RX700 All-In-One InkJet Printer
Epson CX3650 printer will not work and all the lights are flashing.
My printer, Epson CX3650, is not working, all the lights are flashing on it. I have disconnected all the cables and reconnected, turned off and on again & checked for paper and dust stuck in the printer, but nothing.
Please help me.
Alice
  • Anonymous Jan 06, 2009
    epson 3650 stylis
Inky
  • 691 Answers
SOURCE: epson aculaser c11oo
Best guess would be that the lever on the sensor for the cover that is reported as open has got bent. Get yourself a service manual from http://www.TheServiceManualShop.com and find where the sensor is that is affected. Visually inspect it and ensure it works when the cover is opened/closed. Switches Image
Posted on Apr 24, 2007
mocap
  • 7 Answers
SOURCE: Epson CX3650 Printing Only half a page
This may sound nutty, but I have an epson stylus cx3650, with the same INFURIATING problem. And I think I *may* have just fixed it. and its daft, and simple, but we all know how picky printers can be!
Okay, the paperfeed at the top, on the left hand side is a grey slide, (right in the printer) to hold the paper in place. USE IT to keep the paper straight, it seems, if the paper goes in straight, the whole page is printed. I don't know how or why but it worked for me! ^^ (and this is after the printer was stored in a cupboard for a year, because of this problem!)
Posted on Jan 07, 2008
  • 26 Answers
SOURCE: Epson 1280 Printer breakdown
it is the wasted ink pad, they are full.
to have your printer work again
turn off the printer.
press and hold the ink and paper button while turning on the printer, wait for 5 seconds then release the button and press the paper button for at least 10 sec.
if done correctly , you will see the carriage start moving
Posted on Jan 21, 2008
SOURCE: Epson stylus 880 printer
"Turn the printer on while holding down both the ink and paper buttons. When the paper light flashes release both buttons", then hold down the ink button for approx. half a minute until the printer lights flash again then release it. That resets the printer.”
Posted on Jun 03, 2008
  • 1894 Answers
SOURCE: How to fix paper jam
Please perform the below steps.
1. Switch off the printer and disconnect the power supply. Allow any residual charge inside the all-in-one printer to dissipate before putting your hands or any metal tools inside the chassis.
2.
Pin down the exact location of the jam. The 3 hot spots for a jam are before a sheet completely leaves the paper tray, anywhere between the feed tray and print carriage or between the print carriage and output tray.
3.
Take off the front paper tray if the sheet jammed while still in the front area of the printer. If here, you should be able to see most of the paper.
4.
Pull the sheet with both hands and steady pressure. Do not tug as you might rip the paper, leaving a piece deeper inside the machine.
5.
Open the back panel to reach paper jammed between the feed-tray area and print carriage. Carefully remove the jammed paper.
6.
Use the carriage access door to get at a jam further inside the printer. You may need to remove the print carriage to get to the jam.
7.
Replace all parts and return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch.
CREDITS: nanicool
IF YOU DONT GET FIXED WITH THIS THEN PLEASE REPLY BACK.
I SHALL BE GLAD TO HELP YOU WITH YOUR PROBLEMS.
THANK YOU
REGARDS
SWEET RASCAL
Posted on Jun 28, 2008
ON/OFF LIGHT FLASHING .INK LIGHT ON ,E AND OTHER LIGHTS FLASHING
The Ink Cartridges to be removed and re-inserted correctly power off the printer and then power on again
Jun 24, 2015 | Epson Office Equipment & Supplies
Stop the two red lights on my epson r200
Please try this procedure one more time using the instructions below.
  1. Turn the printer off, and disconnect the interface cable.
  2. Turn the printer back on.
  3. If the error lights disappear, turn the printer off and reconnect the interface cable. Turn the printer back on and try printing again.
  4. If the error lights continue, unplug the printer power cord for a few seconds and reconnect it to a different power outlet.
  5. If the printer is plugged into a power strip or surge protector, try plugging it directly into the outlet.
Note: Also check that the ink cartridges and lids are pushed down fully.
If the problem persists, an unknown printer error has occurred. The printer may require service.
Sep 24, 2014 | Epson Photo Office Equipment & Supplies
Epson CX3650 - local copy works OK, but no print output from PC.PC reports printer is "paused". Have deleted all docs in queue; reset printer; powered down and up again; disconnected/reconnected USB; but...
The problem was solved, or at least made to go away, by running Epson Scan to see if the computer was "talking" to the printer. The test scan was successful and afterwards the printer worked normally and is shown as "ready" on the Control Panel/Printers & Faxes window.
Nov 17, 2009 | Epson Office Equipment & Supplies
I have lost the CD instalation disc. Can you
Support for Epson CX3650 on next site:
http://www.epson.co.uk/Printers-and-All-In-Ones/Inkjet/Epson-Stylus-CX3650/Drivers-Support?supportLandingPage=true
Automatic operating system detection, when wanting to install on the computer used for the downloads.
When wanting to install on a computer with another system, select yours.
Oct 11, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Manunal for epson stylus cx3650
http://safemanuals.com/user-guide-instructions-owner-manual/EPSON/STYLUS%20CX3650-_S
Sep 08, 2009 | Epson Stylus Multifunction Inkjet Printer/...
EPSON Stylus S20 print cartridges not recognised.
Try reinstalling cartridges make sure you remove the yellow strip.Ok turn your printer off and back on while installing cartridges ,if this dosen't work disconnect printer cable then turn printer on then off reconnect cable turn on again also disconnect power to printer then reconnect if all fails call Epson and your warranty may cover this
Aug 27, 2009 | Epson Stylus S20 InkJet Photo Printer...
All the red lights flash and 'E' comes up.
you need SSC services utility to solve the problem and reset the eror
May 25, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Red & Green Lights keep flashing on Epson Stylus Photo1280
I had the same problem. You need to reset the waste ink counter:
1. Turn printer off, unplug power cord. Disconnect computor interface cable (back of the printer).
2. After one minute, reattach power cord, but not the computor interface cable.
3 Hold down the LOAD/EJECT and CLEANING buttons simultaneously (cleaning button has ink drop on it) .
4 Turn printer on. Release all buttons as soon as the paper out light flashes.
5 Quickly press the cleaning button, and hold for 10 sec while paper out light flashes.
6 Release the button and the printer will initialize.
7. Once the initialization is complete, turn the printer off.
8. Reconnect the interface cable.
9. Turn the printer on and try to print your document.
This process worked for me. Good luck!
Feb 01, 2009 | Epson Stylus Photo 1280 InkJet Printer
C42UX problem
An unknown printer error has occurred. Turn the printer off, disconnect the interface cable and turn the printer back on. If error disappears, turn the printer off, reconnect the interface cable and turn the printer back on. If error continues then printer needs service. If printer returns to normal the issue is resolved.
Jun 09, 2008 | Epson Stylus C42UX InkJet Printer
Epson Stylus Photo RX700 All-In-One InkJet Printer Logo
616 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
