Question about EliteGroup P4VMM2 Motherboard
CONNECTIONS TO THE MOTHER BOARD POWER WIRES
I PULLED THE POWER PLUGS OUT OF THE MOTHER BOARD AND CANT HOOK THEM BACK UP COULD YOU HELP
  • Anonymous May 16, 2009
    Scholar:
  • 187 Answers
All of the plugs? Most of them should be straight forward. Thin ones around an inch wide, go to your CD and hard drives, long one around 1cm x 1.5inch goes into the same socket on the board (there will only be one of them). You may also have another socket on the board thats 1cmx1cm and requires 4 pins, there will be one connected to the power supply that fits it. You can find the manual (will contain a diagram for you) at; http://www.ecs.com.tw/ECSWebSite/Downloads/ProductsDetail_Download.aspx?detailid=46&DetailName=New&DetailDesc=P4VMM2%20%20(V1.1A)&CategoryID=1&MenuID=82&LanID=0
Posted on May 29, 2008
How do I re-conect the power on and off switch to the motherboard?
They should be labeled. The Power switch plug should say pwr. The Hard Drive Led should say hdd, etc. Look on the motherboard for the inscribed label.
May 23, 2012 | Computers & Internet
I need to find a wiring diagram for a Polaroid FL-323B television. I took the back off to clean it and the the box that holds the power supply fell and pulled all the wires from the connector that plugs...
Listen to me,u don't need a schamatic diagram for this job.All the wires connectors are matches in sequences.I was an engineer before,i design and fixes alot of these elctronics devices before all the connections are design to fit only one connection,that the connection it going into it.No two wire connections are alike.Just slowly matches up the pins and the sizes of the connectors and just plug it back in.
Mar 02, 2011 | Polaroid Televison & Video
Hello i have a e-machine T3103 the three set of
There is a small block of pins usually on the bottom right corner of the mother board to hook up front panel connections, you will have to read the board around it and somewhere it will tell you which wires go where.
Mar 02, 2010 | E-Machines Computers & Internet
Wont power up
This may help. I have had the same problem from time to time. I took the back off ( slowly don't break the four wires connected to the back) then I cleaned the connections where the battery pins press to the main board.
Jun 12, 2009 | Magellan Meridian Gold GPS Receiver
Replaced mother board, forgot where power switch plugs into
you can look for the power switch terminal by its label.like PW for power button and PLED for power led.reset is RS.
May 20, 2009 | E-Machines eMachines Desktop PC
Mother board
about the small connectors, there is white text printed into the motherboard showing what goes where.
about the drives, check your cables.
May 03, 2008 | Computers & Internet
Emachine W3400/ front panel connections
they have to be plugged in horizontally although it is possible to plug them in vertically because the pins are evenly spaced either way. they are color coded just not like you would expect for example one plug has a green wire and a white wire the green side goes to the green pin and the white side goes to a green pin with a white cross you have to look close because there are several green pins which is what threw me off do this with all three plugs
Apr 19, 2008 | AMD eMachines Desktop System w/ 17'' CRT...
I need to know how to hook up some mother board wires
Hi swiftty6, you can download the manual for this board from this link. http://global.msi.com.tw/index.php?func=downloaddetail&type=manual&maincat_no=1&prod_no=558
Than go to pg. 2-18 for a better picture showing these case connections.
Like this.
4b15236.jpg Enjoy!
Mike
Apr 03, 2008 | Computers & Internet
MY MONTOR HAS POWER AND IS NOT WORKING.
Hi, dont loose faith. If you look on your mother board along the edge closest to the front of the case you will see a series of pins, usualy about 10 pins. Printed on the board will be the names of the plugs that match. The wires from the front of the case have corresponding names. The power and reset switch will work no matter witch way around you put them. The HDD led and the pwr led will only work one way so if these lights dont work, just reverce the plugs. If desperate you can bridge two pins together at a time until you get the on/off switch. Note you cant hurt anything unless you use a hammer. Regards mistyman
Sep 03, 2007 | FIC FR33E Motherboard
EliteGroup P4VMM2 Motherboard Logo
215 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
