Question about Refrigerators
The refrigerator is not working, the relays continue to click and nothing happens.
  • Refrigerators Master
  • 43,501 Answers
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Oct 02, 2010
Clicking noise
Yes, there are a couple of relays inside fridges. Your fridge should come with a schematic drawing of the circuitry, usually in a bag attached to the back of the fridge. They are cheap to replace, but sometimes hard to reach.
Mar 27, 2012 | Frigidaire FRS23H5AS Side by Side...
This was working fine, then stopped working. The motor gets hot, but nothing else happens. It used to click a bit when I plugged it in and started working, no sound now, it seems dead. Is this worth...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
Jun 09, 2011 | Magic Chef MCBR445W1 Compact Refrigerator
Refrigerator stopped cooling, there are no fans/motors running, when first plugged in there is a brief buzz and then a click but nothing happens.
heatman101
Mar 28, 2011 | Refrigerators
The fridge is not cooling. There is a humming noise then a click and nothing happens. The compressor is not starting
heatman101
Mar 18, 2011 | Amana ABB2227DE Bottom Freezer...
My bottom freezer amana refrigerator is making a clicking noise. And my freezer is barely cold.
Refrigerator making clicking noise compressor not running.
The clicking could be the start relay.If the start relay is bad, the compressor will not start and you will hear a clicking noise in 2-5 minute intervals. The clicking noise is the overload cutting the compressor off when it overheats from trying to start with a bad start relay. To find out if this is bad first unplug the refrigerator. Remove the lower cover from your refrigerator. Then take the cover off that is on the side of the compressor,you will see wires going to this. Now you should be able to see the start relay plugged on to the side of the compressor and unplug it. Now the best way to tell if it's bad is to shake it. If it rattles, it's bad and needs to be replaced. If not, most of the time it's ok. But rather than saying the compressors bad, you might want to replace it anyways because it does not cost much. A quick check on the compressor is to remove the start relay. You will see 3 pins connect a multi meter set for continuity. You should have continuity between any of the 3 pins. If you do not the compressor is bad. Also check from each pin to a good ground on the cabinet. There should be no continuity if there is the compressor is bad. If you replace it and it doesn't work then the compressor is bad and you'll need to call a repairman. (Note that compressors are very costly and are normally not worth fixing).You can enter your model # at Refrigerator clicking for diagrams and illustrations or to purchase a start relay. A 3 in 1 start relay will also work fine.
Jan 29, 2011 | Amana Freezers
Not cooling clicking sound refrig compresso and
IT'S MOST LIKELY THE START RELAY/OVERLOAD PROTECTOR ON THE SIDE OF THE COMPRESSOR. UNPLUG UNIT AND PULL START RELAY OFF AND SHAKE. IF SOUNDS LIKE IT'S FULL OF GRAVEL IT'S BAD, OR GET VOLT /OHM METER AND CHECK CONTINUITY BETWEEN THE START AND RUN TERMINALS ON BACK SIDE OF RELAY, WHILE YOUR THERE CHECK CONTINUITY BETWEEN THE BACK SIDE OF OVERLOAD AND WHERE L1 WIRE COMES IN FROM THE HARNESS. IF ALL THAT CHECKS OUT THE COMPRESSOR MIGHT BE BAD OR DRAWING TOO MUCH CURRNET FOR THE FACTORY START DEVICE. YOU DIDN'T NOTE A SERIAL #, SOME OF THOSE MODELS WERE UNDER RECALL FOR THE RELAY/OVERLOAD PROBLEM.
Oct 06, 2010 | Maytag MSD2756G Side by Side Refrigerator
I have a Kenmore household refridgerator/top freezer and it does not wok. The inside light comes on but other then that, nothing else happens. I switch the freezer setting to "OFF" and then turn it to...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
heatman101
Sep 13, 2010 | Kenmore 74889 / 74882 / 74884 Top Freezer...
Relay keeps clicking on and off
We aren't sure either without putting a tester called an "Annie" on your compressor. Maytag has had a lot of compressor failures, and we have installed overload relays on some of these refrigerators, the compressors ran fine and pulled perfect amps, and hours later the compressors failed anyway. You can remove the overload relay from the compressor, and do a continuity check on the three terminals. You should get continuity between all three, and you should not get any continuity between any terminal and the compressor case or freon lines. If the compressor tests fine, then it is usually, not always, a bad overload relay. If the compressor tests bad, then your refer is not worth repair, usually a 900 to 1100.00 repair in my area in Seattle. You may still have a warrantee on it as most brands still have a full 5 year warrantee on the compressor. Good Luck, Appliance Specialists.
Jan 25, 2010 | Maytag MSD2454G Side by Side Refrigerator
Help me please
sounds like the main pc board.
Jun 19, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Side by side stopped working but clicling noises every second two.
Ok the motherboard is malfunctioning. Ive observed this exact problem before. Replace the board and all will be normal again. If you keep lettig it click and click it may finally kill that relay that you descibed to me or even worse the compressor itself.
Dec 02, 2007 | GE GSL25JFR Brushed Steel Side by Side...
Refrigerators Logo
29 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
