Question about RELIANCE ELECTRIC WATER HEATER
Water leaking from overflow. - RELIANCE ELECTRIC WATER HEATER
  • 760 Answers
This is not an "overflow". It is a Temperature/pressure relief valve. Sometimes they leak with age or build up solids in valve preventing them from closing completely. This is the single most important safety device on your water heater. If one of the thermostats is malfunctioning, the TPR valve will relieve. If the pressure rises too high, it will also relieve. You can replace the valve, but be sure it is the same temperature and pressure rating. You will need to turn the water off and drain some of the water prior to removing the valve. Don't forget to reinstall the down pipe that directs floor to floor or drain. If a new one leaks also, suspect your temperature control. Water heaters can be bombs if the safeties are not working properly
Posted on Oct 02, 2010
My sister have an electric water heater and no hot water. Power is going to the tank. What could be the issue or what can I try to help her out? The overflow pipe do leak but not a great deal. She was...
Probably one of the beating elements has gone bad and it sounds as if the overflow valve needs replaced, if there are no leaks in tank it would probably cost 1/3 to 1/2 cheaper to have elements and valve replaced.
Jul 30, 2017 | Water Water Heaters
Water meter keeps running. When I turn off the water supply to the hot water tank the needle on the water meter stops, does that mean that I have a leak in the hot water pipe coming out of tge tank.
Yes you have a leak on hot pipe or TP overflow tube.
Put ear against pipe to listen for sound of running water.
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html#listen
If TP valve goes into drain line, check if water is running down TP overflow tube.
Check each faucet for leaks.
If pipes are under slab, put ear against each faucet to determine which faucet is closest to broken pipe.
Mar 23, 2013 | Water Heaters
Hot water heater overflow leak
Copy following link for testing and replacing TP valve.
Do not cap off TP overflow tube, as this leakage signals problem.
http://waterheatertimer.org/How-to-replace-TP-valve.html
Jul 29, 2012 | Water Heaters
After water is sufficiently heated up, water flow out of the overflow pipe for about 2-3 minutes. Is it normal?
No.
Water should not leak out of water heater.
Water should only come out of the TP valve and down the overflow pipe if water is too hot, or if TP valve is bad, or if you have stacking condition.
http://waterheatertimer.org/Stacking.html
http://waterheatertimer.org/Leaking-water-heater.html
Jul 14, 2011 | Rheem 81VP6S/430126 Water Heater
Seems that the bottom is leaking. Water is hot. Should I replace the thermostat?
Leaking is not repairable, replace the unit, UNLESS the water is coming from an overflow or overheat circuit, in which case, lower the temp and test again.
Jul 03, 2011 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Water puddles leaking our of overflow pipe onto floor
sounds like your pressure relief is leaking. Make sure your home water pressure isn't abnormally high (above 80 psi). As long as your water pressure is fine, you should replace the pressure relief.
May 25, 2010 | Noritz 6.3 Gallon Residential Tankless...
Hot water coming out of overflow, valves all been checked. Santon unvented heating system help!!
this wil happend with heating ??
if yes look for thermostat on boiler and turn it a little back then wil heater worming up only not to the max heating so then you do not need overflow outlet never leaking again out of overflow
Nov 08, 2009 | RTO Santon® Tankless Hot Water Heater -...
Whenever we switch the heating on there is continuous overflow from our cold water tank in the house
pumping over could be a leak in coil thus pumping through overflowing best of luck
Oct 20, 2009 | Water Heaters
Worcester 350 boiler pressure low - warning light comes on so i top it up with water half an hour later the pressure drops again. Have checked rads and pipes no obvious leaks. Water seems to be coming out...
That overflow is the Pressure Relief Valve.usually they are set at 3-3.5 bar but over time they can be gunged up inside and leak/allow water to flow out. Dismantle & clean or replace. Turn off mains water and ch pipes before removing - operate valve remove & allow for some water to leak from it
Oct 15, 2009 | Water Heaters
RELIANCE ELECTRIC WATER HEATER Logo
309 people viewed this question
Top Reliance Water Heaters Experts
Mack Baxter
Gil Shultz
rickb63
Are you a Reliance Water Heater Expert? Answer questions, earn points and help others
