Question about Alpine PDX-1.600 Car Audio Amplifier
I have an alpine pdx 1.600 powering a 10 in. JBL woofer with a jvc KD-G340 head unit. i have hooked it up to spec but when i turn the head unit volume up to a certain level the bass kicks off and the amp has a blue light on the left and a red light on the right.....i have a toggle switch on the remote wire to the head unit and when i switch it off for a few seconds and switch it back on its ok unless it is over this certain volume limit....please help!!
  • dodge_vipa29 Oct 02, 2010
    thanks for the link and the help
  • 2,272 Answers
When you use the Head unit bass volume control.
When you turn up the bass control it gives more signal to the amp and therefore changes how the main headunit volume>Bass control volume>amplifier gain setting all work together.
Heres a good practice so your subwoofers remain consistent with the rest of your system on average with most of the music you play.
Set the bass control volume in the HU to 3 , then set the gains on the amp.This way you have close to linear volume matching with your HU main volume and the bass control volume.
keep your bass volume control in the + side but keep it as close to 0. +3 always worked.
There is an art to setting THe HU bass control and the amps gain for perfect volume matching with the rest of your speakers.
Typically setting all the speakers to the front speakers.
Volume matching means when you turn up the main volume all your speakers (fronts,backs+subs) will sound equal in every way, even at extreme volume.Perfect for SQ bass.
---------------- You can certainly blow your subs if the voltage/watts you`re sending to them is beyond the capacity of the speaker. You should make sure that if you put amps in your home theater / car that you are still within the limits of your speakers.Otherwise you will blow them. Add an amplifier for the new speakers.And this will clear the problems.As the bass kicks off due to extra voltage getting and this overloads so bass kicks off. ---------
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation
Posted on Oct 02, 2010
  • 3,083 Answers
This really sounds like some component in the amplifier circuit is breaking down under a load, which would require servicing, but I ran across this blog on the web, and they seem to think it's related to the gain, so it might be worth reading:
http://www.caraudioforum.com/showthread.php?t=318023
Good luck, and hope this helps,.
  • Tom Carson
    Tom Carson Oct 03, 2010
    Hope it helps.
How set bass on kd g340
Do you have User manual? If not, it can be downloaded from jvc website: http://books.jvc.com/booklist.asp?Model=kd-g340. Refer to page 20. Press EQ, then use up/dn to select mode, then use right/left to select tone, then use vol to adjust.
Feb 14, 2015 | JVC Car Audio & Video
Replaced the battery in the car but now unit seems dead although power to inline fuse is OK. KD G386/385 Has it got an internal fuse ?
It might be a good idea to check all of the fuses in the car. The radio requires two power sources in order to work properly.
Aug 22, 2011 | JVC KD-G340 Car CD/ MP3 Player
I have jvc car audio model # kd-g335 how to connect my sub woofer?
You can not connect the subwoofer directly to your head unit. You need an amplifier installed to play the sub woofer. Asuming that there is an amplifier installed then: If your head unit has an RCA output on the rear, connect that to the LINE IN of your amplifier. Also there should be a Blue&White cable at the rear of the head unit.(amplifier remote) That should be connected the the remote terminal on the amplifier. (this will turn the amp on and off when the head unit turns on or off) Hope this helps. dreamsystems
Feb 08, 2011 | JVC KD-G340 Car CD/ MP3 Player
Jvc kd-g340 rear speakers not working. I recently bought the car with this unit installed. I noticed that there is a l/r cable, power, ground in the trunk which means there was probably a subwoofer...
check the wires in the back of the stereo if not then make sure the back speakers are not hooked up to a internal amp and if it is make sure that it is not blown
Mar 31, 2010 | JVC KD-G340 Car CD/ MP3 Player
How due stop the demo screen scrolling on the JVC KD-G335
well i cant be sure this will be right because i cannot find that particular model anywhere so you can try this web site the closest model number i could find should be on it http://www.retrevo.com/pdf/23446bh450/10/General+settings+%E2%80%94+PSM#q=JVC+KD-G340 other then that call jvc themselves at (800) 252-5722
Mar 04, 2010 | JVC AM FM CD DET FACE CAR STEREO
Need to wire JVC model KD-G340 into a 97 Kia Sephia
Do not cut the wires from the car. Instead, call Crutchfield at 888-955-6000 and order the adapter part number 120701003. When you call them, ask for color coding. For JVC, refer to the attached picture. Match the adapter color code with that of JVC. If the adapter color code is the same, then connect ground (black), battery (yellow), and wire from ignition switch (red) securely. Turn on the car and see the radio works. If it works, connect one by one speakers and confirm. Remember, perfect connection gives reliable installation.
Nov 22, 2009 | JVC KD-G340 Car CD/ MP3 Player
One rca jack for subwoofer (jvc kd-avx44)
I run this set up im runng a 1000 rms Alpine and 2 alpine type S and everys good
Jun 28, 2009 | JVC KD-AVX33 Car Video Player
I have a jvc KD-G320 cd player and i am trying to hook it up to my 2 12" subs n the cd player doesnt seem to b sending the message to the subs to kick is there anything special i have to get to make...
ok first make sure all the leads are good
remote
and rca leads
check power to amp
then go in to settings in the head unit and change from rear to woofer and then do sub contol on high
Aug 16, 2008 | JVC Car Audio & Video
Alpine PDX-1.600 Car Audio Amplifier Logo
185 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
