Question about MotorGuide STANDARD MOTOR REPLACEMENT PARTS SWITCHES AND COMPONENTSDescript
Can not get my prop off motorguide stealth 250.
bargainbin2
  • 123 Answers
SOURCE: Only one speed on MotorGuide 300 Stealth 30 lb
The speed control.
Posted on Aug 26, 2009
  • 152 Answers
SOURCE: need a new prop for my Motorguide trolling motor #HT28DA - wh
Try these guys:
http://www.trollingmotorparts.com
Posted on Dec 06, 2009
  • 16 Answers
SOURCE: find oners manuals for motorguide modle no. sf300
this site has owner's manuals for the motorguide
http://motorguide.com/support/literature
I hope that this is helpful for you
Posted on Feb 18, 2010
SOURCE: need a relay for a
I have a Motorguide Stealth 200B trolling motor, works perfect but getting a new boat with a new motor. Trolling motor has original manual and paperwork with it, as well as 4 blade Ninja prop and prop wrench. Has some cosmetic scratches on motor. looking for $25.00
Posted on Apr 02, 2011
SOURCE: Wire going to prop of Motorguide trolling motor shorted
Unless you are mechanically inclined, dont attempt this. Take the lower unit apart by removing the prop and removing the two bolts that hold the forward and aft housing to the center housing. Fwd being the cone shaped part. Pull the aft housing away from the motor so you can inspect the connections to the board that holds the brushes and the soldered wiring terminals. You should find the solder missing from at least one of the terminals that connects the wiring from the foot switch to the speed control windings inside the aft housing. Clean up the terminal and wiring and re-solder. Also re-flow the solder on the other terminals. Clean up the seals and the area where the seals meet the housing parts. Replace seals if damaged. Reassemble the lower unit and torque the bolts 45-50 in-lbs and no more otherwise you will fail the seals. This problem is due to a "cold" solder joint that creates a high resistance to elec current flow and heats enough to melt the solder. This is a result of poor quality control at the manufacturer. Good luck.
Posted on Dec 29, 2011
The first thing to check,(After making SURE the electricity is disconnected to the trolling-motor) remove the propeller and see if the shear-pin (Usually made of brass) in in place and not sheared/broken.
If it is, your local marine shop should be able to provide a new one. I always carry spares. If the pin is OK, the windings may have an electrical fault that would require a factory-repair.
Sep 05, 2014 | MotorGuide Transom Mount Great White...
Motorguide troubleshooting
try moving the trim tab above the prop to the opposite direction to pull it back !
Apr 08, 2014 | Boating
Need a relay for a MotorGuide Stealth 200 troll motor - part VF4-899F11
Feb 12, 2011 | MotorGuide Standard Motor Replacement...
Motorguide t47 powerplus trolling motor
t 47 power plus motorguide prop wont turn but you can feel the power going to motor to try to turn it
Jul 06, 2010 | MotorGuide STANDARD MOTOR REPLACEMENT...
Find oners manuals for motorguide modle no. sf300
Aug 04, 2009 | Electrical Supplies
Replacement of motorguide trolling motor prop
Motor Guide hubs come in two different sizes - 3" and 3.5". The 3" size is more for older and lower thrust models. Newer units use the 3.5. The size differences are between manufacturers too. MinnKota's are a little bigger. If you order a new prop, the only issue may be the depth of the prop. I had to use a longer prop nut wrench to tighten the Hydrilla Hacker I purchased.
Triton72
Mar 26, 2009 | Boating
MotorGuide STANDARD MOTOR REPLACEMENT PARTS SWITCHES AND COMPONENTSDescript Logo
154 people viewed this question
Top MotorGuide Electrical Supplies Experts
jdthefixer
Mike
Mike Marcotte
Mike Marcotte
Are you a MotorGuide Electrical Supply Expert? Answer questions, earn points and help others
