Question about E-Machines eMachines Desktop PC
Emachines 790 the front of the machine came off and the attached leads that run from the front cover (the on switch) to the main unit were disconnected. The 3 leads are for the Power switch; power LED; HDD LED. I am just wondering where to reconnect them (they have very small plugs at the end. Many thanks.
  • 1 more comment
  • Andy1999 May 26, 2008
    Thanks,
    Having just looked on the motherboard its definately imperial G - I'm not sure where to look for the rest of the reference.
  • Andy1999 May 27, 2008
    Actually I think ive found the correct pins now - they were bent because of the way the leads must have been pulled out so didn't look like normal pins. It all seems to be powering up now - i just need to connect everything else now like the monitor to make sure it all works after the blow it suffered. There is a dent in the outer casing - im hoping its all safe still. Many thanks!
  • cwood067 Feb 26, 2009
    i have just aquired an emachine 790 from a friend which he believed only to have a defective power supply. I changed power the power supply with a spare i had rated at 350watt origonal 250watt does this matter?
    After fitting 350watt PS nothing powered up at all only the fan on CPC turning, i then noticed the leads from the on off switch were disconnected, where do they go? do they need connecting?
    Thanks for any advice
    Chris
    Genius:
  • 1,027 Answers
I'm still looking the pin outs aren't listed even in the manual.
I believe your board is a TRIGEM IMPERIAL G (intel845G)
Posted on May 26, 2008
  • Mark Williams
    Mark Williams May 26, 2008
    are the pin outs all in one row or is it 2 rows of 9 pins.
  • Mark Williams
    Mark Williams May 27, 2008
    To info how Trigem references the boards...it is by the chip set.
    If you have 845G it is Imperial G, if it is 845GV Imperial GV, 845GL etc.
E000012-0106
The machine cannot be operated and the error code <E000012> appears on the display.
Cause and Solution
The delivery feeder unit may not be installed correctly. Follow the procedure below to install the delivery feeder unit correctly. If the error code persists after the delivery feeder unit is installed correctly, contact your local authorized Canon dealer.
Re-install the Delivery Feeder Unit
NOTE
  • You have to remove the delivery feeder unit and reinstall the delivery feeder unit correctly.
  • When you remove the delivery feeder unit, you have to turn the main power switch OFF.
  • Sending or receiving documents cannot be done when the main power switch is OFF or the power cord is disconnected.
  • If the main power switch is turned OFF, all jobs waiting in the print queue will be erased.
  • Documents received into memory and documents stored for delayed send will be retained for approximately 60 minutes after the power cord has been disconnected.
1. Turn OFF the main power switch and disconnect the power cord.
2. Open the front cover.
If you are using the stack bypass tray, close it before opening the front cover. Open the front cover gently holding the handle (A).
3. Push the levers (A) on both sides of the delivery feeder unit and remove the delivery feeder unit gently, holding it by the tabs (B).
CAUTION
Do not place any object on or touch the transfer belt (A) of the delivery feeder unit. You do not need to manually clean the transfer belt even when it is stained by toner, as the delivery feeder unit has a self cleaning function for the belt. Breaking the delivery feeder unit or damaging the transfer belt may result in misfeeds or deterioration in print quality.
4. Install the delivery feeder unit so that the protrusions (A) of the delivery feeder unit fit into the guides (B) and click into place.
5. Confirm that the triangle marks (A) on the delivery feeder unit are aligned with the triangle marks (B) on the machine.
6. Close the front cover.
Close the front cover gently holding the handle.
CAUTION
Be careful not to get your fingers caught.
7. Reconnect the power cord and turn on the main power switch.
Jun 22, 2015 | Office Equipment & Supplies
C3725 problem
Sir, First open the side of the copier is there any red/orange looking stuff laying around if so the fusing unit is shot and will be needed to be replaced. If it looks ok then close it up and turn off the machine including the main power switch inside the front cover. Then holding down the Utility /Counter button power on the machine first inside front cover switch first(close cover) then on the side operating panel you must keep the Utility/Counter Button press all this time until you get the screen that says "Trouble Reset" then you will touch trouble reset and wait for OK. then power off the machine using main power switch inside front cover WAIT TEN SECONDS then power back on if the code shows again get a Technician to look at the machine if you keep doing the reset you will destroy the machine. Its trying to tell you its broke when that code shows up!!!!
Feb 16, 2014 | Konica Minolta KONICA BR BIZHUB C451...
Code c-3B04
Fusing unit issue! Have to reset with PWR off the machine using both the main pwr inside front cover and sub pwr on the side of the op panel then turn on the machine holding down the Utiliy/counter button. unit the Trouble reset show on the screen then press trouble reset until says OK the Power off the machine with Main power switch inside the front cover, Wait ten seconds before doing that. If it comes back do not re do its broke and telling you so get a certified tech to look at it.
Oct 03, 2013 | Konica Minolta KONICA BR BIZHUB C451...
Hi, my nokia n73 camera unit main rarely works when using the backslide of the phone? it hardly detects the camera. Is there any way to switch camera from front camera to main without using the...
Usual problem of main camera for this phone is the backslide cover,there are 2 gold plated metal pins attach at the back housing which triggering the metal interface of the backslide cover,sometimes if the back cover is not attach well or the lock of it is damage, it will never hit the to pins all thru the 2 metal attach on the back cover.
To be able to fix this problem,simply align the 2 pins attach at the back housing,it should be bouncing and align as well,also clean the metal interface of the back cover,might some area is corroded.
Otherwise, need to replace the backslide cover to be able to use the main camera.
Good day....
Jul 07, 2011 | Nokia N73 Cellular Phone
Trying restore emachine need full back up discs model 590/790
You can order a set of recovery disks here:
https://secure.tx.acer.com/RCDB/Main.aspx?brand=emachines
They are about $20 plus shipping, and you need to input your machine's serial number to insure you obtain the correct disks.
Hope this helps.
Mar 07, 2010 | E-Machines eMachines Desktop PC
SP MODE AND INSTALLATION PROCEDURE FOR TOSHIBA DP 1660.
Installation Procedure:
01.Open the machine and take out all tape
02. Open the front cover and right hand side cover + blue lock press and open the black part
03. front side two scrow (big) open
04. Out of PC Unit ( drum and developer Unit)
05. done you Two part the ( drum and developer Unit)
06. developer keep on developer
07. total Items set on the machine
08. main switch on
SP mode
01. 0+5 press and main twitch same time for AJ MODE
02. 0+5 press and main twitch same time for ADMODE
Jan 28, 2010 | Toshiba e-Studio163 Copier
Emachine T3958 wont turn on
make shure that the 4 wire plug to ther mother board from power supply is plugged in..other wise try a new power supply
Oct 09, 2009 | E-Machines eMachines Desktop PC
Computer is not working
yes it is ur video card i suggest taking it to computer store
Nov 26, 2008 | E-Machines eMachines Desktop PC
Unit will not power on, replaced power unit with 400 watt unit but push on button still will not power up.
Start Simple...!
I know this may sound too simple, but if you are replacing the Power Unit due to and old one blowing, it may well have blown fuses. Check them! in all mains plugs related to PC.
Also, are ALL you connections made. I.e. take off the front cover and check that the power button connector is attached to both button and board.
what are you running?
do you have NVidia Cards Running in Dual sli mode? - this is power hungry, you'll need 500w plus, i have a 600watt unit for this (i run 2 x 9600's in sli mode - i know 400w would never cope with the power demands of CPU's -quad- and GPU's - Dual - plus the 3 or 4 fans you will have on-board.
A little more info on the machine you are building/running would help.
a common old circuit tester would help out here also, to find out if power -when switched on at the main rear switch - is reaching the board, Are there any leds etc on at all?
I hope this is some help, .... Double check all connections...
otherwise post back with system spec and i will find a more precise and definite answer for you..
Oct 26, 2008 | E-Machines T4511 PC Desktop
G4 kirby
ensure the safety switches are made properly by making sure the front brush assembly is fitted properly, you will see a tag that enters the machine making the front switch, secondly make sure the bag bottom housing is on properly and fully rotated so that its tag makes the switch on the side.
The only fuse is in the plug (UK).
Common fault is the mains lead broken internally, unplug from the side of the machine after removing the little cover where the wire goes in. You can use a kettle lead to test the hoover.
If this does not cure it most likely the motor brushes are worn.
Jul 24, 2008 | Kirby G4 Bagged Upright Vacuum
E-Machines eMachines Desktop PC Logo
135 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
