Question about Breezaire WKL 4000 Wine Cooler
The unit is a Breezeaire wine cooler. The evaperator is freezing up.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 50 Answers
MOST LIKELY A FREON LEAK ALMOST 90% OF UNITS WITH FREON LEAKS DEVELOP ICE BUILD UP ON THE FRONT COIL, AND AFTER A PERIOD OF TIME IT GOES AWAY AND THEN UNIT RUNS NON STOP GETTING WARMER AND WARMER TILL IT HITS ARROWND 70 T0 72 DEGREES.
Posted on Sep 20, 2011
The wine cooler is freezing up
The thermostat is broken( check if you ever hear it stop running). or if freezing is only on a local spot like on a corner on the backplate then you have a gas shortage( compressor is running a lot more and longer than normal.but it stops once a wile.
Mar 03, 2015 | Furniture
Why is our EuroCave DUO wine cooler model D264 freezing 1/4 inch of ice on back wall inside cooler?
Most cases of ice build up can be traced to seals that leak humid air into the cooler. Check the door seal carefully using a fresh $1 bill. The bill should not pull out easily when the door is closed. If the unit has a self defrost feature it it is not coming on. Ice buildup inside a wine cooler is very rare. The cooler box should not reach 32deg in normal operation. Does the unit seem to run continuously?
Sep 10, 2014 | Furniture
Breezair unit freezs up in my wine cooler---- why.
Does it run constantly? If so, an easy test fix is to go to WalMart and buy a timer that cycles in half hour intervals. Play with the on/off settings and see if that stops it from freezing up.
May be the thermostat, which is a fairly easy fix.
May be low on Freon.
Jun 13, 2014 | Haier BC112G Wine Cooler
Our breezeaire wks4000 is set up to automatically drain. After 2 years, we noticed there is water dripping down the side of wall. when we try and move the unit, water pours out of it.
YOU PROBABLY HAVE A CLOGGED DRAIN HOSE.
REMOVE THE COVER BY REMOVING THE SCREWS ON BOTH SIDES OF THE UNIT(FAN DECK) PULL TOWARD THE FRONT AND YOU WILL SEE BLUE INSULATION, REMOVE THE TOP PEACE AND THE SIDE PEACE OF BLUE INSULATION ON THE RIGHT, LOOK INSIDE AND THERE WILL BE A DRAIN PAN, CONECTED TO THAT DRAIN PAN IS A WHITE PLASTIC DRAIN TUBE, USE A SHOP VAC TO **** OUT ALL THE WATER, CLEAN THE DRAIN PAN AND UNCLUG THE DRAIN TUBE, I WOULD RECOMMEND A SHOP VAC TO DRAIN THE WATER OUT AND TO BLOW AIR INTO THE DRAIN TUBE TO CLEAR ANY MATERIAL CLOGGING THE DRAIN TUBE.
Aug 04, 2011 | Breezaire WKS4000 (1000 cu. ft.) Wine...
Can you advise what type and amount of refrigerant is in Breezeaire 6000 wine cooler?
TYPE OF THE REFRIGERANT IS LOCATED ON THE TAG ON THE BACK OF THE UNIT IT COULD BE AND R-22 OR AN R-134A
AND IT USES 22 oz OF REFRIGERANT WHAT EVER THE TYPE THE UNIT IS.
Nov 26, 2010 | Breezaire WKE 6000 Wine Cooler
Viking Wine Cellar Temperature Near-Freezing
Viking wine coolers are made by Marvel.They all had issues with freezing the contents. If you replace the electronic cold control system it will be fine.If you don't, it will freeze the wine popping the corks and leaking in the unit.If you get the parts from Marvell they are much cheaper.
Jun 01, 2010 | Viking VUWC141 Wine Cooler
Koolspace NUVO wine cooler recharge
do you have a recovery machine and gauges you need to tap both sides to check the high to and it needs to be vaccumed down to remove moisture ,find and fix the leak. leaks arnt verry common un less someone broke a line somehow. if the compressor is running it is more likley it has a restriction or bad valve in compressor, hooking to high and low sides will determine which if is less than 5 years old it could be under warrant still most sealed systems have a longer warranty than the rest of it is the evaperator getting cold at all.
Dec 31, 2009 | Vintage Keeper Koolspace Wine Cellar
Danby wine chiller
I found the solution to my case. The continuous compressor running problem started a few days after we moved the unit from a hardwood floor to a room where it is on a carpet. For some reason, this caused some sort of freeze up. I solved the issue by raising the unit about 1/2" using a couple of boards I had and placing them under the legs. Now I need to figure out a bit more visually pleasing solution, but raising it up cured my freezing problem.
Jul 05, 2008 | Danby DWC283BLS Wine Cooler
Wine cooler gets too cold (freezes)
Check your thermostat setting, if the setting is ok then something wrong with your thermostat control.
Jan 20, 2008 | Haier BC112G Wine Cooler
Breezaire WKL 4000 Wine Cooler Logo
480 people viewed this question
Top Breezaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Breezaire Refrigerator Expert? Answer questions, earn points and help others
