Question about Kohler CH25 PA-CH730-0040 Command Gasoline Engine
Oil leak by oil sensor wire and low oil light blinking
  • 760 Answers
Sounds like bad oil pressure switch. Part number should be:
25 099 27-S @ $7.49 Not uncommon that when one starts leaking, that it won't functgion either.
Posted on Oct 02, 2010
My daughters oil pressure sensor was leaking. changed oil first. it was low.the oil gauge reds 25-30 when speed of 55-60. when idling warning light blinks. according to om this can be normal but she says...
did you change the oil sensor with a new one and did you clean out the plug from the oil that got into it if not the oil in the plug is shorting out the wires causing the light to blink on and off do this first before you spend any $$$$$ and then get back to me we'll take it from there
Aug 25, 2014 | Cars & Trucks
Oil pan leak
For oil pump,oil pump pressure,oil warning light,oil low,oil ewplacing and other car engine oil problems,the help links are provided below.Click the link to go through the procedure :-----Oil light came on and the car died?http://schematicsdiagram.blogspot.in/2012/03/oil-light-came-on-and-car-died.html--------How to replace Oil filler cap or breather cap?http://repairhelpcenter.blogspot.in/2012/02/how-to-replace-oil-filler-cap-or.html---------Oil pouring out from left front of engine?http://schematicsdiagram.blogspot.com/2012/01/oil-pouring-out-from-left-front-of.html------Common Causes of Car Oil Leaks?http://schematicsdiagram.blogspot.com/2011/12/common-causes-of-car-oil-leaks.html--------Troubleshoot Car Oil leak?http://schematicsdiagram.blogspot.com/2011/12/troubleshoot-car-oil-leak.html--------Oil change details?http://repairhelpcenter.blogspot.com/2012/01/toyota-highlander-sport-oil-change.html---------Low oil pressure light?
http://howtobyme.blogspot.com/2011/11/low-oil-pressure-light-on-dodge-magnum.html
leaking oil from oil pan?
http://howtobyme.blogspot.com/2011/11/kia-sportage-leaking-oil-from-oil-pan.html ----------
Car Turns OFF due to low oil pressure warning light?
http://schematicsdiagram.blogspot.com/2011/12/car-turns-off-due-to-low-oil-pressure.html
leaking oil from timing cover?
http://technoanswers.blogspot.in/2012/02/toyota-corolla-leaking-oil-from-timing.html
For more oil and oil pump details check out the direct links below: ---
How to Replace Oil Pan on car?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-oil-pan-on-audi-a4-and.html
How to Replace an Oil Pan Gasket?
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-oil-pan-gasket.html
HOW TO REPLACE AN OIL PUMP
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-oil-pump.html
HOW TO CHANGE ENGINE OIL AND FILTER
http://schematicsdiagram.blogspot.com/2011/07/how-to-change-engine-oil-and-filter.html
HOW TO REPLACE AN OIL PRESSURE SWITCH (SENSOR)
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-oil-pressure-switch.html
How to Check Differential Oil Leaks and Replace Oil
http://schematicsdiagram.blogspot.com/2011/07/how-to-check-differential-oil-leaks-and.html
HOW TO PERFORM A BASIC ENGINE TUNE UP-OIL CHANGE
http://schematicsdiagram.blogspot.com/2011/08/how-to-perform-basic-engine-tune-up-oil.html
Oil pan Gasket on car?
http://howtobyme.blogspot.com/2011/11/oil-pan-gasket-on-1998-toyota-tercel.html
Oil pressure for car?
http://schematicsdiagram.blogspot.com/2011/12/oil-pressure-for-2001-gmc-jimmy-v6.html
How to replace Oil Pan on car?
http://schematicsdiagram.blogspot.com/2011/12/how-to-replace-oil-pan-on-2008-honda.html
How to replace Oil Pressure Sensor on car?
http://schematicsdiagram.blogspot.com/2011/12/how-to-replace-oil-pressure-sensor-on.html
How to replace Oil Pump on car?
http://howtobyme.blogspot.com/2011/12/how-to-replace-oil-pump-on-2008-honda.html
Car oil leak?
http://schematicsdiagram.blogspot.com/2011/12/car-oil-leak.html
Car oil leaks from valve cover gasket?
http://schematicsdiagram.blogspot.com/2011/12/car-oil-leaks-from-valve-cover-gasket.html
Oil light blinks on dashboard?
http://schematicsdiagram.blogspot.com/2011/12/oil-light-blinks-on-dashboard.html
Oil pressure issues on car?
http://repairhelpcenter.blogspot.com/2012/01/oil-pressure-issuers-on-toyota-tundra.html
Oil leaks from air filter on ford?
http://technoanswers.blogspot.com/2012/01/oil-leaks-from-air-filter-on-ford.html
Wire running from oil pan to alternator?
http://technoanswers.blogspot.in/2012/02/wire-running-from-oil-pan-to-alternator.html
Why car leaks oil from oil filter?
http://schematicsdiagram.blogspot.in/2012/02/toyota-camry-leaks-oil-from-oil-filter.html
Why engine is consuming lots of oil?
http://schematicsdiagram.blogspot.in/2012/02/2008-scion-xb-24l-engine-is-consuming.html
Maint REQD message on car dash?
http://schematicsdiagram.blogspot.in/2012/02/maint-reqd-message-on-2008-lexus-rx350.html
Remove Sump oil pan?
http://repairhelpcenter.blogspot.in/2012/03/remove-volkswagen-sump-oil-pan.html
Sump not coming OFF?
http://repairhelpcenter.blogspot.in/2012/03/sump-not-coming-off.html
How to remove the sump on car?http://repairhelpcenter.blogspot.in/2012/03/how-to-remove-sump-on-vw-beetle.html----------Car oil sump removal diagram?
http://repairhelpcenter.blogspot.in/2012/03/volkswagen-beetle-oil-sump-removal.html
This will help.
Thanks.
Feb 28, 2012 | 2001 Kia Sephia
Where is oil pressure switch on 1995 oil pressure switch
Car oil leak?
This will help.
Thanks.
Feb 26, 2012 | 1995 Isuzu Rodeo
How to replace oil sensor in 2003 olds alero
Car oil leak?
This will help.
Thanks.
Feb 22, 2012 | 2003 Oldsmobile Alero
Fiat stilo loose connection warning
Car oil leak?
This will help.
Thanks.
Feb 19, 2012 | 2004 Fiat Stilo 1.4
How to replace oil pump 1990 f150 4.9 liter inline six
Car oil leak?
This will help.
Thanks.
Feb 14, 2012 | 1990 Ford F150
How to replace the oil pump
Car oil leak?
This will help.
Thanks.
Feb 12, 2012 | 2000 Oldsmobile Alero
Oil pressure light comes on at idle
Car oil leak?
This will help.
Thanks.
Feb 05, 2012 | 1997 Porsche Boxster
How to replace a oil pump
Car oil leak?
This will help.
Thanks.
Feb 03, 2012 | 1999 Oldsmobile Aurora
2001 plymouth neon oil light keeps blinling on and off
You have an oil leak. From where is the question. On most Dodge products, the oil pressure sensor is behind the oil filter. Petroleum products are solvents, however mild. This affects gaskets, wires, hoses, you name it. Have someone check the wires on the oil pressure sensor. Also see if it is screwed in tight. Neons are buzzy little engines and tend to have minor stuff wiggle loose from time to time. There is the possibility of having a "Double Gasket" on the oil filter which would cause the oil to leak and pressure to drop at lower RPMs. If all of that checks out, then you might need a new oil pump.
Apr 17, 2009 | 2001 Plymouth Neon
Kohler CH25 PA-CH730-0040 Command Gasoline Engine Logo
414 people viewed this question
Top Kohler Electrical Supplies Experts
rjivaro
John Trevino
Wayne McNeil
Are you a Kohler Electrical Supply Expert? Answer questions, earn points and help others
